Lighter Carb Springs
#294275 09/25/2008 10:22 AM
piper1 Offline OP
Fitted and tried out a pair of Kawasaki gpz900 carb vacuum springs. Same diamater as ours, but lighter and a little shorter. Result - much better throttle response. Maybe this mod is compatible with enlargening the vacuum hole in the slide, but I haven't had the guts to drill that hole yet...
(Mods - maybe something for the Tech Vault? # 92081-1760)
Re: Lighter Carb Springs
piper1 #294276 09/25/2008 10:30 AM
This is an old trick for this type carb. We used to cut the stock spring shorter for a similar result.
You might as well drill the slide if you have the older bike with the smaller hole since later bikes actually come with the larger hole. All you are doing is drilling it to that larger stock size.
The_Dog33 #294277 09/25/2008 6:25 PM
I agree with Ian, if you can change the springs, you can drill the slide. Its very easy to do, with pics from the tech vault.
piper1 #294278 09/26/2008 7:16 PM
OK, I remember hearing that there are other springs out there that are lighter than ours that will work. Was it from a Yamaha? or something else. I would like to try this mod as well, should be a cheap mod. Year of the GPZ 900 springs that you used will work too.
69tri1 #294279 09/27/2008 1:17 AM
piper1 Offline OP
The # is 92081-1760. Hope this helps.
piper1 #294280 09/27/2008 8:04 AM
Thanks, I will give it a try.
69tri1 #294281 09/28/2008 9:31 PM
I am going to try them out, too
roadworthy #294282 11/05/2008 7:06 PM
So I finally got my carb springs installed today.... wow, what a difference! The throttle response is much, much quicker now, even when I just blip the throttle. I think they cost about 30 bucks from the Kawasaki dealer. For me, worth the price.
roadworthy #294283 11/05/2008 8:44 PM
I can see where this is going. 904 kit, lighter carb springs, louder exhaust.... Whatta ya got in mind, Dave?
arstaren #294284 11/05/2008 8:55 PM
I'm trying to hit the "H" on the speedometer.... go look at it and you'll know what I mean
roadworthy #294285 11/05/2008 9:02 PM
So, when did you start looking at your speedometer? After our last ride, I didn't think you cared!
arstaren #294286 11/05/2008 9:06 PM
Dude! You talk as if I have some sort of disregard for posted speed limits on the interstate!
Actually, I do use them as a sort of "guideline", if you will.
roadworthy #294287 11/05/2008 9:29 PM
Yep
arstaren #294288 11/05/2008 9:34 PM
I've been looking at those Tour Tanks, to maybe be able to go faster even longer
http://tourtank.com/tourtanks.html
roadworthy #294289 11/05/2008 9:42 PM
Wow! A 7 gal reserve tank?!! My poor, old bum would never recover!
arstaren #294290 11/05/2008 10:00 PM
Yeah, I think 3 gallons would be just about right. 250-300 miles at a time would be long enough.
roadworthy #294291 11/06/2008 1:36 AM
piper1 Offline OP
Yup. Same here. Easy, cheap mod with great results.
piper1 #294292 11/06/2008 10:10 AM
This is why I love this site. Great inexpensive performance tips which make our bikes run better. Anyone out there cut down the stock spring and if so by how much and how did it work out? Love the idea of making simple mods to improve these bikes. Right now running a drilled airbox, Uni filter, short TORs, #125 main jets and TBS needles on a 2007 America.
roadworthy #294293 11/06/2008 11:20 AM
That gives me an idea. Now, I know it's kinda off the wall, but hear me out. What if we use carbs that have the throttle linkage connected directly to the slides? Would that work? Then you could get rid of the springs entirely. Danm, I'm smart. Think I'll patent that...
Lazyrider #294294 11/06/2008 11:41 AM
buy keihin CR Special and you are done
Lazyrider #294295 11/06/2008 2:12 PM
[quote... Think I'll patent that...
You outta throw a smiley or two in there, as others might think you're serious...
gilligan #294296 11/06/2008 8:16 PM
There is a fine line on this that could cause problems. On my Ninja the carb (Keihin) springs were too weak and the engine surged at a constant throttle position. Stretching them some at least temporarily fixed that but was annoying when it was happening. Old Triumph mechanic gave me that hint.
Lazyrider #294297 11/06/2008 10:33 PM
The easy answer is yes and it has been done. I have been toying with using a set of Amal carbs I have from a Norton 850 Commando. I restored the Norton for a customer and ity only had 6,000 original miles on it. was a sweet bike but had been sitting for 20+ years and everything was gummed up.
The_Dog33 #294298 11/06/2008 11:29 PM
... The easy answer is yes and it has been done...
Old school. That used to be the norm.
piper1 #294299 11/06/2008 11:36 PM
...Easy, cheap mod with great results...
How does it hold a steady cruise in the 2-3k range in 2nd gear?
My personal opinion is the stock springs are too stiff, yet I have to wonder if a stock cut-down spring or a lighter rate replacement is the way to go with the stock CVK's.
Cut springs still have the same basic spring rate, & lighter replacements may be too light for a steady cruise.
Those Mik 42's may be on my agenda at some point.
B02S4 #294300 11/06/2008 11:47 PM
I noticed no ill-affects on the highway, I don't spend a lot of time in the 2-3k range in 2nd gear
roadworthy #294301 11/07/2008 8:35 AM
...I don't spend a lot of time in the 2-3k range in 2nd gear
Understood, & most of us wouldn't either, however if there is an issue with light springs it would likely be detected in that situation.
B02S4 #294302 11/07/2008 11:40 AM
Good points gentlemen. Surging at steady throttle would not be good. Sounds like no one has had that issue with the Kawi springs so far. But in the interest of cheapness, cuting the stock spring would be free, so I'm wondering if anyone has done it and how much did they cut off and how did it work out? Anyone?
gilligan #294303 11/07/2008 12:23 PM
I wonder if it would make the mixture too rich at mid throttle. My thinking is the lighter spring will allow the slide open a little farther at any given throttle position where the slide is in play thus acting as if there was a slightly larger jet due to the needle being open farther.
The_Dog33 #294304 11/07/2008 2:27 PM
I don't see how that could make it richer. At the same time the needle is pulled up, the slide is opening to allow more air. Seems to me that the possibility of surging (or total loss of control) is the only downside.
Lazyrider #294305 11/07/2008 2:30 PM
OK, now I have another idea. One could lighten the spring to the point where throttle response is virtually instantaneous. It'll surge like crazy. The solution is to attach a miniature hydraulic dampener to the slide. Danm, I'm smart. Think I'll patent that.
Lazyrider #294306 11/07/2008 3:55 PM
...The solution is to attach a miniature hydraulic dampener to the Danm, I'm smart. Think I'll patent that.
Given that a "dampener" makes things wet, why would you want to do that?
Lazyrider #294307 11/07/2008 4:42 PM
Because the slide and needle could be open at a slower RPM given that less vacuum is needed to open them thus supplying more A/F than required for that given RPM.
The_Dog33 #294308 11/07/2008 4:54 PM
How about as soon as I get my valves adjusted (very soon), I go get another dyno run and post my air/fuel mix for everyone to judge for themselves.
roadworthy #294309 11/07/2008 5:09 PM
sounds good, I wasn't saying this was the case, just a thought. I have never personally played with carb springs since I have always had cable operated slides until this bike.
The_Dog33 #294310 11/07/2008 5:31 PM
yeah, I just can't afford those nice 42mm mikuni's right yet, so this makes for a decent compromise
The_Dog33 #294311 11/07/2008 6:27 PM
Ah, I see what you mean. Still, I think a case could be made for just the oposite effect. If the slide opens early, air velocity might not be sufficient to pull the additional fuel needed to maintain proper mix from the metering circuit. In that case, it would run lean. It will be interesting to see the dyno results on this mod.
Lazyrider #294312 11/08/2008 8:51 AM
...I think a case could be made for just the oposite effect. If the slide opens early, air velocity might not be sufficient to pull the additional fuel needed to maintain proper mix from the metering circuit. In that case, it would run lean...
Jack, I don't follow that logic. The only place this should even be a concern is on low speed transition, in which case the elevated slide/needle theoretically caused by a too-light spring could induce a transient rich condition. And that is just theoretical. Presuming the Kawi lighter springs maintain sufficent tension then it won't matter, or it won't matter enough to be of concern. I doubt that a dyno run with this mod is going to reveal anything remarkable regarding A/F, provided the springs have enough rate in them.
roadworthy #294313 11/08/2008 1:20 PM
Bucky , f.k.a. Martin, has one of these big tanks, used to be on his America. Drop him a PM maybe he still has it and would give you a deal if he wants to sell it.
Dinqua #294314 11/09/2008 1:33 PM
I ordered the Kawi springs, stay tuned.
