Page 1 of 4 1 2 3 4
NH DYNOS (finally)
#191267 08/10/2007 6:57 PM
Most of us were running rich by one jet size (pretty good for seat of your pants tunning one jet size off)...
I was puking gas out the pipes (but pulled some decent #s) check out Martins (bucky formerly LJ3000) PERFECT
and look at Tim's RWHP #S yikes
enjoy and gleen what you can from them...
Re: NH DYNOS (finally)
dynos_NH_07 #191268 08/10/2007 7:04 PM
Well, I think this proves it, the Black/ Sky blue Speedmasters are the fastest...
Unless you're willing to spend an obscene amount of money on mods
Let my dying thought be that every mile was fun and let my tombstone read,"They never made one fast enough for me."
ArsnlTim #191269 08/10/2007 7:09 PM
yeah but check out charlie and I...our #s are PDG and just pipe and jets...not even a freak...oh and we ride RED bikes
RobBA05 #191270 08/10/2007 7:14 PM
ok, ok, the red bikes are second fastest
ArsnlTim #191271 08/10/2007 7:22 PM
Good job Rob!
We'll drag for beers in NY!
Last guy in buys the beer!
Uncle Charlie
unclecharlie #191272 08/10/2007 7:38 PM
Sweet! I'm safe
ArsnlTim #191273 08/10/2007 7:51 PM
gonna havta do something about my dyno. come spring it will look a bit different
Frank #191274 08/10/2007 7:59 PM
Wow nice numbers guys. Gotta love the great torque curves of these motors.
ArsnlTim #191275 08/10/2007 11:45 PM
Those numbers are pretty impressive, you are not far behind Pat and correct me if I am wrong you are not running a big bore or any other major mods. Great Numbers! I need to get mine dyno'd to see what kind of numbers she can pull.
dynos_NH_07 #191276 08/11/2007 8:42 AM
They are all posted here as well in full sized pdf files:
New Hampshire Dyno Runs
Dinqua #191277 08/11/2007 1:06 PM
Hey Pat, is there anything you would do to correct your weird spikes and dips under 4K rpms? Also, can you FEEL them when you ride? Just curious...
Not you fat Jesus!
Wyrm74 #191278 08/11/2007 1:14 PM
Since Pat is not online at the moment...let me take this one...
Those spikes were more a function of the dyno guy tweeking with the throtle and less a function of the way pats bike was running...
I think he mis shifted...or possibly let it run down to low cause he almost stalled the bike when it was on the machine...thus the big dip...then smoother curve
RobBA05 #191279 08/11/2007 1:55 PM
plus pat if pig rich
Frank #191280 08/12/2007 3:03 AM
Note the torque numbers with Pat's big bore runs
Schweet
Bucky #191281 08/12/2007 1:43 PM
Are any of the above bikes running an 865cc or are they all 790cc (except PAts bike of course)?
Zmilin #191282 08/12/2007 5:19 PM
Rob,
Are you going to drop one main jet size and keep your pilots? Or, are you planning on lowering both one size?
oldroadie #191283 08/12/2007 5:49 PM
Dyno talk
http://www.rc51.org/dynotuning.htm
Worth a read to help interpret the results and alternate tunings.
"The majority of tuning all comes down to the Air Fuel ratio. Optimum power is generally around 12.6:1 while the stoichiometric value for a gasoline burning engine is about 14.6:1 for a good compromise of performance & mileage while Dynojet themselves generally target 13.2:1 when they build their own maps."
"Exhaust dynamics is a tricky business, but if the flow is improved & the reversion waves are tuned properly then more fuel can be added & the more fuel you have the more power you get. If you have to remove fuel due to a poor flow design or the reversion waves are kicking back to the cylinder & meeting the next exhaust pulse at any point in the rev range then you simply are not going to get good power gains at that point."
If we could find pipes that would ideally scavenge the exhaust flow by introducing a low pressure zone along the way, or at the least, would not offer pressure backlash against the exhaust cycles, it's all downhill from there to maximize HP or find your desired balance of HP vs. torque via jets & needles et al. I'm not clear which pipes those are, or if they even exist for our bikes. At $300 to $700 a pop for aftermarket pipes, I'm not going to the trial and error method to find them. Got mouths to feed.
To the dismay of many seeking HP above all, I'm going to de-tune mine a little further and bring the MPGs back up to 50 MPG. At my current 13.2:1 offering 40 MPG, I apparently have plenty of head room to cut the fuel back a bit and still not exceed the magic threshold of 14.6:1 (or 14.7:1, depending upon which method you desire.) What can I tell ya - I'm an old fart with a tight wallet.
Footnote: RJS runs a Dynojet brand unit, with the Dynojet software mapping.
Bucky #191284 08/12/2007 6:03 PM
My other question is "was everybody running the same octane rating" since that also skews the A/F ratio result?
oldroadie #191285 08/12/2007 6:21 PM
I was told that my pilot circuit and my needles were fine but the my main was WAY to rich (perhaps as much as 2 sizes) BUT as I intend to drill out the airbox I knew I would be rich...so I may only need drill and drop 1 size (to a 132.5 instead of 130'S)
RobBA05 #191286 08/12/2007 6:25 PM
I will re dyno after the mods and compare results
RobBA05 #191287 08/12/2007 7:33 PM
This is the one thing we did not address. I believe pre 2007 the Speedmaster is an 865 cc and the America is 790cc. So Pat's big bore would only give him an extra 39 cc's over a stock Speedmaster while it would give him 114 over the America. It also gives the stock Speedmaster 75 cc's over the America. Definitely something to address as far as hp and torque gains with any mod's.
My mind and body are still out of tune I hope they run into each other real soon "
lzrdking61 #191288 08/13/2007 8:50 AM
I think they were all 790s (the non big bore guys).
Dill #191289 08/13/2007 12:31 PM
I'm a 790
lzrdking61 #191290 08/13/2007 1:39 PM
the big bore is more for compression that cc's, and an added bonus is you get a WAY stornger forged piston
Frank #191291 08/13/2007 5:12 PM
Besides being able to tell the third one down is an 865 because of the year SM you can also easily tell by the numbers. So far it seems to be easier with basic mods to get hp gains with the 790.
lzrdking61 #191292 08/13/2007 9:30 PM
Finally some real results showing that even modest changes can equate to some impressive gains. What would be really good though is to know Exactly what mods had been done to each bike as some of these details have been left out? A table for instance comparing all these details would be really valuable to us HP deprived aspirants .
Then as different mods are made and a dyno done, these results can be added to the table for all to paw over. Just a suggestion but for me these details would be really interesting
Stacka #191293 08/13/2007 9:51 PM
That's an excellent idea. Hey Pat, would you consider hosting spreadsheet?
I think this thread needs to 'stick' around for a bit...
bonnyusa #191294 08/13/2007 10:08 PM
phil, when you gonna get yours dynoed?
Frank #191295 08/13/2007 10:17 PM
Everyone around here wants $100 a pop so my next best is down in south Miami (I have two Dynojet coupons for free runs). Problem is time. I have none. I will get there, I promise.
bonnyusa #191296 08/15/2007 7:16 PM
I wouldn't mind helping out here with updating a spreadsheet or table, in fact I've done a simple one already and scanned it as a Jpeg but it doesn't come out clear enough to read.
Is there any way to upload a file onto this site cos I don't know how?
Stacka #191297 08/15/2007 7:54 PM
John,
Please put the bike type on the spreadsheet, too.
Cowtipper #191298 08/15/2007 8:26 PM
All I can offer is more specs on my bike:
03 TBA 790
Bubs slash cuts
UNI, no snorkle
45 pilots, stock needles, 1 shim, 135 mains
Wrong HD type thunbscrews (set too rich?)
I think I can fix my rich at idle condition by changing
the thumbscrews to Brent's new correctly tapered ones,
and re-adjusting/balancing the carbs.
Anyway, this dyno experience confirmed my seat of the pants
feeling that my bike pulls pretty good. It doesn't get good
mpg, but if I wanted fuel economy, I'd be riding a moped!
Uncle Charlie
Stacka #191299 08/15/2007 8:29 PM
Nice format John. I'd like to see motor size also.
No file uploads here but we just need someone with a site to host it....
Uh, Pat???
bonnyusa #191300 08/15/2007 8:54 PM
all that hark work & cash & Uncle Pat only has 70 ponies?
Yota #191301 08/15/2007 9:02 PM
Send it to me and let me convert it to a table and I can set up a link...
oldroadie #191302 08/15/2007 9:41 PM
Ed, I've just sent the table which I've modified again to you're personal email address. thanks for that Anyone who's detail appear may / will need to send their full details to Ed so he can fill in the gaps eg Type of bike and motor size etc
dynos_NH_07 #191303 08/15/2007 10:09 PM
Bah! Horsepower Shmorsepower -- real men tune for torque
On a more serious note, here's a primer on how to determine optimum shift points for a given torque curve
http://www.allpar.com/eek/hp-vs-torque.html;
Horsepower needs to be where you can get at it (within a viable RPM range) for it to be most useful. For the bikes tuned to peak out their HP at the high revs, your general rule of thumb may be to redline it in each gear if a big ol' twin sidles up to you at the stop light and gives you a cheesy grin. I'd have to run the numbers to verify that though.
Bucky #191304 08/15/2007 10:45 PM
We'll drag for beers at your birthday party!
unclecharlie #191305 08/15/2007 10:52 PM
Ha ha! I'll be seein' ya in my mirrors while you try to twist it up to 7,000.
Stacka #191306 08/16/2007 6:56 AM
I'll add any details that you want to share.
Alrighty, Pat, RobBA05, Charlie, and ArsnlTim have the real men angle covered and everyone else is pretty darn close...6 of the dynos are so close it's amazing.
Page 1 of 4 1 2 3 4
