Page 2 of 5 1 2 3 4 5
Re: CT Tech Day, Part II
Frank #171922 06/18/2007 9:56 PM
1 hour from Cambridge to here...less if 93 is clear from Leo's and trafic
RobBA05 #171923 06/18/2007 10:00 PM
Stop hijacking my thread!!!!
unclecharlie #171924 06/18/2007 11:26 PM
sorry, wasn't intentional
Frank #171925 06/19/2007 9:04 AM
Frank, if you remind me on Tech Day at Uncle Charlie's I'd be happy to go over it with you, etc, if not do it.
bennybmn #171926 06/19/2007 2:53 PM
sounds good, going to try my best to make it there this time. work schedual is changing this week so my hours will be totally different
unclecharlie #171927 06/19/2007 9:07 PM
Just ordered 3 Stebel horns.
1 for me, 1 for Poppy, 1 extra for the 1st one to speak up!
I got an e-mail note that the 3 horns have shipped, 1 is
still available, as is a pair of Progressive fork springs.
Hope for another great turn-out,
Uncle Charlie
unclecharlie #171928 06/19/2007 9:42 PM
Not sure if I can make it... I this past weekend off to go 'pleasure boating' I might have to work that weekend. I'll let you know as it gets closer. If I'm working I will probably need my tools on the boat, but I can drop off the bike lift if you need an extra one.
UC sent you a pm about the springs
cheers -capn
Hold my beer......
capn #171929 06/19/2007 11:55 PM
Pm not received???
unclecharlie #171930 06/20/2007 7:52 AM
weird, just sent a 2nd one
Hold my beer......
bennybmn #171931 06/21/2007 3:52 PM
so this is going to be the 30th?
Frank #171932 06/21/2007 4:13 PM
Yes! Sat 6/30 9am 'till whenever.
I'm not planing a ride for this one, alot to do!
It is "Tech Day" after all. I'll get pizzas for
lunch this time to maximize wrenching efforts.
Snacks and soft drinks will also be on hand.
And the Stebels arrived today, 1 set still available.
They came to $46 each, which includes shipping, and an
installation kit w/relay, wires and connectors.
Let me know if anyone wants any parts or supplies on hand,
I can pick up oil & filters or whatever.
So far:
Brake Fluid, Vac Caps and hose, Fork Oil.
Uncle Charlie
unclecharlie #171933 06/21/2007 8:47 PM
My horn arrived today too! Awe yeah
bennybmn #171934 06/21/2007 9:05 PM
I was thinkin' - maybe I'll put a Harley engine in mine Saturday
Bucky #171935 06/21/2007 9:16 PM
In your basement!
unclecharlie #171936 06/22/2007 11:19 AM
Charlie, I have 130 main jets, d-tool and allen head screws for float bowl and a uni filter. I'd be psyched if we could get the jets in. Let me know what you spend on food, the least I could do is contribute. See you next Saturday.
gilligan #171937 06/22/2007 1:23 PM
Someone else was timmid about re-jetting... We could definitely do it as a tutorial.
gilligan #171938 06/22/2007 8:32 PM
Good time to drill your slides too
Erwin
05 America
Erwin #171939 06/22/2007 8:44 PM
Erwin,
Can you drill the slides with the carbs still in the bike ???
What does drilling the slides do for you ??
John 06 America Mulberry\Silver "Seemed Like A Good Idea At The Time"
Big_Poppy #171940 06/22/2007 9:02 PM
yes but you have to take the top chrome cover off and pull out the slide assy. My set up is TB pipes/130/TBS no shims/3 1/2ish turns out. ever since doing these mods and balancing carbs Ive always had a tiny hesitation when rolling the throttle. Drilling the slide is suppose to give you more vaccume for better throttle responce. Worked great!!
I see your signature states you have an 06, if thats the case ,yours should have the larger diameter hole already.
Erwin
05 America
Erwin #171941 06/23/2007 1:34 PM
I installed the Stebel horn today(sorry, just couldn't wait!). If you want to install the horn in the same position as the old one, you need some washers that will fit the bolt that comes with the horn. The rubber mount is too flimsy. If you want to install the relay where the old AI unit was mounted you need to buy a 3' length of 12-14 ga wire to add onto the fused wire that comes with the install kit.It needs to be soldered.You also need to find that bolt that goes into the mount! Whats nice is that the horn wires will plug directly into the relay without altering. And that's that.
Matt #171942 06/23/2007 2:38 PM
We need a pack of zip ties too. I have some real long super heavy ones I can bring, but I think some smaller ones for tying back hoses and wires is a good idea. Also, the instructions say to keep the compressor vertical, not sure if that will be possible under the seat, but I did figure out how to separate the halves.
bennybmn #171943 06/23/2007 4:10 PM
I have a nice assorment of black zip ties all sizes I will bring them.
Big_Poppy #171944 06/23/2007 4:16 PM
After reading Matts post I have a roll of black wire I will bring just the right size Matt used.
I will bring my soldering kit and shrink tube also.
Big_Poppy #171945 06/23/2007 5:09 PM
Good plan. I have some electrical stuff too.
bennybmn #171946 06/23/2007 8:33 PM
Also you need a crimping tool for the wire connectors, oh yeah a lock washer that will fit the horn bolt. That should be it. You guys know how to adjust the chain? I'm always afraid it won't be aligned. I have the wrenchs for the rear axle. Let me know...
Matt #171947 06/24/2007 9:33 AM
We can do chains. I need do adjust mine... I'll toss my crimping tool in.
bennybmn #171948 06/24/2007 2:08 PM
One more thing with the Stebel. If you want to have the air intake under the tank you need to get a 3' piece of hose that will fit the adapter that comes with it.
Matt #171949 06/24/2007 2:58 PM
I have some hose. I'll try to get more this week. We get it for work and there's always extra.
bennybmn #171950 06/24/2007 6:38 PM
Matt, I have a laser alignment thingy. Can you give me a
parts list(w/sizes), of what is needed(bolts,washers)for
one install? Then I can have the bits on hand.
Thanks,
Uncle Charlie
unclecharlie #171951 06/24/2007 7:17 PM
Stebel horn
for each
2 flat washers & 1 lock washer that will fit the bolt that comes with horn
3' length of 12 - 14 ga wire for an extension on the fused wire
3' length of black fuel line hose that will fit the air intake adapter that comes with the horn
Soldering iron, solder, flux, shrink wrap or tape
multimeter
the machined screw that held AI unit on the frame
I assume you have the wiring kit that comes with the horn
Matt #171952 06/24/2007 8:32 PM
Thanks Matt
unclecharlie #171953 06/24/2007 9:04 PM
The clear tubing I have is 1/4" ID and fits on there snug. I know I have at least 3 feet of it, and I'll confirm how much I can get in a couple days. That being said, it is cheap at the Depot or wherever... I also use it on my brake bleader.
bennybmn #171954 06/24/2007 9:16 PM
Is the 1/4"ID clear tubing what you use for the fresh-air
intake to the horn?
unclecharlie #171955 06/24/2007 10:14 PM
Yep. I tried it on my horn, and it fits nice n snug on there. Some zip ties used like hose clamps would be good insurance too. I think we'll be fine tho.
bennybmn #171956 06/25/2007 7:02 AM
I used black fuel line so it blended in.when I brough it under the tank i made a loop under the fork neck so it stays out of the way.
Matt #171957 06/25/2007 7:18 AM
How do you like it?
unclecharlie #171958 06/25/2007 7:30 AM
It's freakin' loud, dude!
unclecharlie #171959 06/25/2007 10:30 AM
FYI the bolts used for the AI holder are a pretty common thread size on our bikes. I think the one I used is the original, but it may not be. I just pulled it out of my "bolts off bike" bin Point being, there may be some extras laying around Charlie's shop that will work.
bennybmn #171960 06/25/2007 5:45 PM
I picked up a bunch of assorted condoms and 9 feet of black hose today.
OH Baby !!! is it going to be loud in Norwalk on Sat.
Big_Poppy #171961 06/25/2007 6:05 PM
Down Boy!
That sounds dirty!
