Front tire - getting it right
#350932 08/22/2009 11:05 AM
Keith Offline OP
Okay, after 13,000 km the front tire on my 03 TBA is worn out. (I bought the bike this spring with 2000 km). I'm pretty happy about this 'cause I never did like it and I want ww instead. So....
From all the threads unearthed in my searches I am led to believe that:
- the Dunlop K177 120/90-18 is about the only ww available for our bikes,
- I need to modify the fender mounting bracket to accommodate the taller tire, and
- this is a decent tire and handles pretty good.
Also, it's been explained before but I can't remember... what do those numbers such as 120/90 mean?
Re: Front tire - getting it right
Keith #350933 08/22/2009 11:54 AM
120 is the circumference in cm. 90 is the profile or "height." My 130/70 is shorter than my 120/90, but the former is "fatter."
FriarJohn #350934 08/22/2009 12:33 PM
Sorry Friar.
The 120 is the width in mm. The 90 means the sidewall height is
90% of the tread width.
108mm for a 120/90, 91mm for a 130/70.
FriarJohn #350935 08/22/2009 12:40 PM
I don't know much but I do know that the first number is the tread width in mm and the second number is the ratio of the sidewall height compared to that width.
For easy math if your tire was a 100/70 it would have a 100mm wide tread and the sidewall would be 70% of that or 70mm. A 100/50 would be 20% shorter in the sidewall or 50mm. I hope this helps.
1982 Pontiac Trans Am...K.I.T.T. in progress. "It looks like Darth Vaders bathroom in here..."
BrianT #350936 08/22/2009 7:07 PM
Sorry Friar.
This is actually incorrect, 120 is not the tread width but rather the width measured at the widest part of the tire then the 90 would be 90% of that. Part of what I do at my job is sell and mount tires. We are required to know these things.
Keith #350937 08/22/2009 8:13 PM
Keith Offline OP
Thanks everyone for explaining those numbers. Now... are the above assumptions correct?
Keith #350938 08/22/2009 8:23 PM
It's called aspect ratio, moe will explain it.
Keith #350939 08/23/2009 8:48 AM
Probably 50% correct, based on opinion.
erle #350940 08/23/2009 10:43 AM
I'm never afraid to spread mis-information.
FriarJohn #350941 08/23/2009 10:52 AM
From the Tire Rack:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=46
I noticed in a recent issue of Cycle World or Motorcyclist (I get both) that the Motorcycle Superstore now has an ad similar to the Tire Rack showing costs for various bike tire brands/models and they now have a "preferred installer" to ship the tire to for mounting. The Tire Rack also has this for auto tires. Previously, not a lot of shops wanted to install mail-order tires OR they charged you extra. From their webpage:
http://www.motorcycle-superstore.com/819/MNGR/Preferred-Installer-Locator-a-Preferred-Installer.aspx
My zip yielded all small, independant shops (none that I was real familiar with) The "Super installer" was 45 miles away.
Keith #350942 08/24/2009 9:01 AM
I really yearn for the days when that was a simple 4.75-18.
Keith #350943 08/24/2009 10:02 PM
Keith Offline OP
Well it seems ww tires for our bikes are becoming quite rare. I did find a Dunlop K177 but I had to look far and wide to source one out. I tried in vain to find another make for a ww... nothing. So... I hope Dunlop keeps making them 'cause I'm kinda addicted to the notion of running www on my Cardinal Red.
Guess the next step is to modify the fender mount.
Keith #350944 08/25/2009 11:11 PM
I just put the Dunlop K177 on mine this past weekend.A little bike shop ordered it and a Avon for the back. They feel better than the Bridgstones that was on it, but I still wish Avon made a front www. You want me to find out where he got them.
