Another ignitor gone? Opinions?
#179793 07/07/2007 10:12 PM
As some of you may have read, I got in all of about 10 miles up in the mountains before she started having problems.
Here's the scenario:
  • Get her warmed up and loose all power to the plugs and I mean gone!
  • Turn the key to off and then on again, fires up and will last anywhere from 5 seconds to 2 minutes
  • Eventually, the problem becomes consistently intermittent (cuts in and out regularly every few seconds)
I've looked at:
  • All electrical connections
  • Coils, connections, and spark plug wires
  • Fuel flow
I am assuming it is the ignitor but do not have another one to verify of course so I am going to have to let Pure Triumph diagnose it for me. One hope for me is that my VIN falls into the Technical Service Bulletin #52 range so I may be able to get it fixed for free!
Any opinions/input on this will be greatly appreciated!!
Re: Another ignitor gone? Opinions?
bonnyusa #179794 07/07/2007 10:33 PM
Phil,
Yep it sounds like the ignitor. I had the same problem (although only on one cylinder) last year just before the run to/from Germany for the Euro Rally.
Sorry it messed up your ride.
You know, with the trip to Sweden coming up in just over a couple of weeks, this is the only thing about our bikes that scares me, especially with my going through several countries without dealers.
bonnyusa #179795 07/07/2007 11:16 PM
The igniter is located under the tank toward the rear on the right side of the frame. Some may be mounted on the left, but I haven't seen any. It's a plastic box about 2 inches or so square, maybe 2 1/2 - 3 inches tall and part of one side is sloped inward.
Pop the tank off and locate the igniter, then button up the bike and run it untill it starts acting up consistently. Spray some electronic cold spray (available in electronic supply shops including some Radioshacks) up under the tank where the igniter is located and see if it temporarily fixes the problem. If it goes away until the module warms up again, you can bet it's going bad unless there is a contact problem in the big plug on the bottom side.
Greybeard #179796 07/07/2007 11:43 PM
Losing spark to both plugs, you might get lucky with just the ignition sensor going bad. There's been a few that have been replaced, but it is rare. It's #1 on this Bike Bandit parts page. I think it's also commonly referred to as the pickup coil.
bonnyusa #179797 07/08/2007 9:15 AM
Fill,
You can always hook a scope up to the little wires from the sensor to see if you are getting a pulse. Probably need just a 40Mhz scope or so to see it. This should at least tell you if it is a sensor or a CDI issue. Maybe Matt can send you his spare unit he has now - it doesn't work in the rain though.
Dinqua #179798 07/08/2007 9:29 AM
I'll bet a simple piezo alarm speaker fom Radio Shack would read the pulse and give a chirp, that would be a simplistic but inexpensive test tool for the sensor. Freeze spray on the sensor and the ignitor would also be a quick diagnostic tool to identify the culprit. And, there's always the mildly insulting "did you check all of the ground wires?"
bonnyusa #179799 07/08/2007 9:32 AM
Hope this is related enough not to count as a hijack.
Here's a link to search Triumph's site by VIN for technical bulletin's pertaining to a particular bike.
77T140V #179800 07/08/2007 4:32 PM
Thanks for the replies everyone...
I hear ya Thanassis. I was lucky it got me back I guess.
Thanks GB. I am very familiar with the location and the cold shot is a great tip. I will try that. btw, the connector on the ignitor is fine...
Hadn't thought about the sensor, Derek. I will look at the signal output from that (now that I am home, I have access to more electronics test equipment). Pat, don't have a scope but I wonder if an analog meter would show the pulse?
Not insulted at all Ed! Sometimes trying to look at the big picture, we don't check the basics (which I did! )
I checked that link Tom and of course, my VIN shows nothing. As some extra ammo, I also emailed Peter Carleo with the bulletin number, the gist of the contents, and asked whether Triumph would honor that one years later. I hope to have an answer tomorrow...
bonnyusa #179801 07/08/2007 9:34 PM
I will be most interested in hearing how this plays out. Intermittent problems are always the hardest to diagnose, especially when the symptoms fluctuate. The only real rule I rely on is to go back to the last thing I did/repaired and take a very close look. Doesn't seem like this applies in your case.
oldroadie #179802 07/09/2007 10:03 AM
triumph should honor these, way to many have gone bad for it to be looked past. but triumph does seem to turn a blind eye to a lot of this stuff
Frank #179803 07/09/2007 11:36 AM
I'm guessing Derek broke the code on this one.
Pickup coil.
Definitely wanna eliminate that first.
I tried that when I went through all this.
Couldn't get it to work, but then I'm not too sharp on that kind of stuff.
Mine had the classic one-sided problem.
That's how I knew it wasn't the pickup coil.
Said Molly to James, that's a fine motorbike. Richard Thompson
rhnstn #179804 07/17/2007 10:09 AM
An update (sorta)....
Matt (Mlessard) is lending me an ignitor and it should be here this week. I will run her up and down my street until she it starts acting up and then swap the ignitor. That will either prove or eliminate this part from the equation.
If it is the ignitor, then I will have to take it to the dealer where hopefully invoking Service Bulletin #52 gets it replaced for free. If it's not the ignitor, then I will further troubleshoot it down to the root cause.
bonnyusa #179805 07/17/2007 1:43 PM
XHD Offline
Sightglass has an active post on ignition pickup specs that might relate to your problem of misfire. Check it out.
SteveB
"I live the life I love and I love the life I live."
XHD #179806 07/17/2007 3:59 PM
That will be the next step in shooting this problem if the spare ignitor shows the same symptoms.
bonnyusa #179807 07/17/2007 5:10 PM
I think she is just jelous of the t100
Pete
bonnyusa #179808 07/18/2007 9:57 AM
..... then I will have to take it to the dealer where hopefully invoking Service Bulletin #52 gets it replaced for free......
I found a web page that calls out Triumph recalls, but not service bulletins. Where can I find a comprehensive list of Triumph service bulletins for our bikes? The Triumph page doesn't return anything when plugging in all years for the America (re. #52). If exists, sounds like a good link for the "known problems" section of the Tech Vault.
Thanks,
Tom
77T140V #179809 07/18/2007 11:18 AM
From what I have heard, the service bulletins are closely guarded 'secrets' (stupid, I know) and are only available from a dealer.
Here's some links to threads about service bulletin 52:
http://www.bonnevilleamerica.com/forums/...true#Post180779
http://www.bonnevilleamerica.com/forums/...=true#Post65133
bonnyusa #179810 07/19/2007 6:32 PM
Well, there's no question now. I got Matt's (mlessard) ignitor today and went for a short ride (with the stock ignitor) to warm her up and cause the failure. Sure enough, started cutting out after a bit. Got back to the house, took her apart, swapped in Matt's ignitor and SHE RAN PERFECTLY!!!! Did this swap a couple more times to satisfy my anality and I am now 100% convinced I have a bad ignitor.
So now I will take her to the dealer, explain my troubleshooting, invoke Service Bulletin #52, and see what they will do for me. As far as I am concerned, I should pay nothing to have the ignitor replaced and I will get Triumph involved if I have to. Pure Triumph are good people though so I should not have a problem.
Matt is letting me hold onto the ignitor until I get mine replaced so now I don't have to lose much riding time either!! Matt, I love you brother. You saved me a chunk of change and effort. Anything you want, anytime, just ask.
bonnyusa #179811 07/19/2007 8:50 PM
glad its all working out for you captin. Next time your in NY just buy me a Genesee and were square.
bonnyusa #179812 07/19/2007 9:33 PM
tcv Offline
Phil,
Sorry about the ignitor, hopefully Pure Triumph will take of it for you. Electronics can have many levels of failure, with intermittent being the worst of them. I remember Moe thought he had a bad ignitor and brought it over and we installed it on my bike. My bike ran fine with his ignitor. I can't remember what the final solution was, but it was nice to have someone close to verify if the part was good or bad.
Tom
tcv #179813 07/20/2007 11:37 AM
So far, so good.
A plea for goodwill may turn out to be the ticket.
The dealer's rapport may come into play there.
Let us know how it plays if you don't get sworn to secrecy.
rhnstn #179814 07/21/2007 7:23 PM
Update:
Asked the dealer to call Triumph and ask them about this and to please invoke the bulletin. Called back later yesterday and was told that Triumph will not honor this because it was 'too old'.
I have now written to Peter Carleo asking for his help. We shall see....
bonnyusa #179815 07/21/2007 10:56 PM
Let us know, it may be time for him to get about 100 notes about never buying another Triumph because the Prince of Darkness is still around and Triumph charges outlandish rates to fix the inherent vice.
I already did one and coils on warranty. If I do one on my dime in the near future, Triumph and I will be getting divorced. The bucks they charge for that box is obscene.
bonnyusa #179816 07/23/2007 12:03 PM
Please be specific when talking to Peter. It is a Technical News Bulletin NOT a Service Bulletin. All dealers have online access to both the service Bulletins and the technical news bulletins.
moe #179817 07/23/2007 12:50 PM
Thanks Jim. I re-replied to email to Peter and clarified that!
bonnyusa #179818 07/29/2007 12:21 AM
Out of town Friday and most of today but this past Thursday, I finally got to really run her with Matt's CDI in there instead of a 'bench' check. About 3 miles (aka, hot), she starting cutting out just like with the original. ARE YOU KIDDING ME?!?!
Nope and did not have a chance to do any more (dealing with leaving) but I now have two right side (alternator cover) gaskets and will delve into there tomorrow. My plan is to check the gap and run her. The saga continues and I hope it's something stupid that I might have done (like every other time I have ever broke her!). Details to follow. If I have to take the cover off, I will be taking lots of pics.
bonnyusa #179819 07/29/2007 12:34 AM
Phil, did you see the Triumph tech bulletin about the production change? It was posted on another thread:
My bike would misfire and sometimes lose one cylinder firing when hot. The dealer finally replaced both coils and the CDI and it never happened again. They are now making the above changes on any bike with similar problems first. This info was not out when they fixed mine on warranty. The shop manual has the gap at 1.0 mm, so they have made a significant production change.
RamSound #179820 07/29/2007 1:14 AM
I hear ya Bob. First thing I am going to do (beyond checking all other electrical again) is to check that gap. I did see Pete's post about the new spec. Having new gaskets, that cover is coming off just because!
btw, has anyone ever tried turning the key off and then on again (which got me home three time now! ) when exhibiting this set of circumstances?
bonnyusa #179821 07/29/2007 3:40 PM
When mine got bad I would stop and turn off. Sometimes after sitting 5 min. it would run another 20 miles before acting up again. One time though, I had to cross a 3 mile bridge all on one cylinder as I couldn't pull over and stop.
RamSound #179822 07/29/2007 4:24 PM
Hi Phil,
sorry to hear about your problems, I have just got mine back from the dealers once again. This time they replaced the igniter. I had already replaced two coils as thats what was diagnosed by the RAC (Breakdown and recovery people) the first time it started missing.
This is my third igniter and the bike is only just 3 years old, I was lucky enough to have it replaced by Triumph at the dealership.
Hopefully this will be the end of it and it should run perfectly now
Hope you get yours sorted out, nothing worse than not feeling comfortable on your bike if you are travelling a distance of any kind..
birchr #179823 07/29/2007 8:00 PM
My bike died on the road again today. Luckily it was leaving a buddy's house so I only had to push it a 1/4 of a mile back. We did the usual check for gas and I was so sure I couldn't be the cdi that I must just be missing the spark that I pulled the carbs etc.
3 hours later another check for spark. And guess what nothing, thats 2 ignitors in less than 2k miles. I'm very annoyed. In fact I will have a hard time trusting this bike again.
bonnyusa #179824 07/30/2007 8:27 PM
Didn't Matt or rather wasn't Matt having problems with his ignitor? SOoooo.....
moe #179825 07/31/2007 12:44 AM
His ignitor ran fine as long as you didn't get it wet AND then shut her down. With it still cutting out with his, I'd say it's not the ignitor now. Having to work on the refrigerator and the friggin pool pump, I haven't been able to work on her. Now that those are out of the way, my complete focus is on my bike.
bonnyusa #179826 07/31/2007 7:05 AM
Phil,
Is it "dry" behind the right side cover? I was going to order some right side gaskets from Chy's place and reset my air gap if it didn't get into a $50 oil change at the same time.
oldroadie #179827 07/31/2007 10:05 AM
No, it's wet but according to the Haynes manual, you can take the cover off and not lose all the oil. Below is the info from that manual. I plan on having a piece of plastic sheeting draped/taped over the frame to force any oil into a catch basin for two reasons. I don't want to lose the oil and I don't want to make a mess!
Another thing I found in chapter 8, section 30 (Alternator rotor and stator, page 8-23) is that they say you do not have to drain the oil if the bike is on the sidestand when removing the alternator cover. They do caution to be ready to catch residual oil (they do not qualify that!
bonnyusa #179828 07/31/2007 10:23 AM
Thanks, that's a great answer. I'll get a plastic sheet and a catch pan as well. I really want to check the air gap AND I want to look at the mount to see if there's any possibility of advancing the timing a skosh like you can do on the Honda Shadow...really improved the response on the old ACE advancing a couple of degrees.
oldroadie #179829 07/31/2007 12:02 PM
Myra in the parts dept. at Chy's new shop was very helpful, gaskets on the way. Thanks again Phil.
Dill #179830 07/31/2007 6:52 PM
Know how you feel Dill, that's just how I feel at this present time, at least I have around the 11000 mile mark on but three igniters is a little much..
birchr #179831 08/01/2007 9:13 AM
So what are we going to do about it?
Is there any hope of procom coming through on the aftermaket cause for 150 or so I would carry a spare but for the 700 that triumph wants I might go looking for another bike.
bonnyusa #179832 08/01/2007 9:33 AM
just for the heck of it maybe try unplugging the tps? before i changed the carbs my bike would have a HUGE miss that only happened sometimes. ever since the new carbs with no tps the bike runs perfect
bonnyusa #179833 08/01/2007 2:27 PM
I cracked the alternator cover and (just guessing) dropped about 1/2 to 1 cup of oil on the floor. Surprise! I didn't know it was going to be wet. I also reused the gasket and didn't have any leaks, but I think I just got lucky.
bonnyusa #179834 08/01/2007 2:37 PM
Has anyone noticed a correlation between fried igniter units and heat? I lost mine when the daily temps were hitting up around 105dF. BTW, I had about 20k on my bike at the time.
Cody #179835 08/01/2007 2:38 PM
It was 90 when mine went on saturday and about 80 when my other went in May. I wouldn't call either extreme heat.
Dill #179836 08/01/2007 3:03 PM
I wonder if procom would get cracking if we ( maybe a hundered) were to put in an advance order?
kennymc #179837 08/01/2007 4:15 PM
Can't undwerstand why they haven't made one for ours yet they have for the Bonneville
Procom CDI's
birchr #179838 08/01/2007 4:43 PM
i just sent them this:
Hello,
I was wondering if there is any hope of your company producing a cdi for the America/Speedmaster series of motorcycles. They are quite similar to the Bonneville family that you already make an after market box for. Except that they have a 270 deg motor rather than a 360 deg motor. The factory boxes seem to have some quality issues and some owners are having multiple failures. There is currently no after market product available so you company would be in a good market position.
If you could please look in this product I know that I would buy one as a spare at the very least. And I'm sure many others would also. If you have any questions for the owners of the America/speedmaster family; BonnevilleAmerica.com forums would be a great place to pose them.
Thank You
Alden Dill
I think if more of us do this it can't hurt.
Dill #179839 08/01/2007 11:26 PM
looks good to me
Frank #179840 08/02/2007 7:48 AM
if you check their website, the bonneville is the only non-offroad bike they produce for. I don't know much about dirtbikes, but am guessing there probably are similarities in the timing, etc which allowed for much easier development of the Bonneville's box.
Mark
LitzerSki #179841 08/02/2007 10:22 AM
Sent my email to them this morning. Litzerski's probably correct but there's no way to know if we don't try.
oldroadie #179842 08/05/2007 4:36 PM
We (the dealer and all of the NH rally crew) learn something interesting on saturday. My bike was in the shop again for a blown ignitor. The dealer had robbed one off an 07 to test my system. Plugged it in and nothing. They traced the entire system and nothing. They were stymied as were we. The verdict was that I need a new bike and we all tromped off to look at a Turbo Rocket. But Pat and Bill (not sure of screen name but from Ont) thought this isn't right and convinced the dealer to pull a cdi off an 05 that was on consignment. Low and behold it had spark. Turns out the 07 igntors were different. This igntor had come off a mulberry 07 that hadn't even been uncrated completely yet. This means that Triumph changed something. And didn't even tell the dealers. Interesting to say the least.
Dill #179843 08/05/2007 11:45 PM
chy Offline
Our Triumph parts catalogue lists several different CDI's depending on year and engine serial#.
oldroadie #179844 08/14/2007 4:07 PM
Here's their reply:
Hello there. We apologize for the delay in answering your inquiries. The engineer has been out town for a few months and has just returned earlier this week. we spoke to him and he said that will not continue the process of making the Bonneville America CDI boxes because of the fact that their are too many OEM part numbers for the stock CDI Box  to keep into account and that the CDI would not work with more than at least two models. The engines may be the same, but the CDI boxes are different. We apologize for any inconvenience.
Regards,
Customer Service
Procom Engineering, Inc.
oldroadie #179845 08/14/2007 4:44 PM
that sux
Frank #179846 08/16/2007 12:41 PM
This is ridiculous. I just called the dealer they got an igniter in early this week. They put it in and it went bad on the test ride so now they are waiting for another one. And triumph north America doesn't have one in stock. So if anyone is keeping track that is almost 2 months that my bike has been down this summer due to electrical gremlins. If I was in the position to ride I would be really much more annoyed. But like I said how can I trust this thing now?
Dill #179847 08/16/2007 1:33 PM
How do they know it was the igniter?
Have the coils, coil wires, and pickup coil been replaced/checked?
