Page 2 of 4 1 2 3 4
Re: Disconnect TPS
roadworthy #344073 08/14/2009 4:52 PM
well it maybe just my imagination but i unplugged mine today and only did a 12 mile run back home but bike seemed smoother might be in my head because having unplugged i expect a difference, but when i am at low revs in almost anygear and then accelerate it is normally a bit lumpy almost as tho i am in wrong gear but i didnt get it once comeing home and i was trying just seemed a far smoother ride
Tone
Re: Disconnect TPS
lardie #344074 08/15/2009 4:06 AM
Just pulled the plug. Now let's see how she feels...
Update: Really couldn't feel any difference running with the TPS disconnected. The MAJOR improvement was that the excessive popping I've had is g-o-n-e! Nice.
Re: Disconnect TPS
Scottdog #344075 08/15/2009 11:09 AM
Scottdog is correct, default dynoruns are basically WOT, especially with CV carbs, unless the dyno operator specifically tests for other combinations/conditions (say, a/f @ cruise or idle). It therefore should come as no surprise that back to back dyno runs on the same machine in the same conditions would show similar results with & without TPS connected.
Re: Disconnect TPS
Keith #344076 08/16/2009 11:59 AM
I disconnested my this weekend, see no reason to ever hook it back up. Now what else can I rip out of the wireing on this thing
Re: Disconnect TPS
rebelraider #344077 08/17/2009 12:11 PM
Found this regarding popping on "the other site" written by Pieman. Can't say I fully understand everything, but surely someone does?
Our Bonnies with the carbs setup correctly and with anything other than the restrictive OEM silencers will tend to snap, crackle and pop on the overrun to varying degrees, mainly between 3,000rpm and 2,000rpm. The AFR in this rev region starts at around 17.5:1, goes down to 14.5:1 and then by 2,000rpm is back up to 16.5:1
If you want to reduce the overrun snap, crackle and pop to virtually nothing, set your pilot screws to the correct setting and then remove the ACV spring from the left side of the left carb and cut off exactly three turns. Put it back together with the cut end away from the rubber diaphragm and go for a ride, no more snap crackle and pop.
This mod doesn't effect the carb setup in any other way than by reducing overrun noise. Enjoy.
Sounds interesting (I think), but I do need an explanation...
Re: Disconnect TPS
piper1 #344078 08/18/2009 4:11 AM
Here is a link to a source that seams to shed some light on the ACV function - www.thumperfaq.com/acv.htm
Hasse
Even better is this link to the Keihin CVK mysteries where 'ACV' is named 'Coasting Enricher' - www.gadgetjq.com/keihin_carb.htm
Second edit: This issue with the 'ACV' is also discussed in the BA thread 'I really need help on this one!! Carb issue?'!
Air Cut Valve Spring
Hasse #344079 08/18/2009 10:38 AM
Thanks! OK, so now I'm a little smarter and really think I understand it. However, cutting a spring is quite err... definite. Could be hard to find a new one if needed. It sounds great though, to be able to fatten up the mixture when decelerating and only then. Would make reconnecting the TPS possible and still get rid of the pop and crackle...
Re: Air Cut Valve Spring
piper1 #344080 08/18/2009 12:10 PM
i just happened to come across this TPS eliminator kit figured I'd post it
http://www.shop.lcfabrications.com/product.sc?productId=19&categoryId=4
brokenfixed #344081 08/18/2009 12:17 PM
Keith Offline OP
Ahhh yes, for all us TPS-be-gone folk that would clean up the right carb nicely.
piper1 #344082 08/18/2009 2:51 PM
Hi, After spending 3 weeks messing with carbs and mainly the Air Cut Off Valve I feel somewhat enlightened on it.
This is ONLY my opinion and I dont mean to tread on peoples toes but:::: cutting the spring is NOT the way to go.
The design on the air valve is rather clever... should you take it apart you will see at the rear of the diaphragm is a small piston shaped rod, under normal running, tickover, cruising and accelerating the spring holds the piston to the back of a recess allowing unrestricted air into the carbs via a small drilling.
Once the throttle is closed there is a vacum in the air valve and the small piston is sucked towards the outside of the recess closing the 2 air holes making the mixture richer.
If you were to cut that spring lessening the tension the vacum would actually pull the piston out covering the holes at idle and richen the mixture considerably, on over run (high vacum) the piston would be pulled PAST the holes so defeating the object. The spring is a designed length to allow the movement to work but it also acts as a stopper when fully compressed to stop the piston moving out the opening too far.
To disable the valve is a simple matter of undoing the 2 screws and place a small bit of a plastic bag OVER the O ring to stop the vacum. Cheap and reversable.
Hope that might help someone.. I spent ages playing with it, springs, tape, vacum gauges so I have a very good understanding of how it works.
TrOjAn
TrOjAn #344083 08/23/2009 4:14 PM
Will disconnecting the TPS cause any damage?
miniski #344084 08/23/2009 6:01 PM
Hope not.
I finally unplugged mine, or should say had my son do it. I couldn't begin to get enough fingers in place to pull the plug apart...
Went for a short ride today and the throttle response feels better and the engine feels smoother. Didin't check the popping thing, but I had that pretty well dialed out already.
More flags More fun!
Re: Disconnect TPS (malarchy)
Keith #344085 08/23/2009 11:45 PM
OK...so I disconnected my TPS a few days ago to see what all the hoopla was about. Here is my experience....
BEFORE:
Freak (K&N pods for those that want to split hairs), Specialty Spares long cannons, 150 main, 45 pilot, dont remember the turns out.
The bike ran just fine. No issues at all.
Smooth throttle response off the line.
Plenty of power for what it is.
No major popping on decel, rather a nice low burble as the rpms came down
No backfires etc...
So why did I do it you ask...cause theres always something else to try to make things better and so many people liked what it did for them. Oh...and I love to tinker
AFTER:
No change in setup other than re-connecting the TPS.
Off the line throttle response was bad. The bike wanted to die first before it would take off.
I noticed a backfire usually in situations where the RPMs were high (over 4000) and I needed to pull the clutch for a quick stop. Not a loud backfire but I could hear and feel it.
Didnt notice a change in popping on decel.
Didnt notice any increase or decrease in power.
Oh well...I guess I can not report positive results with this one. I guess my bike is just set up right
Zmilin #344086 08/24/2009 12:31 AM
Keith Offline OP
Kinda interesting... like everything there is no said and fast rule. Too many variables and life's too short to figure it all out. But I'd love to 1/4 mile against you and yours just to introduce another variable. Nah.... just kidding. Just that since I disconnected the TPS on mine is seems to go like snot compared to before. Could be my imagination... but no ill effect for sure. Go figure, eh?
Keith #344087 08/24/2009 1:01 AM
Keith...Ill drag with ya...as soon as you make it down here
I thought it was interesting that I didnt get a positive result but like you said, variables and lots of em.
Re: Disconnect TPS
Keith #344088 09/03/2009 2:36 AM
Don't tell PETA, but I thought I'd give this horse a few more kicks....
After disconnecting the TPS and getting a few good miles in, I have this to report:
The bike runs smoother. The throttle is more responsive. My gas mileage hasn't changed - still average about 45 per. And, the most impressive result, when I hit the limiter, it no longer dies for several seconds - it just burbles a bit to let me know it's time to shift or back off.
The only downside so far - I work nights - leaving at midnight - and I used to have to pull the choke out 1/4 to 1/2 to start the bike. Now (and it's been in the high 40's low 50's) I have to pull the choke out all the way or it doesn't want to start. Once started, I push the choke in about 1/2 and give it a minute or two, and it runs fine.
For those who hyper-analyze these things:
03 America 790cc.
Thunderbike silencers.
45 pilots, 130 mains. Slides drilled to 7/32.
Stock airbox with snorkels removed, K&N filter, with screened bellmouth fitted.
Vacuum balancer hose fitted between intake manifolds.
Knurled thumbscrew pilot screws set at 3 1/2 turns.
Nology coils and high performance wires.
89 octane gasoline.
It seems to work well for me.
Re: Disconnect TPS
Deon #344089 09/03/2009 4:28 AM
Great! I don't think I'll go back.
Re: Disconnect TPS
Deon #344090 09/03/2009 8:59 AM
did you really drill your slides out to 7/32? that is .219 inch. It works okay?
the usual drill out is to .118 inch. approx 3MM up form the 2.5 mm stock.
Re: Disconnect TPS
mag10 #344091 09/03/2009 9:54 AM
I'm pretty sure 7/32" is what I did to mine as well
Re: Disconnect TPS
roadworthy #344092 09/03/2009 10:55 AM
I think my drill bit was 7/64.......
Re: Disconnect TPS
Hasse #344093 09/03/2009 11:38 AM
Yep. 7/64 "
Here's the link
Click Here
Tony G '03 America
Re: Disconnect TPS
TonyG #344094 09/03/2009 11:44 AM
that's right, it's been years since I did it, hard to remember small details like that
Re: Disconnect TPS
roadworthy #344095 09/03/2009 1:28 PM
Dave, they say that the first thing to go is your memory.
I can't remember the second thing.
Tony G '03 America
Re: Disconnect TPS
roadworthy #344096 09/03/2009 1:28 PM
7/64 = .109 inch, that sounds way more likely. and you could still go bigger yet. I have mine at .120 inch.
back to the original topic - My TPS is off the carb and unplugged from the harness. It seems to idle better than it did before, especially when cold. No down side to removing it that I can see (so far).
Re: Disconnect TPS
mag10 #344097 09/03/2009 1:34 PM
It was 7/something... and it was a loong time ago. What's a few .000's among friends??
Sorry.
Re: Disconnect TPS
TonyG #344098 09/03/2009 3:31 PM
then I'm in bad shape, because I'm only 31
Re: Disconnect TPS
roadworthy #344099 09/04/2009 3:56 AM
Im due a dyno run soon... should I do it with the TPS connected or disconnected?
Decisions decisions
TrOjAn
Re: Disconnect TPS
TrOjAn #344100 09/04/2009 6:08 AM
Decisions decisions
yes you should.
Re: Disconnect TPS
TrOjAn #344101 09/04/2009 8:24 AM
Decisions decisions
do one of each. it only takes a minute or so to unplug the TPS. Then you will have a straight up answer. Just tell the dyno guy what you want to do before he starts.
should be interesting.
Re: Disconnect TPS
mag10 #344102 09/04/2009 10:44 AM
Keith Offline OP
Decisions decisions
Took me a lot longer than a minute to unplug that puppy. It's a hard place to get yer hand into.
Re: Disconnect TPS
Keith #344103 09/04/2009 12:13 PM
Decisions decisions
that cause your old and stoned
Re: Disconnect TPS
Zmilin #344104 09/04/2009 1:30 PM
Keith Offline OP
I ain't laughing.
Re: Disconnect TPS
Keith #344105 09/04/2009 4:33 PM
Hey, I resemble that remark!
From what ScottDog explained in another post:
Or, my take on it:
When you do a dyno run, the throttle is wide open.
So the spark is at full advance.
If you disconnect the tps, it goes to full advance (default).
Same thing, right?
Re: Disconnect TPS
unclecharlie #344106 09/04/2009 5:34 PM
...When you do a dyno run, the throttle is wide open.
So the spark is at full advance. If you disconnect the tps, it goes to full advance (default).
Same thing, right?
Basically, yes.
Re: Disconnect TPS
Keith #344107 09/04/2009 6:45 PM
I ain't laughing.
I am
Zmilin #344108 09/04/2009 8:58 PM
BEFORE:
No backfires etc...
AFTER:
so your bike ran like crapp with the TPS disconnected?
Erwin
05 America
Erwin #344109 09/04/2009 9:37 PM
Not like crap but noticeably worse in respect to backfire and off the line response. It felt like it wanted to die on takeoff unless I realy throttled up.
Normally its smooth as glass of the line and only backfired a couple times on startup but NEVER while riding or on decel.
Re: Disconnect TPS
unclecharlie #344110 09/04/2009 9:44 PM
Same thing, right?
Well not exactly since the dyno run the operator starts at closed throttle and opens it to get the full range and if default is full advance then you start at full advance instead of the normally retarded starting position then advancing as the engine runs faster. Not sure how much impact the TPS sensor has on that though since throttle position changes as you move through the gears and the advance should change as the engine runs faster not as the throttle opens and closes since the ignition has to keep up with the RPM not the throttle position.
Re: Disconnect TPS
The_Dog33 #344111 09/04/2009 11:18 PM
...Well not exactly since the dyno run the operator starts at closed throttle and opens it to get the full range ...
Now we're getting technical, however for practical purposes the CV carbs are WOT above approx. 3500 RPMS (& lower)on a conventional dyno run. That said, a dyno ain't the street.
Re: Disconnect TPS
Zmilin #344112 09/05/2009 12:00 AM
Keith Offline OP
I ain't laughing.
I am
Okay that's it! I'll never lead you unscathed through all the radar traps again. Yer on yer own next time!!!
Now let these guys get back to discussing TPS stuff. Whatareya... stoned or something!!
Page 2 of 4 1 2 3 4
