Re: fat front tyre
bast_uk #287054 09/09/2009 8:02 PM
I was wondering if anyone has had any luck finding 130/70-18 in a wide White Wall?
http://www.motoxoutlet.com/index.asp?PageAction=VIEWPROD&ProdID=606
'02 TBA w/ '03 motor, D&D exhaust,gangster WW.. Bonnie rides again..
Re: fat front tyre
Gratfultim #287055 11/06/2009 10:28 AM
Why does metzeler have the ME 880 in a Bias and a Radial? Also the shop I do buiness with can only get the bias tire is this a big deal I very confused.
Re: fat front tyre
chuckyj #287056 11/11/2009 9:35 PM
IF you are going to run a radial run both as radials.If bias tire run both.
Re: fat front tyre
Speedblue #287057 11/11/2009 10:50 PM
Thats what I thought but I think factory tires are byis back and radial font any way.
Re: fat front tyre
Gratfultim #287058 11/12/2009 11:41 PM
As far as I know there is now only one www tire for our bikes, and it's a Dunlop K177 120/90-18. Don't quote me on that but I think this may be true.
Re: fat front tyre
roadworthy #287059 06/18/2012 9:51 PM
I need to do the same or raise it up some. I am thinking raise it, I liked the look when i had it real close but if gravel or something tore through there it sounded like the fender and tyre was being tore to shreds. Has any one had luck manufacturing risers for the front fender?
I have a 120/90 on mine, had to trim out the center of the fender mounting bracket
Re: fat front tyre
Gratfultim #287060 06/24/2012 6:58 PM
I love my coker.
Re: fat front tyre
Gratfultim #287061 06/24/2012 9:19 PM
3/4 of the way down this thread ==> The Vault - How Tos. Keith has a very nice solution. I took a slightly less elegant route. 4 approximately 1.5 inch by 1/2 inch lengths of aluminum drilled with 2 holes and painted flat black to raise mine. I have the Dunlop K177 120/90-18 wide white wall.
Re: fat front tyre
The_Insane_Viking #287062 06/24/2012 9:56 PM
I managed to fit a 130/90 with a combo of Keith s extenders and some hillbilly surgery. [image][/image]
Re: fat front tyre
Ryk #287063 04/11/2013 10:38 AM
I'm a bit confused here. It seems to me that those of you who are using a 130/70-18, are putting a smaller diameter tire on your bike. No? As far as I know, the stock size is 110/90-18 on pre-2011 Americans. So the diameters are as follows:
110/90-18 is 65.5cm
130/70-18 is 63.9cm
Am I missing something here? Some of you have mentioned that the stock front tire size is 100/90-18, but I have not seen this in anything that I've read, nor is it the case on my bike.
I'm thinking 130/80-18 (66.5) will give a bit fatter look without too much profile height as does 120/90-18 with the rubbing issues.
Re: fat front tyre
Homerocks #287064 04/11/2013 10:47 AM
Different tire manufacturers as to the same numbers, equal different actual physical dimensions. Measure Circumferences with a flat tape meas. and you will find this out for yourself.
Re: fat front tyre
BrianT #287065 04/11/2013 11:33 AM
Anonymous
Unregistered
Anonymous
Unregistered
No mods needed? It looks like you did quite a bit of cutting to that front mudguard. But maybe you just did that for other reasons,just curious.
Re: fat front tyre
#287066 04/11/2013 6:04 PM
Who is the question directed at?
Re: fat front tyre
Ryk #287067 04/11/2013 7:14 PM
Anonymous
Unregistered
Anonymous
Unregistered
Brian T. as noted next to subject header in my post.
Re: fat front tyre
roadworthy #287068 04/23/2013 2:06 PM
I like the tire tread! What brand is it? How well does it handle when the roads are wet?
Re: fat front tyre
Edwin #287069 04/23/2013 2:39 PM
Last I looked, Fast Eddy sells those tires, he sold me one a couple of years ago.
