Re: carb problem
kennymc #322436 04/25/2009 6:29 PM
Kenny, I believe its either a sticky slide or a sticky valve, this would also cause it to backfire, perhaps a bit of carbon on the valve seat, also recheck your clearances,Another possibility is the one of the tabs on the needle holder may be blocking the vacuum hole on the slide. hope this helps, cheers, Tadpole
Re: carb problem
tadpole #322437 05/08/2009 10:23 PM
kennymc Offline OP
Thanks for the help guys but no luck problem did not go away.
I have learned to take my carbs apart though so that's good.
Here's a question. which end of the needle jet goes into it's hole first?
Re: carb problem
kennymc #322438 05/08/2009 10:42 PM
The pointy end and the opposite side from where the thread is! Sorry
Re: carb problem
kennymc #322439 05/08/2009 10:53 PM
Seriously?
Re: carb problem
mrt202 #322440 05/09/2009 5:32 PM
kennymc Offline OP
the needle jet lives in the same hole that the main jet holder screws into, but it can go in two ways and only one is right. The manual warns about putting it in upside down but doesn't show which is which.
Re: carb problem
kennymc #322441 05/09/2009 8:43 PM
The pointed end goes down, towards the bowls.
Re: carb problem
mrt202 #322442 05/10/2009 3:14 AM
kennymc Offline OP
I am not talking about the needle. I am about the needle JET
Re: carb problem
kennymc #322443 05/10/2009 9:11 PM
kennymc Offline OP
ok, no help here.
Re: carb problem
kennymc #322444 05/10/2009 9:36 PM
Are you talking about the tiny piece on the chamber side of the jet collar? It's like 1/4" long? The more open side goes towards the chamber. Make sense?
Re: carb problem
roadworthy #322445 05/10/2009 11:34 PM
kennymc Offline OP
yes, that's what I wanted to know, that little piece according to the manual, is called the needle jet. it came out when I was cleaning the carb and I didn't know which way it goes back in. thanks.
