Re: dyno run last night 136whp
roadworthy #345852 07/24/2009 9:03 PM
ScottS #345853 07/24/2009 9:11 PM
On all of my dyno runs, we never just go shifting through the gears like that. Just 3rd gear from about 2500-3000 rpm to redline.
roadworthy #345854 07/24/2009 9:45 PM
damien Offline OP
the dyno guy said i had a min speed (50mph) and a max speed (100mph) he said to get up to the min and then open it up to 100mph then let off and what is this arkansas rally u speak of
damien #345855 07/24/2009 10:08 PM
Arkansas Rally
And maybe it was 4th gear, because that sounds right about the speeds, but only used one gear to get the power line
roadworthy #345856 07/24/2009 10:38 PM
My SM with stock bore makes over 60 RWHP and I got a bunch of crap about even that. I won't post my numbers again since I was told by a few on here my numbers are impossible even though there were a couple others who said they were about the same as me. 135 HP isn't gonna happen but I bet it felt great while it lasted!
The_Dog33 #345857 07/24/2009 10:56 PM
I've seen a couple on here that were in the 60's with stock bore
The_Dog33 #345858 07/25/2009 9:55 AM
With a properly adjusted limber chain and correctly inflated tire, 60 HP at the rear wheel translates to 68 - 75 HP at the crank. On a cold dry day with properly tuned intake and exhaust, you can get that from a stock displacement engine.
Now, as for the 136 reading. Some dyno's have too many adjustments for the operator to fiddle with. On the newer ones, you can adjust for altitude, humidity, etc to get a reading that can be close to what you would get at sea level with standard temperature and pressure. On some, you can also dial in a drive train loss 'fudge factor' that might give you a rough estimate of crankshaft power IF it is set correctly.
So, I'm thinking the dyno wasn't setup correctly, but it seemed to be more accurate on other bikes because they had under inflated tires, incorrectly adjusted belt drives and cold, heavy transmission oil, all factors that will result in low readings.
Greybeard #345859 07/26/2009 6:24 PM
damien Offline OP
well about a year after i got the i dyoned it and it came out 51hp and it was bone stock
FriarJohn #345860 07/26/2009 6:34 PM
But what would the dyno operator have to gain by reporting abnormally high numbers?
hmmmm... hooters bike night... hmmmm...
Maybe he had just found over time that people were more pleased and happy with high numbers than low? I'm just thinking about the whole hooters parking lot crowd scene.
damien #345861 07/26/2009 7:26 PM
Soooo...what did you do to the bike to make you think that you actually gained 80+ HP?
Your starting to make me think your avatar is a true!
Zmilin #345862 07/26/2009 9:52 PM
ouch!
roadworthy #345863 07/26/2009 11:26 PM
ouch!
it was said in fun...were all friends here...most of the time
Zmilin #345864 07/26/2009 11:33 PM
He said with a grin!
FriarJohn #345865 07/27/2009 8:23 AM
It's likely the dyno that's the problem, not damien. But what would the dyno operator have to gain by reporting abnormally high numbers? Could it be calibrated wrong for bikes of this displacement? What gives?
He was probably trying to get it to reflect crank HP on bikes with extra thick poorly adjusted drive belts and oversize under inflated tires. May even have put a poorly tuned stock engined "chopper" on the dyno and "Calibrated" it by dialing up the advertised HP.
Greybeard #345866 07/27/2009 9:05 AM
Maybe in a sea of Harleys he was having a bit of fun with the Trumpet owner...
FriarJohn #345867 07/28/2009 8:45 AM
Ya know my buddy has a 1200 sporty, had the dealership do pipes, efi, and intake, dynoed it at like 85hp...something like a 25 hp gain over stock.
Is that possible?
brokenfixed #345868 07/28/2009 8:55 AM
In these days of legislators fancying themselves to be engineers, it is easily possible. 1200 is roughly 74 cubic inches and the blockhead design is said to be more efficient than the older engine, yet I was getting close to that from my old '76 Ironhead XLCH and that was only 61 cubic inches.
Greybeard #345869 07/28/2009 9:05 AM
it just seemed like a large increase considering the numbers that bore jobs add to our bikes. And then I seen the new thunderbird numbers compared to this little sporty and what the hel?
brokenfixed #345870 07/28/2009 9:14 AM
Open up the breathing and (in some cases anyway) fix the valve timing and you can get similar changes, or even better, from Triumphs. Even the little 883 has catalytic converters in the exhaust, so they can start off with decent valve timing. The whole thing is pumping enough air through the engine and getting the mixture down to around 12.5:1 like it aught to be to produce optimum power.
Greybeard #345871 07/28/2009 9:38 AM
it pssed me off cause I was running with him the same at first and then he went to the dealership and came back pulling away from me and driving my rev limiter crazy
