 Re: HOW TO - make a laydown lic plate for under $1
Posts: 311 |
Good question, well spotted,  I didnt want to put tabs on to screw the plate into so plate is stuck on with those double sided pads. Wont move and pretty easy to remove when I need to get at wiring. Keeps it clean as well. Cheers Chris
All the best
Chris
Do it today - tommorrow it may be illegal.
Posts: 3,210 |
double sided tape? You better tie a piece of fishing string on there just in case, cause youre gonna lose that at higher speeds I bet.
Posts: 311 |
Done a few quickish runs with the plate on, its still there. I used specialist automotive pads that are designed for vehicle number plates. They seem pretty strong and if you've ever tried to get one off they are a bugger. Got some good comments too. Cheers Chris
All the best
Chris
 Re: HOW TO - make a laydown lic plate for under $10
Posts: 63 |
nice job,is that the standard size number plate for UK?
live fast,ride faster
Posts: 3,210 |
i guess time will tell then. Theres a difference in sticking a plate on a car vs. a motorcycle though. The winds from driving forward are pushing on all sides or your plate. On a car the back of the plate is flush and shielded from the wind. The weather in the UK doesnt help either.
Posts: 311 |
Its not illegal its just not the legal size required.  Keep them guessing,  as long as it can be seen and read from a reasonable distance they seem to be fine. The main problem is the ones that the numbers and letters are missrepresented or done in a stupid italic script that can't be read. Not been done yet, but might be if it falls off, see above.  Cheers Chris
All the best
Chris
Posts: 13 |
I used these stems from JP cycle: part # 3200520 $8.99 for a set
The long end threads into the OEM turn signal housing. It needs to be cut down cause its too long and interferes with the bulb socket. I also used a thin nut, lock washer and red loctite on it as well.
How did you attach these to the bike ?
Jimmy Stonefish
Posts: 5,616 |
Jimmy, I didnt...they attatch to a flange on the backing plate I made for Karens bike. You can see it in this pic:
NEW: 19 Goldwing Tour DCT
Posts: 13 |
Thanks Mate. I couldn't see properly in the earlier photo, but these photos are excellent. Fantastic design. Cheers, Jimmy.
Jimmy Stonefish
