America Plugs
#307766 01/06/2009 12:49 PM
rossUK Offline OP
Hi Guys. I have an 05 America and want to check the plugs. As I am not that technically minded can anyone help? What size socket do I need, can I use a standard 'plug' spanner/spocket and what are those things next to the plugs? Other bikes I have had in the past didn't have these. What do they do and do I need them? Thanks in advance
Ross
Ross (05 black America) If at first you don't succeed, avoid skydiving.
Re: America Plugs
rossUK #307767 01/06/2009 1:04 PM
those things next to the plugs are the AI connections. If you remove them you will need to blank the holes off and also the one in the airbox.
I think you need a 12mm plug spanner.
Re: America Plugs
Monkey865 #307768 01/06/2009 1:50 PM
Ross , lots of info in "search" about the AI . Be careful tightening the plugs , the "feel" is an aquired skill , get a torque wrench . Look at the color to get an indication of what's going on with the mix . Dab some anti-sieze on the threads .
Re: America Plugs
Wade #307769 01/06/2009 4:33 PM
From the Tech Vault, tools section:
I know this baby fits like a glove. I have one and it's $3.99 at Sears. It's a nice thin walled sparkplug socket.
Craftsman 18mm Spark Plug Socket
Sears item #00943330000
Mfr. model #43330
direct link:
http://www.sears.com/sr/javasr/search.do...p;gobutton=find
Re: America Plugs
unclecharlie #307770 01/06/2009 9:23 PM
Take from Charlie above. Sears is the best place in the US to get one that fits well. A lot of regular 18mm sockets don't work too good. You might not can run down to a Sears and pick one up in the UK. Just make sure it is thin walled 18 mm.
Re: America Plugs
RamSound #307771 01/06/2009 9:51 PM
The credit goes to Ron(Fishercat).
The only time I pulled my plugs was for the valve adjust.
At 13,000 miles, they looked OK. A nice tan color.
Re: America Plugs
unclecharlie #307772 01/07/2009 12:21 AM
rossUK Offline OP
Thanks guys. The reason I want to check the plugs is I have trouble starting her in the cold. It takes at least 6 or 7 attempts to get her going so I just want to make sure the plugs are okay before I start looking further (or asking you lot for more advice lol).
Re: America Plugs
rossUK #307773 01/07/2009 6:38 AM
Are you using the choke? Are you twisting the throttle when using the choke (you shouldn't)?
Re: America Plugs
Monkey865 #307774 01/07/2009 12:11 PM
rossUK Offline OP
Yes I am using the choke. I do twist the throttle after the first few cranks otherwise it wont start. Once it does start it is very sluggish for a while. When you twist the throttle after it has started it doesn't rev as such, it sounds very flat.
Re: America Plugs
rossUK #307775 01/07/2009 3:25 PM
sounds like your pilot circuit may need adjustment, your bike should start without touching the throttle. Some people have blown up their air box buy twisting the throttle while starting.
Re: America Plugs
The_Dog33 #307776 01/08/2009 11:03 AM
rossUK Offline OP
What is a pilot circuit, and how do I adjust it?
Re: America Plugs
rossUK #307777 01/08/2009 11:41 AM
Have you tried using half choke?
Do you have stock pipes and air filter etc?
Re: America Plugs
Monkey865 #307778 01/09/2009 8:39 AM
rossUK Offline OP
Yes and yes.
Re: America Plugs
rossUK #307779 01/09/2009 9:53 AM
Ross make sure the idle adjust has not been set to low, you should not have to touch the throttle to start the bike.
Also take a look at the Dent thread, as we would love to see you there and you could chew our ears to death
Re: America Plugs
The_Dog33 #307780 01/09/2009 2:59 PM
buy IRIDIUM plugs they need lower current ..never had problems with them when cold
Re: America Plugs
Grzegorz #307781 01/09/2009 3:19 PM
Nor should you with conventional plugs...
Re: America Plugs
B02S4 #307782 01/09/2009 3:38 PM
I still have my stock plugs at 20,000 miles and have no issues. Bike starts right up with no throttle.
Try the idle first it should idle just over 1,000 RPM mile is right at 1,000. If that doesn't do it we can get into mixture adjustment.
Re: America Plugs
The_Dog33 #307783 01/09/2009 4:29 PM
cold I mean real cold few degree below freezing and my carbs are not heated
Re: America Plugs
Grzegorz #307784 01/09/2009 4:40 PM
I have stock heated carbs and I have started my bike well below freezing. If your carbs are not heated there is a possibility of carb ice from about 40ºF and below, don't need freezing temperatures to develop carb ice.
Re: America Plugs
rossUK #307785 01/09/2009 5:25 PM
The pilot circuit controls the fuel flow in the lower throttle range including idle. Typically the pilot jets are #42 for your bike in a stock setup. They shouldn't have to be changed unless you have modded the intake. The idle circuit is controlled by the idle jets (in conjunction with the pilots to a degree). These have a cover over them which will have to be removed before you can adjust. The screws themselves have a "D" shaped head which will require a home made tool or a special tool to adjust. http://www.newspeedmaster.com/html/d_tool.html My feeling is that these screws should be turned out a half turn each and see if that helps. Turning them out will richen the idle circuit.
Have you modded the bike at all? Has the bike always been this way on startup? If not, you could have some varnish buildup in the idle circuit. Try some Seafoam in the fuel to help remove it.
Re: America Plugs
Gregger #307786 01/09/2009 8:37 PM
rossUK Offline OP
OK, I have not made any mods to the bike. Triumph rebuilt the engine in August last year when a bit inside the casing that holds the starter gear shattered. Thye replaced the casing but I am not sure what else.
It looks like I need to adjust the idle (really sorry for being thick) how do i do this?
Re: America Plugs
rossUK #307787 01/09/2009 8:39 PM
there is an idle adjustment knob on the bottom of the left (as you sit on it) carb.... little black knob down there, that would be a good place to start
Re: America Plugs
roadworthy #307788 01/09/2009 8:49 PM
Don't ever worry about being thick.., I've had an America for nearly 4 years, and I've asked some really daft questions in my time. That's what this place is for.
Oh and I wondered how long it would take Ray to mention Dent... but if you can get there... it's a great way to learn.
Re: America Plugs
rossUK #307789 01/09/2009 10:46 PM
No such thing as being thick here.
There are two idle adjustments. One is your idle rpm the bike will run at. It is adjusted with a black knob on the left carb as already stated. If this is adjusted too low, the engine might stall on start up or when you come to an intersection until it is warm. Having the engine adjusted too slow won't cause it to feel flat on acceleration as you stated in a previous post. This is why I feel your engine is running too lean and the other idle adjustment screws which control the air fuel mixture of the idle circuit need to be richened.
You didn't state if your engine always had this condition or if it just happened after the engine rebuild.
Re: America Plugs
Gregger #307790 01/10/2009 5:45 AM
Re: America Plugs
birchr #307791 01/10/2009 9:42 AM
Thanks Ray.
That picture says it all. The black knob on the right is the idle speed adjuster and the two holes with the arrows pointing to them are the access points to the pilots/idle screws (idle mixture adjustment screws)
That pic should be in the carb tech vault.
Re: America Plugs
Gregger #307792 01/10/2009 5:47 PM
rossUK Offline OP
It has only happened since the rebuild.
A brief history. I bought the bike, new, in Spain and didn't even need choke for the first 18 months/2 years. The airbox blew up just before the warranty ran out and Triumph repaired it for me. I've always had it serviced, at a Triumph dealer until the warranty ran out then with a mate who had his own business. Last year, about March/April time the starter gear broke and I couldnt afford to fix it so I got onto Triumph (had a go about the bike being just out of warranty and shouldn't be breaking like this etc). They said if I could get it back to the UK they'd take a look at it. So I got a guy to bring it back in a van, Triumph looked at it and fixed it for nothing. Since then, in the cold, it has trouble starting and when it starts there is no power when you twist the throttle, it goes kinda flat, until it warms up a bit. I have trouble with it cutting out in the wet too. Even in Spain, if it rained, it would cough and splutter. Triumphed looked into that but couldn't find anything. Every electrical connection I can find is now covered in grease and, fingers crossed, it hasn't happened for a while.
Right, I think thats about it. Sorry to waffle and thanks for all the advice so far.
Re: America Plugs
Gregger #307793 01/10/2009 5:49 PM
rossUK Offline OP
Thanks Ray.
Right, so what do I have to do to the idle adjustment mixture screws then?
Re: America Plugs
rossUK #307794 01/10/2009 7:22 PM
disconnect the left plug wire and adjust the right carb. Have to turn the idle up so the engine will run on 1 cyl. but not so far that the engine isn't idling on the pilot. turn that screw in until the engine runs rough then back out until it runs rough. Your setting is half way between those 2 points. Repeat for the other cyl. Wouldn't hurt to balance them while you are at it.
Re: America Plugs
rossUK #307795 01/10/2009 7:24 PM
checout the Tech vault Ross"HERE" You will also need one of these, I borrowed one from one of the guys on here. Sorry cannot remember who now...
Better still turn up at DENT and get one of the guys to sort it for you..
Re: America Plugs
birchr #307796 01/10/2009 7:32 PM
There are a couple ways around the D tool. One is to flatten 1 side of a piece of appropriate size break line, instant D tool. The other is to carefully remove the screw with small needle nose pliers or hemostats. Careful not to lose the spring, washer, or O-ring. Then carefully cut a screwdriver slot in them and reinstall. The last is to buy the thumbscrew pilot screws, Bella Corse has them , not sure if Eddy does or not.
Re: America Plugs
The_Dog33 #307797 01/10/2009 7:41 PM
Ross I would suggest you buy at least the Haynes manual either off eBay or from local shop... This will give you an idea and step by step instructions of how to
Triumph manual on ebay
Haynes manual on eBay
Re: America Plugs
birchr #307798 01/10/2009 11:20 PM
+1 on the thumbscrews. I got mine from Brent at BonnivilleAmerica.com. They made it very easy for me to tweak and find the best setting for the bike. I also bought a manometer to balance the carbs. I check them at idle and at a little above 3K where vibration used to be noticeable. My bike has never run better than now after 3.5 years and 15000 miles.
I also agree you should have a shop manual. At least the Haynes which is loaded with info. I have both the Haynes and the Triumph shop manual.
Re: America Plugs
RamSound #307799 01/14/2009 2:53 PM
rossUK Offline OP
Right! I spoke to the Triumph mechanic today (after breaking down in the wet again, see thread in the lounge (Good Grief!). He said both the starting and the cutting out in the wet thing are caused by the coils getting wet. He suggested cleaning the connections up on the coils and coating them in silicone sealant. Am gonna have a go at this tomorrow I think.
And does anyone know where I can get a d tool for the carbs and an 18 mm thin walled spark plug socket in the UK? I have searched for ages and can't find them anywhere in the UK.
Re: America Plugs
rossUK #307800 01/14/2009 4:37 PM
Hiya, Ross. Welcome. What's the score with your bike? Are you keeping it/selling it? Is is now ally/plastic/rubber/steel ingots buried in a peat bog somewhere?!!!
Regarding the plug socket, I had trouble finding one, too. I finally got mine from Partco. There's no brand name on it but there is a code: TMTWPS1116
It's an 18mm magnetic plug socket. Cost about £7.
You'll need to remove the tank each time you want to check the plugs if you still have the AI in. If you intend to keep the bike, it might be as well to remove the AI system; it's not a huge job. Do a search in these forums for details.
Regarding the D-tool, if you obtain a short piece of thin copper pipe and flatten one edge, you'll have your D-tool.
Once you've cleaned your coil connections, it might be as well to cover them with a plastic bag, bicycle inner-tube or something. Even if it's only temporary, if it runs OK in that time, you'll know it is water ingress and you can take appropriate action.
Let us know what's happening.
Neill
Re: America Plugs
Echoance #307801 01/15/2009 9:10 AM
I use the one off my Honda CB Seven Fifty(96) fits perfectly for the spark plugs, don't even have to take the tank off to undo them
Re: America Plugs
birchr #307802 01/15/2009 9:58 AM
rossUK Offline OP
Right. Today I decided to take the tank off and check/clean/grease the coil connections. Took out the bolt holding the rear seat on, and when I took the rear seat off, the clip holding it to the front seat bolt was still on the bike! The two posts holding the clip to the rear seat had cracked. Broken in half! I tell you, I must have been a complete b*st*rd in a previous life. Nothing ever goes right... ever! Anyway, I greased ujp every electrical connection I could find. Covered the coils in a bag (there wasn't anything obvious wrong with them by the way, no corrosion or damage to the connecions) and taped it all up. Taped a bag around the bits uncovered by the stolen side panel until I can get a new one.
OK, seriously, if anyone wants to buy a used, 05, black America in need of a little TLC, send me a PM with an offer!
Re: America Plugs
rossUK #307803 01/15/2009 11:01 AM
Nah, it's not you.... just the previous owner was a git and you are just the innocent next owner...
Re: America Plugs
birchr #307804 01/15/2009 11:05 AM
Can't wait for fuel injection.
Re: America Plugs
rossUK #307805 01/15/2009 11:07 AM
"Covered the coils in a bag"
beware condensation
