Re: Sheet metal bending?
Bucky #221008 12/03/2007 8:33 AM
would you still think they're cool if they were painted flat black?
Yep
I believe flat black would look better than silver.
Yeah definately flat black...they'd defiantely look nice recessed in the kneepad too...i'll have to get some kneepads.
Erwin #221009 12/03/2007 12:02 PM
Maybe Gloss Black to match your valve cover. Either way, black
Erwin
05 America
Erwin #221010 12/03/2007 1:25 PM
thats a thought, it'll contrast the flat black
brokenfixed #221011 12/03/2007 2:18 PM
Exactly. Just enough....
Erwin
05 America
Erwin #221012 12/03/2007 2:37 PM
yeah cause if you look closely at the painted dash I have its a matte with a slight gloss to it when compared to the tank paint, so the kneepads should set it off pretty decently.
brokenfixed #221013 12/03/2007 6:32 PM
Its gonna look pretty sharp
Erwin
05 America
Erwin #221014 02/29/2008 12:57 PM
Cut the tank, weld the plate in? Oh, a cheap mod.? Fair enough!!
brokenfixed #221015 02/29/2008 4:05 PM
An English wheel does wonders for compound curves. Takes a little practice, but not too bad to work with.
Greybeard #221016 03/01/2008 5:33 AM
Sorry, my fault. Didn't realise this was an oldish post.
What did you end up doing, Tom?
Echoance #221017 03/03/2008 9:03 AM
ahah...back from the dead
it ended up getting shelved because of the winter. I work in my backyard sitting on a cinderblock, and in the winter i dont have any daylight
see i think an english wheel would flatten/distort the diamondplate pattern. It seems like it wouldnt bend anything until the diamonds are flattened out enough for it to actually move back and forth.
The diamond plate would have to be steel to weld to the tank. It would be nice to take it to a custom shop and have it done right...but thats a decent amount of money for no reason. I think im gonna try the rubber kneepad fixation relation, and see how that "holds" get it?
brokenfixed #221018 03/05/2008 12:15 PM
A possible solution that could be used is an old jewellery technique using a pinch bowl that is bowl /box filled with a mixture of sand and tar which is heated with metal on top of the hardened tar this allows the metal and tar to soften. This allows the metal to be beaten and worked while supported. The Tar cools and hardens slowly which allows small changes within the metal to be made. You can beat out almost any shape imaginable using pinchbowl. Most of the old silversmiths and goldsmiths used this for working metal sheet. Just a thought. It does work I have used it in a previous job and was amazed at the results.
kidhaf #221019 03/05/2008 12:18 PM
i actually hung out with an apprentice blacksmith the other day...ill have to talk to him about it and see what he can do with it
