20W50 instead of 15W50?
#21604 09/09/2005 5:52 PM
nologic Offline OP
Is anyone running 20W50 in their bike? I can't seem to find 15W50 anywhere around here. (Other than my dealer at $50/gal.) I can get 20W50 Amsoil V-Twin oil from my brother for $6.95 a qt.
Re: 20W50 instead of 15W50?
nologic #21605 09/09/2005 6:09 PM
Nologic,been running Amsoil 20/50 for about two years.
Very satisified. 6.95 quart is a good price.
Go for it.
Mike
nologic #21606 09/09/2005 9:11 PM
I've done two oil changes with Mobil 1 V-Twin oil in 20W-50 weight. The 10W-40 choice didn't seem like a good idea. If I rode all year round, the 10W-40 might make sense for the colder months.
nologic #21607 09/09/2005 9:18 PM
tcv Offline
If you go to Amsoils website and look at the write-up on the 20W-50 Syn Motorcycle oil, and scroll down to the Applicatins section they address this question.
Tom
nologic #21608 09/09/2005 10:00 PM
As long as the rest of the spec matches or betters the Triumph requirements, AND you don't intend to ride when it's -40F, 20W50 isn't a problem. The 20W part means that the oil doesn't get any thicker than does single viscosity SAE20 at 0F.
Greybeard #21609 09/10/2005 12:06 AM
Running mobil v twin here. I did an extensive search and found a website with a resident guru who is apparently in the oil biz and has done a lot of research and testing of oils. V twin was his recommendation. After reading a lot of posts there i came to believe this guy knew what he was talking about from real experience. Most opinions on oil are just that, but this guy seemed to know from much lab research. So thats my oil of choice. Don't ask me to link the site, as i can't recall what it's called and only found it after searching google for a few weeks when i first got the bike.I doubt i could find it again very easily.
nologic #21610 09/10/2005 9:42 AM
Oh boy, more oil talk! It's been at least three days.
I am currently running the Shell Rotella 5w-30 snythetic. I was told, "NO NO! You cannot, must not, should not run 5w in a motorcycle!!! It will ruin your cluth, it will blow up your motor, it will blow all your seals, it will molest your daughters...."
Works great, many many hard miles, no slippy, motor stays nice and cool, runs hard, only $12 a gallon at Wally World.
I used to run 10-40, 20-50 etc etc. All kinds of oils and weights. Never a problem.
Simple rule: Clean oil is good oil. If the clutch don't slip, it be fine!
Dinqua #21611 09/10/2005 10:12 AM
So pat, is that motorcycle oil or just plain old oil oil? I got my sister a case of it at costco for 15 bucks for her car...
bennybmn #21612 09/10/2005 10:25 AM
Benny, it is synthetic diesel oil. If you go the the Rotella site, they even recommend it highly for wet clutch motorcycles.
Dinqua #21613 09/10/2005 10:37 AM
Ok cool, I guess Costco just has the plain jane petroleum oil on the cheap. Good for my sis's 91 saturn...
Dinqua #21614 09/10/2005 12:11 PM
Pat:
Has it really been three days? <g> Poop-Boys had the gallon of Shell Rotella Diesel but it did not mention it being synthetic. It was $7.59/gallon which would make sense if it was not synthetic. I'll give Wally World a shot. I'm still getting a bit of "sproing" on clutch release with the Mobil 1 V-Twin oil, I guess something is sticking?
ssjones #21615 09/10/2005 12:29 PM
Really Al, you know what I mean by the 3 day remark eh? Over at the RatNet it is rediculous, every other thread is 'what oil...???"
Anyway, I got the synthetic Rotella at WalFart, it was on the bottom shelf and says synthetic right on the front. It is a different color than all the other oils.
Good stuff too, and I beat my bike pretty hard and it's been fine. There are a few others that use it but I am betting they are a bit afraid to say so because of the Oil Nazis that will say what idiots they are for using the wrong oil.
I figure it runs great, the temp and pressure are perfect, the clutch feels great so it must be ok?
Dinqua #21616 09/10/2005 1:39 PM
I think there are 2 kinds of "the wrong oil". theres stuff that is just wrong and it's a known fact...wrong type, (extended milage, etc) or weight. Then theres the kind that works fine and no one really knows because no one has problems with it, and if they do it cannot be linked reliably to the oil. So the big question is how does anyone know whether it may cause the engine to wear out faster. I mean, if one guy's bike with a lesser oil lasts 100k and the other with a known good oil lasts 130k, neither is going know why thier bike went to that perticular milage before needing a rebuild. And even if 2 guys did compare considering the oils they used, it would be a rare situation. It would take a lot of people with high milage bikes comparing over a long period before any definate conclusions could be made. So what do we really know? All we REALLY know is that the wrong weight is not good, and using oil thats the wrong type for a wet clutch is not good. other than that i'd bet that till some controlled tests are done we will never truly know whether shell rotella is as good or better than mobil V twin, or whether vtwin is as good or better than mobil 1 car oil, etc etc etc.
thats why as dinqua suggests, these oil threads are pretty much useless other than to answer the already known questions like weight for example, and those take one reply before the thread is then worthy of closing.(of course even weight is subjective to a point, but beyond that point it's known)
Dinqua #21617 09/10/2005 2:50 PM
nologic Offline OP
Didn't mean to kick a dead horse here. I did do a search and didn't find any threads that asked about using 20W50 instead of 15W50. Just looking for some thoughts from fellow enthusiasts. Sorry.
nologic #21618 09/10/2005 2:52 PM
No worries, go ahead and ask, that's what the place is for. Don't worry if it's been asked. And at least you did a search too.
Dinqua #21619 09/10/2005 3:23 PM
Yup, no problem. I often search but can't find fine details i wanna know that weren't answered even in a ton of related threads. I was just relating what i seem to have realized from all i've read, which basically boils down to no one really knows whats the best among oils within the known limits. as long as the specs and weight meet triumph's requirments and it contains no milage extenders chances are only god knows which one will actually make any difference. If you want to be safe AND go with something recommended by someone who probably knows a lot more about oil than all of us, go with the mobil 1 v twin as recommended by that guy i mentioned. Wish i could find that site, as reading his posts it's obvious the guy is truly in the know. but unless you intend to ride the bike extremely hard a lot and in very adverse conditions and KEEP it to very high miles, i serously doubt you could make a bad decision if you tried unless you went with a very wrong weight or a oil with milage extenders.
dazco #21620 09/10/2005 4:38 PM
nologic Offline OP
Just wanted to make sure 20W50 was acceptable .....in whatever oil anyone feels is good in their opinion. In mine it's Amsoil because I feel comfortable with it. And it is accessible and priced right.
nologic #21621 09/10/2005 8:00 PM
find motorcycle oil motul syn 10w-50w 31$ cdn a gallon. it was the first time I saw 10-50w anybody have any info about motul 10w-5ow.
bennybmn #21622 09/10/2005 9:15 PM
Interesting site about oil faqs;
http://www.thumperfaq.com/oil.htm
Dinqua #21623 09/11/2005 5:19 PM
Pat, is the same Rotella T stuff I see at 'wamert' that is recommended for heavy trucks, etc., but doesn't mention bikes? Seems too easy!! Checked today and it was up to $14/gal....still a bunch cheaper than most bike-specific blends.
blackdog #21624 09/12/2005 3:48 AM
BD,cheaper now isn't always cheaper later. Al
blackdog #21625 09/12/2005 6:33 AM
nologic Offline OP
As far as I know (I'm in heavy duty truck maintenance) Shell Rotella is not synthetic. Unless they've recently come out with a new Rotella.
blackdog #21626 09/12/2005 12:27 PM
Yes, that's the stuff.
Read this link from Rotella FAQs
Dinqua #21627 09/12/2005 2:37 PM
Soooo,
Pat,
Do ya know where I can lay my hands on 4 qts of Amsoil 20w50? Wouldn't mind changing me awl when I'm round your way!
nologic #21628 09/12/2005 10:09 PM
nologic, go over to any BMW dealer, they have 15W50 that meets all of our specs (as I mentioned in my other post), and is only $8 a quart versus $12, then you have that extra peace of mind. Another possibility is to order Motorex oil online from:
MOTOREX USA
Chuck Ramage
1932 Eastman Ave., Suite #107
93003 Ventura, California
Tel: 001 805 658 0900
Fax: 001 805 658 09 10
e-mail: motorexusa@juno.com
They have several 15W50's, one for about $7 a quart, one for $8 a quart and one for $12 a quart. All meet our requirements, so you should be fine to go for the $7/quart stuff. I'm going to give the $8/quart stuff a try next time around. Running the Beemer oil now (it's actually from Spectro), so far, so good!
Gregu710 #21629 09/18/2005 10:30 AM
Rotella 10W-40 is my choice. Full synthetic with no additives. Been running it for a couple months. Bike runs great and no slipping on the clutch.
Live Free or Die Velvet
bennybmn #21630 09/23/2005 8:01 PM
nologic Offline OP
Does anyone think there would be a warranty issue if an engine problem would develope and Triumph found that I was running 20W50 instead of 15W50? Does anyone have any experience or dealer advice in this regard?
nologic #21631 09/24/2005 3:08 PM
NL,please tell me how they are going to know? Al
vegas #21632 09/25/2005 1:28 AM
I don't know whether this is bad or good but, if you look in the harley manuel, they recommend using diesel oil's when harley's brand is not available. They have no warrenty issues with using such oil's as rotella. Personally I think you'd be just as well off and maybe changing at 4000 as oringally suggested by triumph would be a better choice. Im currently using Jersey Joe's Super Slick Stuff, in mine and quite pleased.
trash #21633 09/25/2005 8:14 AM
cat Offline
i'm running 20/50 mobil v twin every 4000 miles w/ a pure one filter and a magnetic oil plug. i run rotella t synthetic 5/40 in another bike and its water cooled. works great. thought about using it in the speedy...???
cat
vegas #21634 09/25/2005 9:07 AM
nologic Offline OP
I'm not sure if the dealer would take an oil sample if there was an engine failure. I know that this is the procedure in the heavy duty truck world. Although most sample labs would need a sample of new oil also to compare. But since it seems like most everyone here runs what they want anyway I shouldn't be too concerned.
nologic #21635 09/25/2005 2:40 PM
NL,if you had an engine fail would you take it in for repair with the wrong oil in it,if it was the WRONG oil? If you insisted on running the cheapest oil filter,would you show up with that oil filter?Al
Gregu710 #21636 10/09/2005 8:38 PM
nologic Offline OP
Just wanted to make an observation here. I've been looking at oils and found that VERY few meet the Triumph spec of API SJ or higher....not even Mobil 1 V-Twin, which I already bought.(Motul doesn't either.) I'm going to follow Bayern710's advice and use the BMW oil until my warranty is up.
nologic #21637 10/09/2005 8:47 PM
20-50 might not be to good in the winter wh ere you are, but other than that its ok. i live in S. Fl. and have always run 20-50 Amsoil but its always warm or hot here thus the 20 factor is fine but in the cold you might want to go to a 5 or 10-30 or 40??
ENJOY!!!!! NEWT!!!!!
newt #21638 10/09/2005 9:21 PM
nologic Offline OP
I usually don't ride in anything below 40 degrees (I'm a wuss) so the 15W50 (BMW oil) should be fine.
nologic #21639 10/10/2005 4:31 PM
So, Sally, I guess you're about done for this season then, eh?
Dinqua #21640 10/10/2005 4:33 PM
OW!
CRUNCH!!
You been storing them up Pat?
bonnyusa #21641 10/10/2005 4:35 PM
Yea, I've been sick all week and I'm just starting to get back to "normal".
Dinqua #21642 10/10/2005 5:26 PM
nologic Offline OP
Did I deserve this????? Some of us ride when we want to ride....not to impress others.
nologic #21643 10/10/2005 7:02 PM
Rick, you should be honored that Pat looked down from his lofty perch and deemed you crunchable!
Of course that perch is often alcohol induced and Pat is usually full of stale gas...
bonnyusa #21644 10/10/2005 7:18 PM
nologic Offline OP
Phil, I guess there's one on every forum. I knew he was jabbing at me. I can handle it. But I'm not used to it from someone who should be above that.
Sally
nologic #21645 10/10/2005 8:23 PM
Oh there's several on this board.
I, however disdain from that kind of juvenile hijinks and never make fun of people.
nologic #21646 10/10/2005 8:24 PM
NL,
Dood, just bustin them nads, get over it, no harm meant!
Seriously, I have run the Shell Rotella 4T in many many forms (petro, synth etc etc) and the surprising thing is that I have found the Valvoline MC specific 10-40w to "feel" better than all the others, and it petro based!!!
I have tried many many many oils, in all ways and means.
I must say though, that I am not one to be afraid of sperimenting. I figure if it blows up, I can rebuild it, and try again.
I like to push it to the limit, blow it up (hopefully not,really!!), then back it all off a pubi-meter next time.
Don't take it to heart, if you really knew me (like many unfortunately do now) you would finger it out that: I am 50% BS and 50%..."you got your pink slip, boy????"
Live on the edge.
Life may suck.......,
but the alternative sucks way more.
Dinqua #21647 10/10/2005 8:39 PM
nologic Offline OP
Pat, No offense taken. I deserve most of it anyway. Besides, a gunner needs a target. Right?
And now for something totally different: I want to stick to the book until my warranty is up. I have wrenched for a living all of my life and quite frankly I am sick of it. I don't want to have to rebuild something just because I experimented with it. I have other hobbies that I want to devote that time to. Know what I mean?
cat #21648 06/04/2007 2:26 PM
Rotella synth. 5W-30 user here...No probs at all including 1000+ mile trip in 22 hours all slab (high speeds/revs)
RobBA05 #21649 06/04/2007 2:33 PM
Way to dig up an oil thread Rob.
Lets see today there has been an octane and an oil thread.
Whats next?
Oh ya,
Sparkplugs, I haven't heard about side gapping in a while.
Dill #21650 06/04/2007 2:51 PM
don't forget tire pressure there dill...
Mark
Dill #21651 06/04/2007 2:59 PM
Whats next?
Oh ya,
And of course the obligatory WD-40 thread is being delt with elsewhere!
Pedal Till You Puke
Dill #21652 06/04/2007 3:05 PM
So what tires are you running Dill?
LitzerSki #21653 06/04/2007 3:09 PM
Rotella synth here too. 90 degrees on the slab the other day at a constant 80 MPH - oil was 190 degrees - well within an acceptable temp.
bonnyusa #21654 06/04/2007 3:27 PM
I'd run Amsoil until Pat started using Rotella synthetic after his BB mod. I tried it a few times, then went back to Amsoil 20W/50 because my valves sounded louder (loud valves save lives ). BUT, this winter, using Amsoil 20/50, at 22°F in the morning, my battery just didn't have the power to dig a trench through that molasses, so I went back to Rotella synthetic.
bonnyusa #21655 06/04/2007 3:32 PM
I am about to start using a car tire on the rear - I've seen the light. $70 for a tire that'll last 40,000 miles and you can stop in the rain using only the rear brake.
SKILLET #21656 06/04/2007 3:35 PM
I looked for an older one but couldnt find one...
RobBA05 #21657 06/04/2007 7:18 PM
Jeez, last time you wrote about that it took about 15 minutes to read. Is this the Reader's Digest condensed version?
Just yanking your chain Rob. I read your entire trip report and enjoyed every bit of it.
And just to stay on topic...Rotella T 5w40 with a PureONE PL14612 the last couple of changes(every 4,000 miles), but I've tried most oil and filter combos without noticing any difference. I might switch the filter to something else since it hangs down farther than the stock one.
SalMaglie #21658 06/04/2007 7:44 PM
Derek,
PureOne has the same filter in a shorter can, but I can't find the part number. It was listed here somewhere.
Which Oil Should I Use?
SKILLET #21659 06/04/2007 10:25 PM
Maybe it's one of the MC part numbers in the Tech Vault(ML16817 or ML16819)? I've just been ordering the PL14612 from Amazon since they have a 2 pack for $9.88. I'll add on a DVD or something else for the wife that qualifies for the free shipping at the same time. That way I get the wife a little something for a surprise, and get 2 filters cheap.
But airguy's recent roadside oil change where his filter took a big hit and dumped all of his oil has me thinking about a lower profile filter.
SalMaglie #21660 06/04/2007 10:41 PM
I recently stopped at the local honda dealer and picked up a filter. It was a good 1/4in shorter than the stock filter.
As deep as the brake pad went into Keith's filter, I don't know if a shorter would have mattered, But I think I'm gonna stick to the honda filter.
roundy77 #21661 06/04/2007 11:21 PM
Yeah, Keith did have a freak occurrence...first time I've heard of it on these boards in 4 years. But it still might be wise to go with a shorter filter, because the cost isn't much different. IMO it isn't a good idea having the filter lower than the oil pan if you can help it.
We were comparing filters at the Southwest Fest between pulls of beer in Dwight's garage at the end of the day. The PureOne I've been using sticks out down below the oil pan. Some of the others didn't, like Dwight's stock Triumph one. Out of curiosity I just went out to the garage and measured the filter and it's 3 inches long. It's below the oil pan by about half an inch.
roundy77 #21662 06/04/2007 11:56 PM
Hey Stewart, can you get me a part number? I will add it to the Tech Vault.
ssjones #21663 06/05/2007 12:04 AM
The Rotella-T Synthetic is in the Blue jug. The non-syn is in the white jug, and now they have a newer Rotella out in a white jug also, and I think it would be okay to use, too, but I do not believe it is even semi-synthetic, and I do not recall the viscocity.
Check the Rotella website for more info on that one - it is intended to help the truckers meet the new EPA guidelines, but I'm pretty sure it still does not contain any friction modifyers that would be harmful to wet-clutch operation.
I have not checked the Rotella Motorcycle Forum lately - I need to go see what's up...
I'm sticking with the blue jug though. My last oil sample results came back better than ever. I think she finally got broke in at about 25k miles!
Keith
Houston
Ridin'Texas
'04 Speedmaster
2020 T120 Black
Blackwind #21664 06/05/2007 9:25 AM
The new Rotella jug you saw may be the CJ-4 spec. Class 8 (18 wheelers) truck diesel engines manufactured on or after 01/01/07 need to run on Ultra Low Sulfur Diesel, (ULSD) at 15 ppm of sulfur. The pre-07 diesel spec - Low Sulfur Diesel [LSD], was 500 ppm of sulfur.
ULSD engines require an oil spec of
CJ-4
Will CJ-4 oil hurt a Triumph?
I don't really know, but I would lean heavily toward, I doubt it.
Shell mentioned that they are going to keep making the blue jug synth we know & love for a while. I don't recall how long, but it was (is?) on their site somewhere. There are still as you know, many pre-07 engines on the road, and many truck fleets pre-bought 06 engine trucks very aggressively to avoid the 07 engines in their tractor replacement cycles. In backlash, some of the major truck makers are now laying people off as a result of the lack of demand caused by the 07 engines. http://portland.indymedia.org/en/2006/09/346126.shtml
The 07 engines are calculated to add up to 16 to $20,000 to the life cycle costs of the vehicle. In the long run, ULSD is a good agenda for cleaning the air we breathe in that the engines burn almost without emissions, but in the mean time, it will hurt an industry plagued with bankruptcies ever since the deregulation of transportation industry rate structures.
(See also - airline bankruptcies since deregulation.)
