Hardbags
#209534 10/12/2007 4:08 PM
mrt202 Offline OP
Anybody got those hardbags advertised on NewBonneville? How do you like them? I'm trying to get the wife to buy me some for my birthday. I'm wondering if they are worth the price.
Re: Hardbags
mrt202 #209535 10/13/2007 8:47 AM
I had a pair on last bike. They where the exact same style but they where the leather version. In my opinion they are the best hard bags for the money. The hinges are plastic but the bags themselves are VERY well made.
good luck.
-Tony
Re: Hardbags
mrt202 #209536 10/13/2007 10:03 AM
How easy are they to take on and off and will a standard size laptop fit in them as well? Need a solution for back and forth to work...
Re: Hardbags
Wheezer #209537 10/13/2007 3:14 PM
To take them off and on 4 bolt and a plug for turn signal.And think a lap top will fit,they are very water tight to.heres mine [image][/image] [image][/image]
Re: Hardbags
midlifespeed #209538 10/16/2007 11:25 PM
How eay are they to powder coat? Cuz i have an 02 Bonnie in Cardinal Red.
'02 TBA w/ '03 motor, D&D exhaust,gangster WW.. Bonnie rides again..
Re: Hardbags
Gratfultim #209539 10/17/2007 7:51 AM
Powder coating requires object to be powdered be metal and withstand prolonged fast oven temperatures.
Re: Hardbags
Gratfultim #209540 10/17/2007 7:54 AM
Moe's right. An electric current has to run through the items to be powder coated for the coating to stick. It's then baked in an oven. They do plastic now but I don't know the process or if it would work on fiberglass.
Re: Hardbags
wojo #209541 10/17/2007 8:55 AM
cat Offline
those look great.
Cat
Re: Hardbags
cat #209542 10/17/2007 11:42 AM
Those bags do look good. However, I recently purchased the BB Reproduction bags because the the ones from NewBonneville were backordered. I'm very happy with the fit and finish. Also, I put them on in about 20 minutes. No rewiring and blinker removal. For what it's worth...
Re: Hardbags
eddieb #209543 10/17/2007 11:47 AM
Eddie, how did you mount the BB Reproductions bags?
Kevin - Luceo Non Uro
Re: Hardbags
Speedmaster05 #209544 10/17/2007 4:19 PM
You have to buy the mounts from BB Reproduction ($120ish). Just remove the last two fender strut bolts and mount with supplied longer ones. After that, slide the bags into place and use the cotter pins to secure.
Re: Hardbags
moe #209545 10/18/2007 8:42 PM
So your saying i should just have them painted. Now wouldn't that have been easier.
Re: Hardbags
Gratfultim #209546 10/18/2007 8:55 PM
cat Offline
i like the pipes, too.
cat
Re: Hardbags
Gratfultim #209547 10/18/2007 9:18 PM
If anyone is interested, plastic parts (fiberglass as well) have been being powdercoated for several years now. There are tons of powders available now, low temp stuff (200-250F) is widely available. the main problem with this is the gloss level is not that high though. The real high gloss stuff is only applicable to surfaces that can withstand the 350 or so degree temps.
Typically plastic pieces are powdercoated by either applying an electrostatic primer or they can be flame coated. The flame coating is becoming very common as pretty much anything can be powdercoated, plastic, wood, even cardboard, as long as it doesn't melt or burn under the initial application. Basically the powder is fed into the edge of a flame and applied in a melted state.... uh, like it's a powdercoatingflamethrowerkindathingy.
(no expert here, just that it's kind of an interest to me as I have been putting various coatings on various items for a good bit a years.... not the Holiday Inn Express thing if you were wondering)
Steve (hewhoshallremainavatarless)
Re: Hardbags
glazer #209548 10/18/2007 9:30 PM
Thanks Cat I get a lot of compliments on the pipes.This time of year they make good leaf blowers.
Re: Hardbags
midlifespeed #209549 10/19/2007 7:53 AM
cat Offline
so where are the pipes available? sound?
thanks.
cat
Re: Hardbags
cat #209550 10/19/2007 8:18 AM
Yeah I'd like in on that info as well.
Re: Hardbags
Gratfultim #209551 10/19/2007 3:55 PM
Well they started out SS long cannon.Then I cut 12" off and used a 18" turn out 3" ID and slip them on.Then I can split them and take the baffles out when need.
Re: Hardbags
midlifespeed #209552 01/12/2008 11:16 AM
I bought a pair,NewBonneville Hardbags W/LED signals but the installation Instructions are a little sketchy.Going to attempt. need to inquire about a few things
sometimes ya' gotta hold a candle to the devil.-06' Blk Spdmastr,TBpipes,Plrs-Blmth,3Trns,AI Out, ,UNI,130/40,1shm-Ea.,TBS ndls.
Re: Hardbags
speedblastr #209553 01/12/2008 1:18 PM
Not trying to threadjack here, but... Hey midlife, what did you do or use to get the liscense plate flush to the fender itself? I like that look, hard bags or not.
My '07 "For three days after death hair and fingernails continue to grow, but phone calls taper off." Johnny Carson
Re: Hardbags
speedblastr #209554 01/12/2008 4:30 PM
Maybe this will help? http://tsukayu.com/Installation_rev3.htm
Re: Hardbags
FriarJohn #209555 01/12/2008 11:59 PM
Thanks John, that top photo with the spacers tells all. I appreciate it a lot. Not going to get into it yet until my back rest and luggage rack come in ,shes a beaut,done some tribal accessories to it.
Re: Hardbags
speedblastr #209556 01/13/2008 3:02 AM
Cool!
Re: Hardbags
FriarJohn #209557 01/13/2008 5:25 AM
I removed stock plate holder and use the rubber gasket as templet. Had a piece of 3/16 ss plate cut and drilled and mounted it useing the rubber gasket as a spacer.
Re: Hardbags
midlifespeed #209558 01/14/2008 6:25 PM
Does anyone know if these bags come in a leather look or leather covering.
Re: Hardbags
drbrake #209559 01/14/2008 8:08 PM
and I thought this thread was about tough women!
Re: Hardbags
The_Dog33 #209560 01/14/2008 9:03 PM
Yes, they do indeed. They're the same price as the painted black bags.
-brent
Re: Hardbags
mrt202 #209561 01/15/2008 9:28 AM
cat Offline
those pipes are boss, too.
who makes them?
cAT
Re: Hardbags
cat #209562 01/15/2008 2:01 PM
Yep, he made the pipes,exhaust extensions from a tractor trailer.I liked them too and asked when he first did it.
Re: Hardbags
The_Dog33 #209563 01/15/2008 7:19 PM
does anyone have pics of the leather hardbags instaled on their bikes. Also is there up and down adjustability as to where you mount them. the picture here has them higher than I would like. I doubt if lowering them a couple of inches would creat any problems with the exhaust heat.
Re: Hardbags
drbrake #209564 01/16/2008 12:03 AM
You know Dog33, when you say it like that its kind of funny but true. And thanks cat, I did it because I wanted turn down could not find any so I made them.
Re: Hardbags
midlifespeed #209565 01/18/2008 9:55 PM
I removed Stock turn signals , going to find some cover caps. Also purchased the back rest/Rack combo to fit with my roadster seat. I'm going to leave the plate holder,the rack comes out to there anyway. The rack has thrown a little twist in the spacer thing as it is now a flat surface for the hardbag brackets,it had spacers to fit in the rear chrome fitment,so I'm good there,so far. How did you run your wiring for the rear LED's? Drill an additional (5th) hole in the side of each bag? Any input Midlifespeed would be fantastic! Thanks Speed.
Re: Hardbags
speedblastr #209566 01/19/2008 5:39 AM
Yes, I drilled the hole for the wire just under the rubber gasket by the front bracket.Ran the wires behind the fender strut and picked up the turn signal wires under the seat.I left the orignal wires in place.One more thing,put a two pin plug on the out side of the bag to make them easier to remove. Put so sealent around the wires their they come out of the bag and your done.
Re: Hardbags
midlifespeed #209567 01/19/2008 11:20 AM
[image][/image]
I seldom tire of seeing what people do!! Your's is exceptional. I like it.
Re: Hardbags
freedom #209568 01/19/2008 11:36 AM
It's definitely one of the most personalized Speedy's I've seen. All your effort shows.
Re: Hardbags
RamSound #209569 01/19/2008 11:52 AM
A very Beautiful Bike indeed!
"Will Ride or Fly for food"
Re: Hardbags
midlifespeed #209570 01/19/2008 4:14 PM
MIDLIFESPEED. How in the heck did you get that first one to line up? I see yours skirt just barely beneath your rear fender,did you eyeball it or by some other means. SPEED.
Re: Hardbags
speedblastr #209571 01/19/2008 7:04 PM
I made a cardboard templet to lay out the holes.Sorry, But threw it away.
Re: Hardbags
midlifespeed #209572 01/19/2008 7:16 PM
Yeah,I got the first one on drilled & permanent.(Tricky stuff)I didn't go by paint&mark.used a markall pencil, still used the tape as those threaded ends will scratch the ****** out of the paint,tomorrow I need to pickup 4 more neoprene washers for the outside as I didn't get any period. Then I will mirror the other side as persay.The only drawback and it's not too bad , when I open the bag lid it catches a little bit on the backside of the roadster seat, otherwise it looks pretty even (topside) with the rear fender. I'll keep ya posted,I may need to ask another Question. Thanks. Speed. P.S. I'm having a tough time finding those 2 -double female sockets,Been t Auto store,TSC,D&B Sales, where did you find yours? Maybe Home Depot or something?
Re: Hardbags
speedblastr #209573 01/21/2008 9:03 PM
I got it MidLifeSpeed. Need to hook up to pods(Drill Hole) , almost done,have a picture in a few days. Thanx. Speed.
