Re: My Thunder Bike Cams
Cowtipper #174492 07/22/2007 7:04 PM
from what i underatand there is a company who has drop in hc pistons for the 865. i believe it was JE but i am not positive. but the 904 is proven with many members on here having great luck with it. by next year i will be able to report how i feel about it
wildmike #174493 07/24/2007 12:31 AM
Winter turned on a beautiful weekend so I managed to get in another couple of hundred kms...
Before this upgrade I never went over 5k rpm, I've found my riding style has changed now cause I just luv being on the gas! accelerating up thru the gears with a carful eye on the taco ( embarrasing to hit limiter) clickin into 4th at around 140kph, and it's time to button off...
For every day riding (cruising) I'm positive it's stronger up thru the midrange, very user friendly...
Machine work on the head was, I thought, very expensive, but without it i'm sure the cams wouldn't have released their full potential...
Head skim, 3 angle grind and material added and removed from the ports, stock valves and springs...
I have no idea as to the specs of the cams but they work for me...
I don't know anybody in NZ who has done a B/B so can't comment on that but do know of several happy people who have had cam and headjobs done...
But maby as Cowboy said...
790 - B/B
865 - Cams and headwork
Safe riding all and roll on spring
wildmike #174494 07/26/2007 12:27 PM
ANybody got info on these high compression BBless pistons?
Jimmy2Bad #174495 07/28/2007 12:23 PM
I don't think they exist, you'd have to rebore or rehone anyway, by the time you buy the pistons for $250-300, a gasket set, and rebore/rehone, you'll be at or above 500 dollars so why not do the 904?
sweatmachine #174496 07/28/2007 5:23 PM
