wide tire kits
#217278 11/13/2007 2:51 PM
kage Offline OP
what is the widest tire you can get under a bonny? i know they make a wide tire kits. with the kit what is the widest you can fit. I know the only way to go to a 200mm or bigger would be to use a jack shaft. thanks for the help.
Re: wide tire kits
kage #217279 11/13/2007 4:07 PM
Under a bonny? Or under an America/Speedmaster?
Regardless, there are no kits.
Re: wide tire kits
FriarJohn #217280 11/13/2007 5:00 PM
british cusotms sells one. big bucks tho for a stock looking wheel. give some time and the ego trip rims will be able to accept wider tires when they come out
Re: wide tire kits
kage #217281 11/13/2007 7:03 PM
180 on the stock rim, 200 on a wider rim.
Re: wide tire kits
Frank #217282 11/13/2007 10:00 PM
It's just a bigger hoop on the stock hub. It's not really a kit. Several people have done that without British Customs' help. Ask Soul_Survivor what size he used. I think he had Buchanan relace it.
Re: wide tire kits
FriarJohn #217283 11/15/2007 5:39 AM
kage Offline OP
i got this information from Soul_survior...so i thought i would share it with everyone.
you can put a 180 tire on the stock 4 inch rim and it will fit within the swing armon an America. But it will be unsafe and you may lose a bead which will could result in you crashing. Any tire 180 or bigger should be mounted on a 5&1/2 inch rim. The 'wide tire' kit BC sells allows you to fit a 180-210 tire on their 5&1/2 inch rim and is sold with the correct offset which is important. To my knowledge BC is the only company that has taken the time to calculate the correct offset. My photos under 'custom' shows a 200 mounted on a 5&1/2 tire on my America. If you have a T-100/bonneville the widest you will be able to fit is a 180. BS sells a wide tire kit for those as well. A 200 will not fit on a T100/bonneville
Re: wide tire kits
kage #217284 11/18/2007 6:50 PM
I run a 200 on the stock rear and a 120 on the stock front.....ANGELIS
Re: wide tire kits
ANGELIS745 #217285 11/30/2007 6:22 AM
kage Offline OP
Well...I made the leap and bout the wide tire kit for my bonny. As soon as I get it put on my bike Ill post some pics for everyone to see.
Re: wide tire kits
kage #217286 12/16/2007 1:10 PM
kage Offline OP
i just posted a pic of my bike with the bc wide tire kit on it..it is just the rim at the moment. i will post more pics as the bike comes along
Re: wide tire kits
kage #217287 12/23/2007 2:35 PM
kage Offline OP
I got the tire mounted on my bike...wow does it look good. the 180mm tire really feels out back of the bike nicely. I have posted some new pics of my bike. It is still not finished but it will be by the time i get home from iraq.
Re: wide tire kits
kage #217288 12/23/2007 2:57 PM
kage Offline OP
Re: wide tire kits
kage #217289 12/23/2007 5:14 PM
Mo' betta? U betcha!
Nice, dude.
Re: wide tire kits
kage #217290 12/24/2007 12:13 PM
Good one!
I've had a 180/70 Marathon on my Speedy since last Feb. No problems, no weird handling, no difficulty installing/seating the bead, and certainly no crashing.
