 Re: Adding some viking patterns
Posts: 7,643 |
Look forward to seeing the tank Sven
Posts: 5,068 Likes: 1
Posts: 5,068 Likes: 1 |
Two ravens? Search and read "The Twa Corbies" ( two ravens ) .
Posts: 112 |
Grim poem  I like Robert Herrick, think he was writing at the same time as this poet.
Metal head!
Posts: 112 |
In some days I will have the pleasure to present a bike that really looks GRIM!! If I would have used other collours, the viking theme might have been more obvious. Now I went for black and silver wish looks grim but not vikingish.
Two small things remain:
1. Should there be some rubber around the locking bolt for the tank, to soak up vibrations?? (if so...where the heck did that piece go, darn)
2. Does any one know where I shall take some off from the flush cap, not fitting my TBA 06. Is it about broadening it up, cutting down on the lenght or the diameter??
Metal head!
Posts: 435 |
Can't wait to see your pics when finished, I've been reading this thread and it looks like you have some cool peices on your bike!  Answers; 1. yes there is a rubber mount for the lower tank bolt, it is rectangle shape with a circular peice that pushes through the hole from the bottom. then a steel washer on top of that. Hope you find it! 2. If the flush gas cap doesn't fit your tank it is probably a harley item??? The only way to make it fit would be to cut the nylon thread section off both your new cap and your stck cap, and plastic weld the stock thread onto the new cap you have.
Posts: 112 |
Thank you for the info  The cap is not for a specific brand i think, its sold at "bonneville america.com". Iv heard about ppl tampering with them to make them fit... (but I cant find that thread).
Anyway, will make sure to fix some photoes soon. Thanks for encouraging me.
Metal head!
Posts: 638 |
LOVE the axes! what an original idea, that's something the guys at OCC would have done. Now I know nothing about leather but wouldn't it be ok to install the leather wet so it is already stretched?
Posts: 23,219 Likes: 61
Posts: 23,219 Likes: 61 |
It is an after market HD part it's right hand thread 83 or later XL,FXR,Dyna,Softail,or Roadking. Kuryakyn (sp*) part number 8309
Posts: 112 |
Kuryakun it is, thats right.
Managed to make it fit. (Also found the missing rubber part for the tank)
The only technical thing to fix before showing this machine ,is that digital cam of mine.
Metal head!
Posts: 112 |
Well, I was afraid that if I applied it stretched it would shrink later. Lether is a strong material, it might have damaged my bike if it was fixed to the metal with screws. Anyway, I have found a quite subtile looking solution, making it easy to remove the belt, and making it able to shrink and expand as it pleases it. Ill show you tomorrow (a picture says more then tousand words).
Metal head!
Posts: 112 |
Her´s the tool bag. Originally a a model of belt bags that I had custommade to the size of a toolbag.
Metal head!
Posts: 112 |
Heres the gem of the bike. Odins raven, Hugin and Munin, sitting in rain and lightning...
Metal head!
Posts: 112 |
This is a belt buckle with viking inspired patern. Sitting on the plate holding the battery.
Metal head!
Posts: 112 |
Fenderbib made by a lether belt (also from a viking inspired pattern). The belt end is held by a small lether braid that is fixed to two rubber plugs. I used toes to get rid of the two holes appearing when I removed the piece holding plate/turning signal. The new bullet turning signals can also be seen...
Metal head!
Posts: 112 |
The custom made low profiled seat!! A genuine viking pattern from an old church in norway (Urnes).
Metal head!
Posts: 112 |
Made the sprocket cover black and removed the "America" logo. (or rather, the airbrush artist did it). The axeplate is also visible. That piece got me inspired to have a viking theme...
Metal head!
Posts: 112 |
Hers the handles I made by braided lether band. The ignition is covered by a medallion called "brakteat". These were made of coins. Its a replica from a archeological finding. The pic is blurry, sorry. On the medallion is the Futhark, meaning the rune alphabet. It was associated wiht wisdom (just like Odin) and believed to give luck and protection. You press the medallion to start the bike... The end of the handle have "Tricorn bar ends" bought at tribal acessories.
Metal head!
Posts: 112 |
Here is another similar medallion. It is used to protect the key hole. It looks tilted, but it is held by a lether band so it can wobble a bit back and fort (less tearing on the fragile medallion). This pies is mostly in the way when you want to start the bike, hahaha. But I like the look so Im giong to keep it. I will take better pics of both medallions later, to show the cool pattern on them.
Metal head!
Posts: 112 |
I will make a proper photogallery like the rest of you once I have better pictures. Just one last pic I want to share now... (Arrrrh, one of the turning signals is more tilted then the other.... sigh!)
Metal head!
Posts: 10,729 Likes: 5
Posts: 10,729 Likes: 5 |
Very cool!! The tank turned out awesome, and the other pieces are great! Really like the axe heads and rear fender bib, but the tanks is just....wow!
Posts: 44 |
Awesome work Sven.
Agreed, the tank graphic is super cool.
'07 Speediesque America
Posts: 529 |
An absolute masterpiece Sven! I can easily see that you'll be an inspriation to anyone wanting to further customize his/her ride.
Posts: 1,012 |
Snyggt Sven!  Johann
Gooseman
Triumph Tiger 1050 Black
Ducati Multistrada 1200s
Posts: 12,877 |
Dude I LOVE the fender bib!! I think that's my fav part. The axe blades are pretty badass too!
Black & Silver '02
Too many mods to list
Not enough miles ridden
Posts: 112 |
Since its just a lether belt it was britty cheap to buy as well To prevent sand from comming between the lether and the fender (bad sandpaper effect by vibrations) I glued some rubber fringes under the belt. These fringes are used to prevent draft in windows. To prevent the tip from curling by rain and sun I glued a piece of thin metal under the last section.
Thank you all for nice comments.
Metal head!
Posts: 2,555 |
Now that is cool, Shows real imagination....
But man you guys need to do somthing about those barn door sized number plates.
The percentage you're paying is too high-priced
While you're living beyond all your means
And the man in the suit has just bought a new car
From the profit he's made on your dreams
Posts: 112 |
Yepp, Its on the to do list...
Metal head!
Posts: 4,518 Likes: 32
Posts: 4,518 Likes: 32 |
Superb theme, imagination and work. Congratulations!
Bedouin.
Blessed are those eyes that have seen more roads than any man! (Homer).
Posts: 5,616 |
Love the axe plates and coins! Nice job Sven!
NEW: 19 Goldwing Tour DCT
Posts: 3,960 |
I love that tank, fender bib and what a great idea with the grips, images of an axe handle come to mind. Great job Sven.
John
Like a dog on a car ride with my tongue in the wind
Posts: 15 |
Very nice! The tooled seat is gorgeous and I love the fender bib.
Posts: 112 |
Thanks for these words. Im mighty proud of my bike :-) I will pass on some comments to Linda Tolind who painted the tank. If any one like to see more of her works you can find it at her page: http://www.flickan.comIf any one would like to know where I found the stuff I put on the bike, mail me.
Metal head!
Excellent in every wayl! Striking imagination and execution of idea and detail. Kudos, Master Sven! That's one pretty ride.
