Page 1 of 3 1 2 3
My bike is falling apart (electrical and chain)
#344931 07/20/2009 12:48 AM
I had the perfect week from he||. The worst is detailed here. But leading up to it I had electrical problems and my chain is dying I think.
First, I rode in the rain most of the day on Monday from Helena to Freedom's house. During a stop in Missoula, a bit over half way, it wouldn't start for several minutes. After that it ran without fail the rest of the way to John's.
Tuesday morning after gassing and loading up, it would die, it would miss and pop through the carbs and exhaust then die. It would run ballz out for 10 minute and just shut down, then not restart for about another 10 minutes. Mind you, we were leaving Freedom's house for a little (?) tour of British Columbia. I couldn't trust it.
So we trucked it over to Empire Cycles in Spokane (Tingley's in Missoula didn't have a mechanic on duty all day). We left it for them and they got right on it (I'm pretty impressed overall with Empire), but we returned to T-Falls. The mechanic started tracing out and testing every circuit. He found "a resistance" and repaired some corroded connections in the neutral light and/or kickstand kill switch circuits. He said he noticed that the neutral light was now much brighter. Early Wednesday morning we went back to Spokane and I rode it back to Freedom's so we could load up and salvage some of vacation. We made it to Nelson without any problems.
Thursday morning on the way to do some laundry it ran like crap. Right cylinder wasn't firing at all. Exhaust was dead cold. I was freaking out by now. Thinking it was the coil I started calling all the dealerships in the NW that could've had people coming to Nelson for the Raid. They insisted that the coils generally don't go bad and they don't even stock them. After fiddling with it and trying to swap coils (at the laundromat) to test it and having no joy, I put everything back and limped it back to the hotel and started poking around some more. A new friend from Wyoming started helping me and wonder of wonders, he found the right coil wire wouldn't stay in the coil. So that was fixed. Zmilin said this happened on Karen's bike. Bike ran great after that.
Also, I ran without my fog lights turned on because they keep blowing fuses.
The last electrical problem manifested itself today on the way home from Spokane. The tach needle is going CRAZY. It's bouncing around all over the place. Nothing else seems wrong.
Next, my friggin chain keeps stretching. I kept adjusting it, probably 3-4 times in the last week. It's sagging a ton right now. I'm assuming that means it's worn out and the o-rings are toast. One guy in Nelson said I should've dropped it in a can of oil when I put it away in 2003 after installing my belt drive kit. Thing has less than 10k miles on it total.
Anyone care to comment on any of this? I'm amazed, after the week we've had, that it got me home. The upside is that the engine is running like a bat out of he||. Basically I'm going to tear the bike apart and go through everything if I ever want to take it out of town again. Probably get a new chain and sprocket set and Nology coils and wires just to be sure.
Eff Lucas.
Re: My bike is falling apart (electrical and chain)
FriarJohn #344932 07/20/2009 1:01 AM
Well John, you have had the week from HeII, especially with our buddy. But hey, you met me! so it wasn't all bad!
FriarJohn #344933 07/20/2009 1:49 AM
Firstly let me say I'm sorry for your riding mate. it's always bad when a rider goes down.
Reading of all the electrical faults on our bikes,I'm wondering what'll be next? I thought all these electircal faults had been left in the Meridan Triumph days.[at least I was hoping they had]
findlay13 #344934 07/20/2009 4:40 AM
Sorry to hear of your troubles John. No real help from me though , those problems are best found by hands on examination. As for the chain , depending where it sat I supposed the O rings could have dried out but never heard of that before. at 10,000 miles that chain should have plenty of life left in it, strange. I never let a chain sit that long before I used it but I have to imagine they sit on warehouse shelves for a while.( probably not 6 years though)
The_Dog33 #344935 07/20/2009 6:54 AM
John, this is a long shot but did you manage to put the chain and sprockets back on in the same direction they were on when you took them off?
oldroadie #344936 07/20/2009 8:45 AM
I believe so. But that doesn't mean anything. For all I know I put the front sprocket on the back.
FriarJohn #344937 07/20/2009 8:57 AM
Dont bother...Ill give you $500 for the bike as is!
You didnt tell everyone that the chain was rusting. Makes a cool jingling sound while riding...its be perfect for the holidays
Tach needle...Id follow your plan...go through all the connections and grease em up. You know this but Ill say it anyway...check your wires while your at it...look for pinches and sharp bends that can cause shorts and breaks.
Good luck...and if you get frustrated my offer stands
Zmilin #344938 07/20/2009 9:04 AM
The only bike you're buying for $500 is Freedom's...
FriarJohn #344939 07/20/2009 10:04 AM
10K is a fair amount of wear in one direction and reversing the parts could easily tip it over the edge. Once upon a time we used to reverse the sprockets to access the unworn side of the teeth and only be out the cost of a new chain, of course that was before O rings (and the internet)...
oldroadie #344940 07/20/2009 11:27 AM
That was his first lie after he failed to fix your bike. At 24K mine is in the garage. It is no longer going on a trip over 500 miles. The Prince of Darkness is alive and well. He seems almost purpose built into these things. I really like my bike for day rides when it can be close to tow truck services. Kinda like a Ural, cool to look at but hard to keep running.
My bike has been in a truck 5 times in 24K miles. Imagine how we would feel if our cars stopped running that often. Its shameful.
Sorry for your bad week John. A much greater shame about our member and your friend's accident.
FriarJohn #344941 07/20/2009 11:54 AM
As far as the rear chain stretching, as I remember, the rear sprocket is offset a little. If you put it on reversed, the sprocket is no longer "inline" or in the same "plane" as the front sprocket, and that will cause the chain to wear very fast, as it is "tweaked" sideways. That rear sprocket, as I remember has a clearly visible offset, maybe 3/16 inch wider on one side. It was not reversible, IF I REMEMBER RIGHT!!
Also, my Knology coils & wires did seem to be much better designed than the stock, and have served me well for many years.
satxron #344942 07/20/2009 11:59 AM
It's strange that some have so much trouble with the electrical system on the bikes. I swapped to the Nology coils and wires at like 5000 miles and haven't had one problem. There were no problems before that either. I agree, 5 times in a truck for 24k miles is quite a bit considering mine has never seen the inside of one. In fact, the only two items to break on my bike were the chain guard, which Triumph replaced 4 years out of warranty, and the throttle grip from Kuryakyn that failed last weekend. The thing that troubles me the most are all the stories from guys here and the hassle they go through with the dealers who can't seem to diagnose an electrical problem correctly. I feel very fortunate that I have a Triumph only dealer only 30 something miles from here. Seems the ones that sell 6 different brand of bikes seem to have some serious knuckleheads working in the service department.
tomv #344943 07/20/2009 12:13 PM
my nology wires gone mad cousing problem when got wet was back to old stock wires and no problems during rain ..now have some home made NGK wires
roadworthy #344944 07/20/2009 12:13 PM
Just for the record, the mechanic at Empire did find the problem he was supposed to find and fairly quickly. He surmised that the corrosion in the kill switch connector cause a resistance in the circuit that "told" my bike that intermittently the kickstand was down and shut off the engine. That particular symptom didn't happen after I got the bike back. But it's odd that so many different electrical problems happened in such a short succession.
My bike ran so good after that he may have found a problem or two I didn't realize I had. The coil wire was an easy fix once found. But now I gotta wonder if there was a short that damaged other components or wiring. Or maybe there are more corroded connectors.
FriarJohn #344945 07/20/2009 12:18 PM
check behind fuse box lots of wires and crap there..... mine main fuse wire corroded and one day just broke...before braking had some electrical issues after repair none
Grzegorz #344946 07/20/2009 4:45 PM
But Dave, with all due respect, you don't know if your techs would find the issues any better than ours. My first bout was in FT. Lauderdale with a Triumph only shop and my last 4 were Triumph/BMW only and an independent. The independent fixed it 6k ago and it is still good. Go figure.
I can just imagine talking to the Toyota guy.
Toyota guy: Oh yeah these Solara models are great. All you have to do is swap all the electrics for a good components and you are set to go. Oh, and don't get it too wet unless you coat all the fittings with dialectic grease. After that buddy, you are rolling down the road in style. Its not a problem, just the way they are. But at least its not a Ford huh,
Customer: Really, ah, ok, let me think on that one a bit.
satxron #344947 07/20/2009 4:58 PM
I guess what I was trying to say is that I would rather have a tech who works on Triumphs every day than one who sees one every other week or so... but you have a point. I wasn't trying to start a "my mechanic is better than your mechanic" war.
I don't know if they would be able to diagnose the problem immediately, but they do have a better chance of seeing similar problems before.
Regardless, it sucks that you can't trust your bike for a long ride.
Grzegorz #344948 07/20/2009 6:11 PM
I have a custom battery box with all the under-seat wiring stuffed into it and the fusebox and ignition switch mounted on the side. You can bet I'll be examining all those wires.
FriarJohn #344949 07/20/2009 6:38 PM
I have ridden mine across several states more than once. I am at about 22,000 miles if I remember right without looking and my bike has never so much as missed a beat. It has been in driving rain more than once too. I haven't even opened the right side cover of my engine so my pick up coil is still at the 04 factory setting.
The_Dog33 #344950 07/20/2009 6:41 PM
The_Dog33 #344951 07/20/2009 9:33 PM
Like Ian's story, except 30,000 miles. I wish for two things. That you start having some decent luck, FJ and Satxron, and that I hadn't ever started reading this thread. Stuff like this feeds my paranoia!!!
FriarJohn #344952 07/20/2009 11:03 PM
1) wash it! (so you can see whats under all that grime)
2) replace that rusty @ss stretched out chain before you ride it again. It sounds like it has sleigh bells.
3) like we talked about...go through all your electrical connections. If you had one bad connection chances are there are more.
** come to think of it, didnt you tap into something in the headlight bucket recently? Tell me your soldering and not using taps!?!?! Those connectors you are using for the fog lights are not meant to be exposed to elements. Ill send you a link as soon as I find it for some real nice water tight connectors.
4) check all areas that you have moved wires (such as your fuse box). Those wires are "molded" to fit the bike as OEM. When we start moving those things we bend and stress them like they were not meant to be stressed and bent.
** get a test light and test both sides of all your fuses while you move your wires around. I have seen this in old cars (I used to install car audio).
Have fun!
Zmilin #344953 07/21/2009 5:47 AM
My point John, was in reply to Rons assertion that he wouldn't ride his bike far. Basicly saying don't lose faith, most of these bikes are extremely dependable but being machines and man made problems can arise.
The_Dog33 #344954 07/21/2009 6:19 AM
I think he's beginning to enjoy his new found role as the anti-Triumph troll
oldroadie #344955 07/21/2009 6:57 AM
It sure does seem that way lately
oldroadie #344956 07/21/2009 8:08 AM
yep, but troll? No. Definitely not.
moe #344957 07/21/2009 8:30 AM
Yeah, that's probably too harsh but his posts have become increasingly negative.
The_Dog33 #344958 07/21/2009 8:45 AM
Yes, they can be very reliable, but they're not all reliable and simply saying "mine is reliable" isn't a valid statical sampling. In other words, I'm happy for you, but it has no bearing on my problems.
FriarJohn #344959 07/21/2009 9:42 AM
Since I go way back in the computer business, a Troll starts trouble where there is none. I have a bike that has electrical issues. Dozens and dozens of post per year are right in front of you about electrical problems, and the frustrations they cause our members. It is not acceptable to accept it as normal cause its a Triumph. Its not normal, its reprehensible.
If you refuse to see how badly Triumph has treated their customers in the area of electrical design, I don't know what to tell you. It appears you have become a branded apologist for a company who could care less about you.
I will become increasingly negative about the electrics. They have not reduced the cost of the CDI, redesigned the coil attachment system or replaced the pick up/crank sensor. They have not done one recall on these issues. 7 years of history and not one recall, service bulletin, or even a reduction in CDI retail cost.
I will take the name negative on Triumph electrical issues but not Troll. That is not an acceptable title. In May I did not enjoy turning around in west Texas due to solid rains fearing my POS would not make it to SWTF. That sucked. But those are decision processes you have to go through after the 3rd or 4th pick-up truck ride.
The thing that bothers me the most is this is still my favorite bike that I will not ever sell.
Soo, kiss my a~` I will type about electrics every time there is a new victim of the factory installed Prince of Darkness.
satxron #344960 07/21/2009 10:18 AM
After two quotes of around $500 for a replacement igniter, I happened to recall the phrase "goodwill claim" that I'd heard when pursuing my warped front discs issue. A dealer put my dead igniter through as a goodwill claim, and I got it for free.
While I can agree in the survival of the company aspect that Triumph corporate wouldn't be inclined to take a full page ad in the NY Times admitting to defective electricals, I shouldn't have had to ask for the magic / secret "goodwill claim", but there it is if anyone may need it.
If I had to choose one bike for a desert isle, it would indeed be a Speedmaster or America, but at the same time, I have to agree that some of the electrical design and install is less than stellar. The placement of the igniter over the hot engine, and some skinny little wires hanging out in the wind without loom or any protection from chafe, and too small of wiring that will not allow for the full potential of the charging system come to mind first. If I can wrangle my bike into a dry warm spot for the Winter, I'd like to do over a great deal of the wiring.
Bucky #344961 07/21/2009 5:24 PM
Re: Probs with K&N pod filters staying on [Re: woodley74]
#398938 - 06/15/09 11:57 PM Edit Reply Quote Quick Reply
Hey Brandon, is there a thread somewhere in which you talk about the reasons for chopping up your wiring harness?
Friar's Ride - Bookmark it in case BA.com ever disappears. Not that I want to freak anybody out or anything...
Post Extras:
(Chopping up) my harness eliminated all of these probs for me. If I have trouble now all the bs unnecessery wires and plugs are out of the way and the important ones out in the open making shorts and ground issues easy to find.
To answer your question- Yes there is. This one.
satxron #344962 07/21/2009 6:31 PM
First I must apologize for misusing the term troll, Jim corrected me and I admitted the mistake.
Second, I'm no "apologist". Like you I love my bike and I'm on my second ignitor. Things break, I bought a used bike, I have no leverage.
Third, why not put that anger to good use? Surely there are enough of us now that have had ignitors fail that you could use us a collective bargaining tool to lever Triumph into action. My ignitor failure was well documented on this forum, you've had electrical troubles, good Lord Dill went through three or four ignitors...put that anger to use man. You're just preaching to the choir here.
oldroadie #344963 07/21/2009 6:46 PM
We have no problems per exchanged pms.
The problem with Triumph is they really don't care. I predict our bikes will be phased out soon anyhow. I know mine is not for sale even though the company that built it could care less about the electrics and the problems they cause. I still am very attached to the bike. I just can't take it anywhere and will ride one of the bigger ones on my next trip. Its a great bar hopper and bike night bike though.
I will temper my comments as they do no good anyhow. Mr. Peter in Ga. could not be bothered as he has no production control, just PR in America.
FriarJohn #344964 07/21/2009 6:49 PM
Maybe not your problems and sure doesn't cure Rons either who I feel for too but it does provide 2 examples of trouble free bikes to those new guys reading this thread to show not all are wrought with problems.I was including Wendy's bike with mine as trouble free and both are 04s. I don't have your answers John, if I did I would tell you like I did when you were asking about seating valves.
The_Dog33 #344965 07/21/2009 7:09 PM
Ian, on the off chance that some of the new guys or new buyers do read these threads, would it not be a good idea to vent? I know you probably had a positive effect, weather you know it or not, on a certain vendor.
Maybe when the shoppers tell dealers about the owners whining about poor workmanship and bad service the company will listen. Maybe not, but I don't know that it does harm.
You can still love a bike and hate its habits. I have an awful lot of oil on my floors from bikes I love You have some of the most problematic motorcycles ever made compared to current standards and you love them. The Prince of Darkness was not a figment of one guys imagination.
Actually it was the connections and Lucas got the bad rap for all of it. Probably less than fair.
Remember the old joke that you take off in a space ship, you look up and it says "Electrics by Lucas" on the control panel.
satxron #344966 07/21/2009 7:24 PM
Point taken, I was not trying to belittle your or Johns problems at all. I also agree that Triumph should do something about the electrical (CDI mostly) problems and the starter gear issue scares the heck outa me and wish they would recall that style case. I know that won't happen due to cost if nothing else. I was just trying to show some pos. in with the neg.
I think Lucas got a bad rap on the old bikes since as you said the most problems were in the wires. The components worked for 50+ years in many cases. That Zener diode was a bad idea though.All the old bikes I rode on a regular basis had my own harness in them.
satxron #344967 07/22/2009 9:07 PM
I have also had a lot of electrical problems, I have replaced 4 coils 1 set of plug wires, a igniter unit, and I have no ideal how many fuses on my 04 America. What I found was if you will take the time to unwrap your entire wiring harness. you will find skinned wires, and even spliced wires. I went through the entire harness and replaced bad wires and recovered them. When you ride in the rain water will get in the loose wiring covers and stay.
rebelraider #344968 07/22/2009 9:10 PM
That is what Triumph needs to hear! But hey, they are not listening.
rebelraider #344969 07/22/2009 9:11 PM
That's pretty much what I'm expecting. Not what I wanted to hear, but expected nonetheless.
rebelraider #344970 07/22/2009 9:14 PM
I (fingers crossed) haven't had any electrical issues whatsoever. Now that my bike is getting a little bit older I'm not sure I won't have issues in the future given what I've read here.
So, would it be possible for anyone who knows better than myself what I should be doing to help prevent any electrical breakdowns in the future.
I remember for instance posts suggesting members use dialectric grease on all the fuse connections.
Is this right and also is there any more good tips?? I just don't like the idea of being stranded with an electical problem because they look like they are hard to fix.
Page 1 of 3 1 2 3
