 Re: lowering rear
Posts: 175 |
will get pics tonight when i get home from school....also i had to remove the chain guard because of clearance issues..the front the chain guard will with the chain when you lower the back end that far....your options are either to remove it or trim out about 1" of chain guard on the transmission side
 Re: lowering rear
Posts: 175 |
 Re: lowering rear
Posts: 410 |
Your truly a STAR  thanks!! TrOjAn
TrOjAn
 Re: lowering rear
Posts: 520 |
made my own brakets for about $15 [image]http://www.facebook.com/photo.php?pid=30334993&l=4b683cae38&id=1423641952[/image]
 Re: lowering rear
Posts: 520 |
[image]http://www.facebook.com/photo.php?pid=30334994&l=cee29470ca&id=1423641952[/image]
 Re: lowering rear
Posts: 520 |
not real shur how to post pics here
 Re: lowering rear
Posts: 23,248 Likes: 64
Posts: 23,248 Likes: 64 |
Here ya go.
 Re: lowering rear
Posts: 3,210 |
I was thinking that bracket is going to be dealing with a lot of force and weight. Are sure that your bracket job will hold up? Its kind of the wrong time to find out when youre doing 65 and the ace end falls out from under you.
 Re: lowering rear
Posts: 531 |
I guess it's tried and tested but I feel more comfortable with my cut down springs than I would with the bracket.
 Re: lowering rear
Posts: 605 |
$hit that's all that is? I thought it was a solid piece of 1.5" steel. I guess I'll make my own with a piece of angle, a chop saw, and a drill press.
Aaron
04 "Green Bean" Freaked, AI removal, Bafflectomy, 6" Risers, and 30" Drag Bars.
 Re: lowering rear
Posts: 520 |
some 3/16 1 and a half inch steel angle, half inch grade 8 bolts, a cut off wheel, drill, rosebud grinder, and the most importent tool a SHARPE. I don't think the brackets gooing to break as long as there is no flex and u keep it tight and theres not a hole lot of side load on it its more trying to push down and back. I don't have any fear of it breaking and iam 270lbs
 Re: lowering rear
I thought it would have been channel with a sleeve welded in to go over the old shock mount. That also would mean the bottom of the shock would have been supported on both sides.
 Re: lowering rear
Posts: 605 |
I think you might actually be on to something though Ian. I like the channel idea better mainly for it's support on both sides. Just slip the shock between the channels and clamp her down. Honestly you don't need a sleeve welded in, just 2 holes. One on the inside big enough to slip over the old shock stud, and the outer one to clamp between the bolt and the stud. I like it.
Aaron
 Re: lowering rear
I was thinking the sleve so you could tighten it down and not crush anything.
 Re: lowering rear
Posts: 605 |
A sleeve to go into the shocks mount so you don't crush the shock's rubber. I see now, at first I was thinking the sleeve was going over the old mounting point which wouldn't crush anything. I'm seeing what you're seein now.
Aaron
 Re: lowering rear
I did mean over the old shock mount so you couldn't push the sides of the channel together. The shock should have an insert. The sleeve wouldn't need to be welded in just figured it would be easier than having the extra loose part.
 Re: lowering rear
Posts: 520 |
i couldn't find a spacer to fit right on the org shock mount i used a stack of washers iam going to get some spacers made later. if u use channle there won't be any support under it and the shock would just push it down
 Re: lowering rear
I was talking about using channel in the same position as the one pictured except it would have a piece behind the shock too.
 Re: lowering rear
Posts: 410 |
Damien, any chance of a photo from ABOVE? looking at that earlier photo I assume the shock lower mount is pushed out about 3/4" ?
CHeers, TrOjAn
TrOjAn
 Re: lowering rear
Posts: 605 |
For clarification here... a channel is a U shaped piece of steel. The idea Ian has come up with is twice the strength and support than the angle. You're angle is under constant twist strain, unlike the channel design.
Aaron
 Re: lowering rear
Posts: 520 |
ya i had to space out the bottom of the shock about 1/2inch to clear the brake caliper
 Re: lowering rear
Posts: 605 |
oh that sucks. I didn't even think about the other side. I thinking it would be nice to have a cutting torch, and a mig. Just cut the studs off the old position and weld them on a little further back. Repowdercoat, and away we go.
Aaron
 Re: lowering rear
Posts: 5,616 |
So...did Streetboogie ever have a problem with their set up? Ive never heard of it.
Your ideas all make sense and are good BUT you might just be overthinking/overengineering this.
NEW: 19 Goldwing Tour DCT
 Re: lowering rear
Posts: 605 |
 OVERENGINEERING No that can't be us.
Aaron
 Re: lowering rear
That was exactly my thinking, thank you for explaining better than I did.
 Re: lowering rear
Posts: 5,616 |
I havent shared my idea for a chaingaurd mod for that reason... I know when my OCDADD kicks in.
 Re: lowering rear
Posts: 90 |
Once I finish college and can afford toys again, I'll be going for new progressives, they are 100% better then stock and you can get them in any shape or style. Plus in my opinion (which may or may not be shared) is cheap mods look cheap, but that doesn't mean go out and spend thousands of dollars just to look good.
Dormaar
 Re: lowering rear
Cheap mods done cheaply I agree but I do my own inexpensive things that are done with care, like my oil pressure gauge that I really love but didn't cost much.
 Re: lowering rear
Posts: 605 |
Now onto the front forks. I'd like to keep the bike level so I'd need to lower the front about an inch or two. So I haven't dug into the forks yet, but I'm hoping there's a spacer in there I can just remove or cut down. Is there one? My dirtbike has the spacers, but I didn't remove them, I need all the travel I can get with those.
Aaron
 Re: lowering rear
There is but it isn't a good way to lower the bike. You lose the preload. I did it with Wendy's and ended up putting it back. There is a kit out there to lower the front the right way by changing the lower guts.
 Re: lowering rear
Posts: 3,210 |
Im with blackbird, I'd rather ride on my cut springs than mess with some wierd bracketing to change the angle.
And thats another thing, youre changing the shock angle...Which means the force isnt being fully put on the exact top and bottom of the shock. The swingarm is pressing the shock more sideways instead of "end to end"
I wouldnt be surpised if the shock piston got kinked a bit with the right kind of bump.
 Re: lowering rear
I agree with cut springs Vs the lowering block, I've said that before. But that being said I would rather a shorter shock that has full travel over the cut springs.
 Re: lowering rear
Posts: 520 |
i should finish my tank this weekend and i'll test the blocks to see if they hold up i have no dought that there going to be fine iam 270lbs i'll ramp so railroad tracks or somthing and see what happens lol
 Re: lowering rear
Posts: 3,210 |
Oh I'd definately prefer shorter shocks to cut ones...I was talking between "rigged pile A" & "rigged pile B"
 Re: lowering rear
Posts: 3,210 |
Make sure you pick up all those washers..haha
 Re: lowering rear
Posts: 520 |
got the bike done yesterday drove it to work today rides good didn't loose my washers lol it droped it 3 inches with me on it looks good will post pics
 Re: lowering rear
Posts: 175 |
 Re: lowering rear
Posts: 198 |
That is one slick lookin ride!
 Re: lowering rear
Posts: 520 |
getting the cold air kit for my bike in a few weeks
 Re: lowering rear
Posts: 520 |
took the wife for a ride last night didn't have any problems didn't loose any washers lol we hit a real hard dip and the tire bumped the fender but other then that i didn't have any problems
