Air Filter Mods
#314004 02/07/2009 8:09 PM
PDS85 Offline OP
I'm changing my air filters this spring. I have stock but not sure what to put on. I've heard mixed reviews of the freak kits. I also remeber seeing pics of bikes on here with velocity stocks dual filters. Those are what i think i want. Anyone have any thoughts or pics of these preferably the velocity stacks. I've seen them made out of pvc elbows.
BOHICA
Re: Air Filter Mods
PDS85 #314005 02/08/2009 2:09 PM
I wouldn't go with straight velocity stacks. It isn't worth taking the chance with the engine internals drawing in unfilted air. Purchase the Freak or alternate high performance systems that will support the carbs with the air box removed and give a substantial boost in performance maintaining the integrity of your engine.
Re: Air Filter Mods
Gregger #314006 02/08/2009 2:33 PM
Are you looking for something like this? This bike is davespain's. Maybe you can send him a pm for more info. If you just want to go with the dual filters, the pod filter part numbers are: LEFT side RC-2890 and Right Side RC-2900.
The airbox removal kit from newspeedmaster or british customs are only needed if you want to keep the chrome side covers. Or you can cut out you stock air box to fit the pod filters and keep the stock mounting points. Search for "ghetto freak" if you want to go that way.
Re: Air Filter Mods
roadworthy #314007 02/08/2009 4:00 PM
Here is a set of filters (both sides) on ebay right now for a good price, they are over 40 bucks a piece if you order them from AutoZone or wherever.
http://cgi.ebay.com/ebaymotors/Triumph-S...es#ht_562wt_950
Re: Air Filter Mods
PDS85 #314008 02/08/2009 10:15 PM
Just remember, you gotta match your inflow with your outgo. To get the benefit of increased air intake, you need pipes and jets to match.
It's only money....
More flags More fun!
Re: Air Filter Mods
Deon #314009 02/08/2009 11:39 PM
PDS85 Offline OP
roadworthy... those are exactly what i'm looking for. thanks for the info all. I'm going to pm him and see if i can get some pics and build info. I went from stock to TOR's and now jc whitney 32" turnouts. I'm sticking with the turnouts. I'v rejetted both times but I'm still missing the right intake system.
BOHICA
Re: Air Filter Mods
PDS85 #314010 02/08/2009 11:44 PM
You will still have to re-jet again with the K&N's. In the classifieds, there is a jet bank thread, you might be able to get what you need there. In the tech vault is the jetting calculator, should be in the intake/carbs thread. Post pics when done!
Re: Air Filter Mods
roadworthy #314011 02/08/2009 11:48 PM
PDS85 Offline OP
Ya I used that calculator the other time. thanks for the bank info. I forget where i got them before. I'll post them, but this won't happen over night. I somtimes get distracted
BOHICA
Re: Air Filter Mods
PDS85 #314012 02/08/2009 11:50 PM
PDS85 Offline OP
the forum doesn't recognize davespains in the forum. does he have another name?
BOHICA
Re: Air Filter Mods
PDS85 #314013 02/08/2009 11:51 PM
PDS85 Offline OP
i got it...davespain
BOHICA
Re: Air Filter Mods
PDS85 #314014 02/08/2009 11:52 PM
Re: Air Filter Mods
roadworthy #314015 02/09/2009 8:49 PM
Hey Brian, Those turn outs i got from Lowe's the are 1 1/2 abs (3 or 4 bucks for both)
I bought a (i think)1 3/4 radiator hose most expensive part from auto parts store and used that to couple the turn out to the carb and the original rubber couples the turn out to the filter, all are fastened with stainless radiator hose clamps...piece of cake to put together.
They dont really get in my way , my right leg touches slightly but with a shorter person it might be worse, Really for the $ and little time it takes to do this its worth a try.
The may be some better shots of it here http://s317.photobucket.com/albums/mm381/shockhappens/
good luck
Re: Air Filter Mods
davespain #314016 02/09/2009 9:52 PM
PDS85 Offline OP
Just so I'm clear, the radiator hose bridges the elbow and the carb(the elbow doesn't fit into or over the carb). and you would use a total of three clamps per side. And there aren't any other mounting points other than the hose clamps. Would these be labeled "velocity stacks" for the rejetting calculator?
BOHICA
Re: Air Filter Mods
PDS85 #314017 02/09/2009 11:51 PM
One website you may want to look at is Mikesxs.com. They have their own version of the K&N filter. According to their tests they get better filtration and airflow compared to the K&N. And @ $16.00 a piece definately a good price difference. I plan on trying these this spring. I was told that the 54mm would fit our carbs(dont hold me to that, anyone out there ever measure the carb openings???)
Jack
Filters
02 Black America---Don't blame me cause the black ones are the fastest, its gods doing!!! http://s279.photobucket.com/albums/kk146/jwoyshnar/
Re: Air Filter Mods
PDS85 #314018 02/10/2009 2:33 AM
These are velocity stacks. No filter. Some have a screen but still lets lots of dirt pass into the engine.
Re: Air Filter Mods
Deon #314019 02/23/2009 1:39 PM
Those are some great shots of your bike Dave. Im guessing you had to fabricate something to support the carbs from the back, right?
Sometimes you get the bar, sometimes the bar gets you.
Re: Air Filter Mods
DuckOner #314020 02/23/2009 9:17 PM
Thanks Duck,
Yea its just like the one that came with the Freak kit....small flat piece of aluminum with a rounded notch on the carb side (fits on that cross over tube that goes in between the carbs) and bolted to the frame and painted black.
You can hardly even notice it
Re: Air Filter Mods
PDS85 #314021 02/24/2009 12:15 AM
How do those turnouts sound compared to TORS? Have you removed the internal baffle? I've been tempted to try a pair, but don't trust JCW quality so much these days.
Re: Air Filter Mods
Lazyrider #314022 02/24/2009 8:27 AM
Was the JC Whitney quality ever good??? I remember as a 16 year old with my first car buying parts and getting the stuff and not being happy with it.
Re: Air Filter Mods
JackW #314023 02/24/2009 1:28 PM
Awsome man, I'd really like to try something like that. I really want to get rid of the airbox, but imho that is so much more badayce then the freak.
Re: Air Filter Mods
DuckOner #314024 02/24/2009 5:18 PM
I don't deal with Whitney anymore. When I was a kid they took my $300 and I never got my parts. I was not quite old enough to drive yet so that $300 was a whole lot of money to me. I wrote several times explaining that very thing and they never even bother to reply. This is back when they went bankrupt and the restructured.
Re: Air Filter Mods
The_Dog33 #314025 02/24/2009 8:36 PM
I got my turnouts from someone here... I thought they said they were Krome Werks or something and if im not mistaken, new they wernt more than 50 or 60 bucks new.
I have never actually heard TORS before but I really like the way the turn outs sound (they are loud though) but me likes loud!
Re: Air Filter Mods
davespain #314026 02/25/2009 2:53 AM
Sorry to hear about that, Dog. I had a not-so-good experience with them last year, but nothing like that. Think I'll pass on the pipes.
Re: Air Filter Mods
The_Dog33 #314027 02/25/2009 6:20 PM
I've had no problems with JCW or Steadfast. I've made a half dozen transactions with both over the last two years.
Now, as for that BIT_H from Chicago,...
Re: Air Filter Mods
erle #314028 02/26/2009 8:38 AM
Hey Dave, on your photobucket page i see your battery mount. Did you order that, have someone make it, or make it yourself?
Re: Air Filter Mods
DuckOner #314029 02/26/2009 9:06 AM
you have to make it, I used the stock batt box and mounted it to a piece of flat aluminum that i put a few bends in it painted it and then mounted that to the bike.
Easy really...someone here has drawings(plans)of it, i cant remember who it was. Maybe do a search on it, ill see if i can find what i went by
Re: Air Filter Mods
davespain #314030 02/26/2009 5:13 PM
excellent man. I might go a different route, but I'd hate to get 90% done and have no where to stick my battery, and no plan B. haha.
Re: Air Filter Mods
DuckOner #314031 02/26/2009 6:05 PM
yo ryan, landfills in jerzey where? Im from the Goucester county landfills down south
Anyway, I was the one that made the diagram and heres some pics of the way I made my bracket. Feel free to ask me any questions
Re: Air Filter Mods
brokenfixed #314032 02/26/2009 7:53 PM
Haha, was born and raised in hudson county, Kearny actually.
Im over in Belleville now, Essex. That really looks pretty simple. Your removing 2 peices off the original bracket, and attaching the 2 new mounts, right? How is it with mud and dirt up in there? That blocks enough of it?
Re: Air Filter Mods
brokenfixed #314033 02/26/2009 8:17 PM
Hey, BF, really sweet battery box, clean and still accessible.
Re: Air Filter Mods
Dinqua #314034 02/26/2009 10:56 PM
Good drawing, brokenfixed. That does look pretty easy and I love that look when you can see through. Wish I could see a side view of your bike there.
Re: Air Filter Mods
DuckOner #314035 02/27/2009 9:16 AM
Essex?....we're gonna have to ride one of these days. I PM you when it gets a bit warmer out.
Anyway, I rode with it for a year (about 3000 miles) before I took it off to paint it black. When I took it down I barely had any grime at all. I just wiped it off with a papertowel and spraypainted it. If you think about it, the way the tire is moving it releases dirt downward at the top of the battery bracket, not really the bottom part. Ive gotten caught in some really bad rainstorms and never had a problem either. Some guys on here added a fender piece to the lower part, but I personally think its not needed and takes away from the barebones idea. I think its been about 2 years now since I first installed it and about 7000 miles.
Re: Air Filter Mods
Dinqua #314036 02/27/2009 9:17 AM
Thanks alot Dinqua, it means alot coming from you.
Re: Air Filter Mods
DunnSpeed #314037 02/27/2009 9:26 AM
Thanks I drew that in CAD really fast. I work as a draftsman for an engineering firm.
Heres a couple more shots for you some old before I painted it, some new etc.
This one was more of a picture of the little toolbox I mounted to the license plate bracket, but you can see some of it.
Re: Air Filter Mods
brokenfixed #314038 02/27/2009 10:44 AM
nice looking bike man. I dig the header wraps and the fat white wall in the back.
Re: Air Filter Mods
DuckOner #314039 02/27/2009 11:37 AM
thanks alot man
Re: Air Filter Mods
DuckOner #314040 03/08/2009 10:37 PM
PDS85 Offline OP
Dave, is there any way you could add a pic on here of that bracket that holds up the rear of the carbs? Thats the only thing i'm really concerned about. As far as how the pipes sound, the turnouts sound much louder and look better in my opinion than the tors. When i bought the tor's i seen that they wern't drilled out all the way. and when i put them on they wern't as loud as i had hoped. these turnouts have one baffle in them and sound great. I'll buy another pair soon because the ones i bought were off ebay and sorta scuffed up.
BOHICA
Re: Air Filter Mods
PDS85 #314041 03/09/2009 1:13 PM
A quick and cheap solution is to use a small turnbuckle. If you look in this picture.....
you'll see a small nut and bolt thru the upper engine mount holding the turnbuckle at the one end. And the other end hooks on the back of the interconnecting carb posts.
Re: Air Filter Mods
brokenfixed #314042 03/09/2009 4:20 PM
The guy shootin' that photo has a really small head.
Re: Air Filter Mods
Lazyrider #314043 03/09/2009 4:33 PM
Dang if he don't!, no neck either.
