Page 2 of 3 1 2 3
Re: Sportster 1200 vs Bonneville America/Speedmast
Greybeard #325580 04/16/2009 10:55 AM
OCRider Offline OP
Is the difference in performance between the newer 865cc engine and the older 790cc version noticable? If I were to buy the Triumph, it would be an '09 because I want fuel-injection. But just out of curiousity, I was wondering if the larger size was significant to any degree.
OCRider #325581 04/16/2009 11:06 AM
Nope, not enough that it's really much noticeable, JC.
Depending on their state of tune, both of 'em will give you about 50-55 BHP at the rear wheel in stock form.
Dwight #325582 04/16/2009 11:17 AM
and for an extra 1 or 2 grand, you can bump it up to 70-80rwhp too
roadworthy #325583 04/16/2009 12:17 PM
OCRider Offline OP
Roadworthy, how would you do that (bump HP)? I would be interested in more ponies, but never at the expense of reliability or longevity. In all honesty, I'd probably be just fine with the stock version. But I'm surprised that my VStrom actually generates more HP (I didn't look, but I believe it's rated at 65hp). I admit my ignorance on this subject, but I'm going to assume the higher HP out of the VStrom's smaller engine is due to the Vstrom being water-cooled?
OCRider #325584 04/16/2009 12:35 PM
Dave is talking about doing a big bore on it, The 904 kit is pretty easy and in expensive as big bore kits go. Plus it;s made by Wiseco so you know it's top notch.
OCRider #325585 04/16/2009 12:37 PM
I have the 904 big bore kit with a ported/polished head and 1mm oversized valves, and my hp went from 54 to 70 and torque went from low 40s to mid 50s. I am waiting to get my bored out stock carbs delivered, that should add about 5-7hp, and finally I will be getting reground cams to put me up near or over 80rwhp, and I'm hoping to be in the 60 ft lb or better range for torque. Power is money, how much do you want to have and how much do you want to spend? There are many many guys here with the big bore kit, and I don't know of any reliability problems. These motors are pretty much bullet proof. These bikes run much better stock than the numbers suggest, I was very happy with mine in stock form, but I just like to have more power.
roadworthy #325586 04/16/2009 12:59 PM
OCRider Offline OP
I forgot about the bigbore kit. I have read about those before. If it's reliable and doesn't do anything to reduce engine life, then it sounds pretty darn nice. Always an option, and I guess you could put several thousand miles on the stock engine first before doing anything like that.
Btw, Stainetune claims a 7 to 8hp increase by just adding their slip-on exhaust for the BA/SM. Is this true, or just hype? I had a stainetune on my BMW F650 and liked the sound, but I don't think it did anything to increase hp.
OCRider #325587 04/16/2009 1:04 PM
Open up the exhaust and air intake, and you can get a nice boost in power.
roadworthy #325588 04/16/2009 1:07 PM
The bored out stock carbs that I'm waiting on, have shown a 5-6 hp increase on a dyno on a bone stock bike. I will post numbers when I get them, hopefully they get here today. The guy will bore out your stock carbs for right around 300, maybe less, maybe more. I'll keep everyone updated.
roadworthy #325589 04/16/2009 1:17 PM
I'm interested in that Dave so please do keep us informed.
I plan on running my bike for 100,000+ miles since I have heard they go that far and farther before I do any rebuilds. Then I plan on doing all the bearings and a big bore once the engine needs to be rebuilt anyway. If I have the money then I'll probably go with a stroker too.
I wonder if the EFI guys could put carbs on those bikes, just a thought for guys like me that like carbs so I can tinker.
The_Dog33 #325590 04/16/2009 1:22 PM
if anything ever happens to my motor, the next build is going to be the 1100cc, no machining the crank or opening the cases, just a new billet cylinder block and pistons.
roadworthy #325591 04/16/2009 2:01 PM
OK, here's maybe a stupid question, but to bore out stock carbs, what does it actually mean? What is bored and how?
piper1 #325592 04/16/2009 2:08 PM
The size of the opening that the air travels through is opened up.
piper1 #325593 04/16/2009 2:08 PM
What he's doing is making the intake side and the manifold side of the carb bigger (I don't know exactly how it's machined), but he has tested them on a flow bench and the stock flows at 199 cfm's and the new bored out carbs showed 234 cfm's. He also does some drilling to the slides, and polishes the slide. I don't know why. The test will be if it feels better, more responsive, dyno numbers...
roadworthy #325594 04/16/2009 2:15 PM
OK, thanks for explaining. Nothing you do on your workbench in the shed... Can't wait to for the results! Sounds like it's heckofalot cheaper than bigger carbs.
roadworthy #325595 04/16/2009 2:44 PM
OCRider Offline OP
Is this another aftermarket upgrade option for BA/SM, or is this something you plan to have custom built?
roadworthy #325596 04/16/2009 2:50 PM
Making them larger decreases the air velocity is that crucial for carbs? Or does he modify something to increase the velocity?
OCRider #325597 04/16/2009 3:11 PM
this is an available aftermarket upgrade. stock stroke, bigger displacement
904 has 92mm pistons, the 1100 has 110mm, I think
brokenfixed #325598 04/16/2009 3:14 PM
I'm not a machinist, all I can do is relay info from him. Maybe it's swirled like the head should be, or the intakes, or whatever he does, but the numbers are there and proven, both on the dyno and the flow bench. For the price, it looks like a very affordable upgrade for carbs, and you know they will fit just like stock! Like I said, I will post dyno numbers soon, I'm expecting delivery on these today, finally, after delays because of the custom intakes he was having machined from billet aluminum.
Re: Sportster 1200 vs Bonneville America/Speedmaster
erle #325599 04/16/2009 3:52 PM
We can talk about price point. Harley's are way over priced.
I test drove a new sportster and I was not impressed.I could not use all the power it had. The BA I ride is an great handling bike. I don't even get into 5th under 60 to 65 mph on the 2 lane roads. It has plenty of power. The braking is fine. I must have forward controls. The middle weight bike is for me. I am not a big dude, but if the bike leans over at a stop I can pick it back up from a near ground touching position. This thing nadles as well as my old Norton which was a roadracer. This thing does destroy curves. I love this bike. You will to. I ride all day and am not sore and I am 57.
Braveheart #325600 04/16/2009 7:29 PM
OCRider Offline OP
Thanks everyone for the great information. I've pretty much decided to drop the Sportster from my list. The Triumph demo days are the 24th & 25th locally, so hopefully I will get a chance to ride both the America and the Speedmaster. Even if I only ride one, I figure they are pretty much the same except for the options that have been mentioned on this thread.
The next step will be to see if I get a decent trade-in value on my Vstrom. I hope so, but I also realize that I might have to sell it first before buying.
OCRider #325601 04/16/2009 9:39 PM
Remember they are extremely quiet stock but easy to pop out some baffles.
The_Dog33 #325602 04/17/2009 12:06 AM
Dog is right, they sound like a sewing machine in stock pipes.
OCRider #325603 04/17/2009 1:08 AM
On a carburetted 865, the first order of business is to swap the cams. Aftermarket cams such as Thunderbike or even stock 790 cams are needed before anything else will be fully effective. From the rated HP, it looks like the injected version has better cams to start with.
Once the valve timing is corrected (if needed), open up the exhaust and intake for a 12 - 15% power increase. If you still want more, the Wiseco big bore kit will take care of it.
roadworthy #325604 04/17/2009 8:45 AM
you actually need to bore the cases for the 1100 so they do need to be split
Frank #325605 04/17/2009 11:13 AM
you are correct, sir. my mistake.
erle #325606 04/17/2009 3:26 PM
i had a sportster 1200 before my america790cc and all i can say is the america is all that i wanted the sportster to be i will be sticking with triumph.Harleys are ok if you dont do long rallys,but thats just what suits me.10 out of ten for my triumph.
TICKY #325607 04/17/2009 8:45 PM
here is a link to my new thread about the carbs, now with pics!
http://www.bonnevilleamerica.com/forums/...ge=0#Post386230
roadworthy #325608 04/18/2009 5:38 AM
Shameless promoter! Hey Dave, what ya gonna do with all that extra power?! (Oh god, I'll probably find out if you ride to the midwest ralley with me...)
arstaren #325609 04/18/2009 8:35 AM
That's right Rich, we will expect lots of photos from you of the back of Dave's helmet way off in the distance.
ThomWill #325610 04/18/2009 10:13 AM
hope you have a powerful lens on that camera!
OCRider #325611 04/21/2009 10:11 PM
something to consider... Speedies and Americas tend to lose resale value real quick like the moment they are taken off the showroom floor. There are deals abound on craigslist for one of these awesome bikes in the $4-6K range with very little miles on them. I bought my 04 in Oct'06 with 3400 miles for $4800, and nothing wrong, not a scratch. The prior owner even took the liberty to buy D&D pipes for it. All I have spent my money on so far is oil and filters, and a set of panniers and EZ brackets.Oh heay, I bought some of Fast Eddy's Mirrors and stickers too! Way cool and a bargain!
Andy 04 Speedmaster and missing my '70 TR6R
Andy_B #325612 04/22/2009 3:22 AM
All the 1200 sporsters I priced were all over $10,ooo so you'll save as much as any depreciation before you leave the show room floor. Plus if you ride with someone on a Sportster when you get off your Bonne., your friend will always beat you into the restarunt, because you'll always have to field all the questions and complements out in the parkinglot. I think it's called curb appeal
erle #325613 04/22/2009 3:58 AM
done a road test on sportster 1200 custom last week at silverstone harley davidson & that skinny front wheel in my opinion is a nightmare in town/traffic riding & you hit a pothole with it & you will fill ya pants! i also test rode the rocker C & that was the most uncomfortable bike i have ever ridden! the bars are wrong the seats wrong & for a 1500cc bike it was under powered.
dmillikan #325614 04/22/2009 6:14 PM
I've rode harleys, hondas and triumphs, now have over 15,000 on my 07 america with out so much as a hiccup, try that with a hardly. Have a bud that rode to alaska and back from the east coast, 06 america, 43,000 miles with only regular oil changes, tire changes. Did have to replace the tail light bulb twice tho.
jusolsteve #325615 04/22/2009 6:41 PM
Can't Triumph get anything right?
Lazyrider #325616 04/22/2009 11:55 PM
Lost my tail light bulb once in Conn. at night. Almost junked the bike.
The_Dog33 #325617 04/25/2009 11:04 AM
OCRider Offline OP
I got a chance to do a demo ride (Triumph Demo Days) yesterday. The America was booked, so I settled on the Speedmaster. Just like I thought, I did not care for the drag bars, which were too narrow and too far forward for my taste. However, the Speedmaster was a fun ride and had a very nice rumble to it. In fact the SM and BA were both loud bikes when compared to the other models on the demo run. Don't get me wrong - they were no obnoxiously loud - they had a pleasing rumble, and the sound picked up when you gave it the throttle. So for you guys that said the SM & BA sound like sewing machines, maybe Triumph listened and for '09 put louder pipes on. A bike that was almost whisper quiet was the Rocket III touring, and I was surprised by this until I thought about it's intended use (long hauls). And what a nice looking bike the RIII was up close. Also had a chance to look at the new Thunderbird. No rides allowed on the bike, but it did look nice.
Btw, the mirrors on the SM sucked. Would definitely replace those if I bought that bike.
They still have the "demo days" going on today, but I'm so busy that I'm not sure if there will be any time to go back over and test out another bike. If I do, I'd like to try that RIII!
OCRider #325618 04/26/2009 11:01 AM
If you haven't sealed the deal yet see if the dealer will swap bars out for you. Many dealers will make small changes like that to make the sale. Herm threw in a seat for me because I wanted the BA set up for taking Wendy when I first bought it and before we got her a BA. He trew in the seats and I paid cost for the sissy bar if I remember right.
The_Dog33 #325619 04/26/2009 11:26 AM
OCRider Offline OP
Dog33, I'm not yet close to any deal, so no worries at this point. I'm sure the dealer would let me ride the BA on another day if I wanted. It was just that Triumph had booked all rides for the BA on Friday so I rode the SM to get a feel for what the BA would be like. I did get a chance to go back to Triumph's Demo Days again (Saturday) in hopes of riding the BA, RIII Touring, or the Tiger. I had arrived late, so everything was booked except the Scrambler. I figured "what the heck" and rode the thing. What a kick in the pants! The Scrambler was a fun bike to ride. It also had the optional Arrow exhaust installed, so there was a nice "bark" to it. I'm glad I got a chance to experience it.
Page 2 of 3 1 2 3
