Re: HOW TO - make a laydown lic plate for under $1
FriarJohn #312227 06/03/2009 2:39 AM
Good question, well spotted,
I didnt want to put tabs on to screw the plate into so plate is stuck on with those double sided pads. Wont move and pretty easy to remove when I need to get at wiring. Keeps it clean as well.
Cheers
Chris
oldgimmer #312228 06/03/2009 8:41 AM
double sided tape? You better tie a piece of fishing string on there just in case, cause youre gonna lose that at higher speeds I bet.
brokenfixed #312229 06/06/2009 4:17 AM
Done a few quickish runs with the plate on, its still there.
I used specialist automotive pads that are designed for vehicle number plates. They seem pretty strong and if you've ever tried to get one off they are a bugger.
Got some good comments too.
Cheers
Chris
Re: HOW TO - make a laydown lic plate for under $10
oldgimmer #312230 06/08/2009 12:21 PM
nice job,is that the standard size number plate for UK?
live fast,ride faster
oldgimmer #312231 06/08/2009 12:49 PM
Cheers
Chris
i guess time will tell then. Theres a difference in sticking a plate on a car vs. a motorcycle though. The winds from driving forward are pushing on all sides or your plate. On a car the back of the plate is flush and shielded from the wind. The weather in the UK doesnt help either.
scuba_speed #312232 06/10/2009 1:57 PM
Its not illegal its just not the legal size required.
Keep them guessing,
as long as it can be seen and read from a reasonable distance they seem to be fine. The main problem is the ones that the numbers and letters are missrepresented or done in a stupid italic script that can't be read.
Not been done yet, but might be if it falls off, see above.
Cheers
Chris
Zmilin #312233 06/16/2009 11:00 PM
I used these stems from JP cycle:
part # 3200520
$8.99 for a set
The long end threads into the OEM turn signal housing. It needs to be cut down cause its too long and interferes with the bulb socket.
I also used a thin nut, lock washer and red loctite on it as well.
How did you attach these to the bike ?
Jimmy Stonefish
Jimmy_Stonefish #312234 06/16/2009 11:21 PM
Zmilin Offline OP
Jimmy,
I didnt...they attatch to a flange on the backing plate I made for Karens bike.
You can see it in this pic:
Zmilin #312235 06/16/2009 11:58 PM
Thanks Mate.
I couldn't see properly in the earlier photo, but these photos are excellent.
Fantastic design.
Cheers, Jimmy.
Jimmy Stonefish
