 Re: Fuel
Posts: 8,639 Likes: 3
Posts: 8,639 Likes: 3 |
Post Script, I did learn about octane ratings here, so thats a good thing. My questions back to ya would be what about carbon deposits? My understanding is that the high grade fuels succumb to higher refinement processes are therefore cleaner burning and typically leave less carbon residue. Is this folly?
Since higher octane ratings mean longer ignition times high grade gas, if anything, will make more carbon deposits. It's not so much that it gets refined more, it just has different additives.
 Re: Fuel
Posts: 23,244 Likes: 64
Posts: 23,244 Likes: 64 |
Thanx Bucky. I have recently been only buying from BP and Hess for that reason and was wondering how much truth was in it.
 Re: Fuel
Posts: 1,337 |
Good to know guys- really- good stuff. THANKS!
 Re: Fuel
Posts: 6,821 |
Aviation and racing fuel 'octane' numbers are an accepted misuse of the word octane. They get those higher than 100 numbers via Benzene, Methane, Ethane, Toluene, Xylene.
It would be a bother to say "well it's like 100 'octane', but 13 clicks better," and so 113 octane it is. In the abstract, it's not too far from "Kleenex" meaning facial tissue.
Hence the term "Octane Rating".
Octane itself,as you mention is a chemical component of gasoline. The amount of octane in the fuel used to raised by "cracking" the gasoline.
When that did not produce enough anti-knock properties, other chemicals were added and the term "octane rating" replaced "octane".
So, when one uses the term "octane" while referring to modern fuels, one is actually using an accepted, abbreviated form of "octane rating".
 Re: Fuel
Posts: 6,821 |
There are exceptions to this practice, where for instance brands P, Q, and R will only sell their own products at their gas stations.
Interesting stuff.
Think you use examples like "brand E" or "brand Ch" or "brand S", etc.?
 Re: Fuel
Posts: 6,821 |
Here in Iowa, officially "The Tall Corn State" we love our ethanol.
I'm rather fond of it myself .
 Re: Fuel
Posts: 3,971 |
'Round here brand E spent x million on a terminal upgrade, then shut it down a few months later. (it's only money, and they have a license to print their own) They're 100% throughput here, and probably save a pile of money by not paying terminal overhead. What must it cost to insure xx million of shore front gas & fuel storage these days? Ouch. Fuel trivia fact #313 - Wish'd I'da bought Valero stock 20 years ago. In buying up old refineries then refurbishing them*, they've now become the single largest refiner in North America. I'd never heard of them until the 90s. They're now #15 on the Fortune 500 list - not too shabby for a company born in 1980. http://www.valero.com/AboutUs/History.htm*No one is building new refineries in the US. When you think of who outside the oil patch could afford to build a few, but doesn't, it's fairly indicative of the way we're over-regulating ourselves back into the stone age. To buy existing refinery footprints like Valero did was fairly genius, in my opinion. Unless motor fuels hit $5 or $6 per gallon, I don't see our thirst for fuel declining anytime too soon. We began to learn our lesson after the embargo, then forgot soon after - not that I'm holier than anyone with a V8 Mustang in the driveway, although it does get 23 MPG on regular.
 Re: Fuel
Posts: 691 |
The non-ethanol fuel seems to get about 5-10% more mileage. When I’ve filled with non-ethanol fuel I normally go 10-15 miles further before switching to reserve than when I fill with the ethanol blend.
I have noticed that too. I was getting 40 mpg on ethanol blend and now get 44 mpg on non-ethanol. I always use 89 octane (mid-grade).
--Tom
 Re: Fuel
Posts: 3,971 |
Lucky you - We're forced to run alco-gas here in the Commie state. Have been for years.  The alcohol lowers the available BTU's, thereby lowering the MPG, thereby burning more fuel per mile. Fuel tax is based upon gallons consumed, so - that means the more fuel we burn, the more fuel tax for the revenuers. Funny how every clean air initiative to get upchucked out the belly of the EPA has resulted in lower MPGs, ever since they began to meddle in 1969. Gosh, It's all about clean air, isn't it !
 Re: Fuel
That and it has lower emissions on 1 gas but higher on everything else.
 Re: Fuel
Posts: 691 |
For all you fuel experts: If I am getting a 10% increase in fuel mileage without the ethanol (about 10%) fuel mix, does that mean that the ethanol provides no energy but only takes up space/volume? If so, why? To sell corn? To make us think we are getting more gasoline domestically?
--Tom
 Re: Fuel
Posts: 3,971 |
I believe alcohol in whatever name they called it then began it's duty in motor fuel service as an air cleaning elixir, as part of the oxy fuels program. (It may have gradually supplanted that wonder potion we knew as MTBE?)
It's now in vogue as a fossil fuel replacement / renewable resource, even though that doesn't quite make economic sense in the acreage required vs. benefit to mankind department. Bush is even encouraging So. American countries to make alcohol as a motor fuel supplement in order to mess with Venezuela's King Chavez.
So to make a long story short, it's a popular political commodity, that lends itself to a variety of games.
Pardon my acute cynicism, but all these 'games' have one primary end result - they raise my cost of living, with smoke & mirrors type benefit.
 Re: Fuel
Posts: 3,017 |
what a waste of perfectly fine ethanol...
Mark
 Re: Fuel
Posts: 948 |
Several years ago an old transport driver told me they put a 'water block' in the pipeline between certain products and that was why it was possible to get water in your gasoline. Wonder if that was an old practice of if he just smelled too many fumes.
I had two uncles that were transport drivers for years-they had some interesting stories.
Redbike7
2006 America
 Re: Fuel
Posts: 6,821 |
Not true at all.
While initially it has that effect, as the technology catches up the opposite is true.
Just look at the performance of modern car and truck engines. They are way ahead of what they were before emission standards thanks to the development of electronic controls.
Chevrolet Corvette: 400 HP and 28mpg out of a 6.0 liter (366ci) V-8.
 Re: Fuel
Posts: 691 |
Hopefully the electronic controls will last longer than 10 years??? and be inexpensive and easy to diagnose and repair???
--Tom
 Re: Fuel
Posts: 7,630 Likes: 7
Posts: 7,630 Likes: 7 |
Just think what kind of fuel milage we could get if they weren't constantly "reformulating" it.
 Re: Fuel
Posts: 6,821 |
Many vehicles and equipment from the late eighties and early nineties still going strong. I expect the new ones are even better.
Hey!!! Mechanics need to make a living too
 Re: Fuel
Posts: 6,821 |
One can only imagine
 Re: Fuel
Posts: 3,971 |
edit - Upon reflection, I deleted the content Coffee is very good this morning - politics in a moto forum - not so good
 Re: Fuel
Posts: 2,626 |
politics in a moto forum - not so good.
Can I get an Amen!
The Hayabusa Killa
Procom CDI
 Re: Fuel
Amen.
 Re: Fuel
Posts: 1,337 |
amen- uh I mean yeesss! you are correct, sir!
 Re: Fuel
More trivia - I would advise to avoid fueling up while the truck delivers at the station. Dumping fuel could well stir up the small volume of water (from condensation) that is on the bottom of most underground storage tanks. Water is a known and managed commodity in USTs, and is usually of no concern as the pick up tubes are well above the tank's bottom, and many gas stations pumps have water occluding 'Hydro-sorb" type filters inside their shell, but I feel better waiting a half hour to let the water settle. Call it superstition I suppose.
My Cousin told me a long time ago to not even stop at the station if you see a fuel truck there.
