 Re: CT Tech Day, Part II
Posts: 3,606 Likes: 2
Posts: 3,606 Likes: 2 |
1 hour from Cambridge to here...less if 93 is clear from Leo's and trafic
THE VOICE OF REASON
per: Stewart
AF&AM/Shriner/Scoutmaster
130/45 TBS 2shim SS Uni 18/42
Posts: 3,099 |
Stop hijacking my thread!!!!
Posts: 23,248 Likes: 64
Posts: 23,248 Likes: 64 |
sorry, wasn't intentional
Posts: 12,877 |
Frank, if you remind me on Tech Day at Uncle Charlie's I'd be happy to go over it with you, etc, if not do it.
Black & Silver '02
Too many mods to list
Not enough miles ridden
Posts: 3,753 |
sounds good, going to try my best to make it there this time. work schedual is changing this week so my hours will be totally different
Posts: 3,099 |
Just ordered 3 Stebel horns. 1 for me, 1 for Poppy, 1 extra for the 1st one to speak up!
I got an e-mail note that the 3 horns have shipped, 1 is still available, as is a pair of Progressive fork springs.
Hope for another great turn-out, Uncle Charlie
Posts: 96 |
Not sure if I can make it... I this past weekend off to go 'pleasure boating' I might have to work that weekend. I'll let you know as it gets closer. If I'm working I will probably need my tools on the boat, but I can drop off the bike lift if you need an extra one. UC sent you a pm about the springs cheers -capn
Hold my beer......
Posts: 3,099 |
Posts: 96 |
weird, just sent a 2nd one
Hold my beer......
Posts: 3,753 |
so this is going to be the 30th?
Posts: 3,099 |
Yes! Sat 6/30 9am 'till whenever.
I'm not planing a ride for this one, alot to do! It is "Tech Day" after all. I'll get pizzas for lunch this time to maximize wrenching efforts. Snacks and soft drinks will also be on hand.
And the Stebels arrived today, 1 set still available. They came to $46 each, which includes shipping, and an installation kit w/relay, wires and connectors.
Let me know if anyone wants any parts or supplies on hand, I can pick up oil & filters or whatever. So far: Brake Fluid, Vac Caps and hose, Fork Oil.
Uncle Charlie
Posts: 12,877 |
My horn arrived today too!  Awe yeah
Black & Silver '02
Posts: 3,971 |
I was thinkin' - maybe I'll put a Harley engine in mine Saturday
Posts: 3,099 |
Posts: 286 |
Charlie, I have 130 main jets, d-tool and allen head screws for float bowl and a uni filter. I'd be psyched if we could get the jets in. Let me know what you spend on food, the least I could do is contribute. See you next Saturday.
Posts: 12,877 |
Someone else was timmid about re-jetting... We could definitely do it as a tutorial.
Black & Silver '02
Posts: 2,525 |
Good time to drill your slides too
Erwin 05 America
Posts: 1,138 |
Erwin,
Can you drill the slides with the carbs still in the bike ???
What does drilling the slides do for you ??
John 06 America Mulberry\Silver
"Seemed Like A Good Idea At The Time"
Posts: 2,525 |
yes but you have to take the top chrome cover off and pull out the slide assy. My set up is TB pipes/130/TBS no shims/3 1/2ish turns out. ever since doing these mods and balancing carbs Ive always had a tiny hesitation when rolling the throttle. Drilling the slide is suppose to give you more vaccume for better throttle responce. Worked great!!  I see your signature states you have an 06, if thats the case ,yours should have the larger diameter hole already.
Erwin 05 America
Posts: 1,457 |
I installed the Stebel horn today(sorry, just couldn't wait!). If you want to install the horn in the same position as the old one, you need some washers that will fit the bolt that comes with the horn. The rubber mount is too flimsy. If you want to install the relay where the old AI unit was mounted you need to buy a 3' length of 12-14 ga wire to add onto the fused wire that comes with the install kit.It needs to be soldered.You also need to find that bolt that goes into the mount! Whats nice is that the horn wires will plug directly into the relay without altering. And that's that.
Posts: 12,877 |
We need a pack of zip ties too. I have some real long super heavy ones I can bring, but I think some smaller ones for tying back hoses and wires is a good idea. Also, the instructions say to keep the compressor vertical, not sure if that will be possible under the seat, but I did figure out how to separate the halves.
Black & Silver '02
Posts: 1,138 |
I have a nice assorment of black zip ties all sizes I will bring them.
Posts: 1,138 |
After reading Matts post I have a roll of black wire I will bring just the right size Matt used.
I will bring my soldering kit and shrink tube also.
Posts: 12,877 |
Good plan. I have some electrical stuff too.
Black & Silver '02
Posts: 1,457 |
Also you need a crimping tool for the wire connectors, oh yeah a lock washer that will fit the horn bolt. That should be it. You guys know how to adjust the chain? I'm always afraid it won't be aligned. I have the wrenchs for the rear axle. Let me know...
Posts: 12,877 |
We can do chains. I need do adjust mine... I'll toss my crimping tool in.
Black & Silver '02
Posts: 1,457 |
One more thing with the Stebel. If you want to have the air intake under the tank you need to get a 3' piece of hose that will fit the adapter that comes with it.
Posts: 12,877 |
I have some hose. I'll try to get more this week. We get it for work and there's always extra.
Black & Silver '02
Posts: 3,099 |
Matt, I have a laser alignment thingy. Can you give me a parts list(w/sizes), of what is needed(bolts,washers)for one install? Then I can have the bits on hand. Thanks, Uncle Charlie
Posts: 1,457 |
Stebel horn for each 2 flat washers & 1 lock washer that will fit the bolt that comes with horn 3' length of 12 - 14 ga wire for an extension on the fused wire 3' length of black fuel line hose that will fit the air intake adapter that comes with the horn Soldering iron, solder, flux, shrink wrap or tape multimeter the machined screw that held AI unit on the frame I assume you have the wiring kit that comes with the horn
Posts: 3,099 |
Posts: 12,877 |
The clear tubing I have is 1/4" ID and fits on there snug. I know I have at least 3 feet of it, and I'll confirm how much I can get in a couple days. That being said, it is cheap at the Depot or wherever... I also use it on my brake bleader.
Black & Silver '02
Posts: 3,099 |
Is the 1/4"ID clear tubing what you use for the fresh-air intake to the horn?
Posts: 12,877 |
Yep. I tried it on my horn, and it fits nice n snug on there. Some zip ties used like hose clamps would be good insurance too. I think we'll be fine tho.
Black & Silver '02
Posts: 1,457 |
I used black fuel line so it blended in.when I brough it under the tank i made a loop under the fork neck so it stays out of the way.
Posts: 3,099 |
Posts: 1,457 |
It's freakin' loud, dude!
Posts: 12,877 |
FYI the bolts used for the AI holder are a pretty common thread size on our bikes. I think the one I used is the original, but it may not be. I just pulled it out of my "bolts off bike" bin  Point being, there may be some extras laying around Charlie's shop that will work.
Black & Silver '02
Posts: 1,138 |
I picked up a bunch of assorted condoms and 9 feet of black hose today.
OH Baby !!! is it going to be loud in Norwalk on Sat.
Posts: 3,099 |
Down Boy! That sounds dirty!
