Airbox snorkel
#166487 05/29/2007 3:22 AM
Hi all,
Would somebody please tell me if I am right to assume that the airbox snorkel is installed only to reduce air intake noise? I can't for the life of me believe it fills any other function.
My dealer said screw around with the snorkel and you will have a mid-throttle flat spot. My feeling is if I use Pat's handy dandy calculator and rejet, or shim, or both and only if I have developed a flat spot I will not have a cronic problem. What say you all and thanks for this fantastic web site.
Blueback -Canuck
Re: Airbox snorkel
blueback #166488 05/29/2007 9:41 AM
Just pull the snorkel out completely. It will allow more air in and your bike will run better. You are not going to have to re-jet from just yanking that thing out.
Re: Airbox snorkel
Soren #166489 05/30/2007 12:28 PM
hey bro i tried the bike without the snorkel runs faster which is a bonus but really splutters
did you re block the airbox after taking of the tube?
Re: Airbox snorkel
Soren #166490 05/30/2007 1:44 PM
I disagree. I did that and it leaned out the top end considerably. I was running short TORs at the time.
Re: Airbox snorkel
FriarJohn #166491 05/30/2007 2:49 PM
I agree with Friarjohn again,with less restrictive pipes and more air you should rejet. These bikes come from the factory lean to start so in my opinion and increase in air flow should be accompanied by jetting. Lean can hurt the motor.
Re: Airbox snorkel
The_Dog33 #166492 05/30/2007 5:11 PM
what about if you plug the hole thats left by removing the snorkel from the airbox
that should keep jetting normal me thinks
it picked up speed quicker than with it conected
yesterday i throttled the bike to 140kph
today same stretch of tarmac and i was up to 150kph
if you are wondering the limit was 60kph
a bit of a change from my speed triple i used to go down that stretch at 200kph before selling it really miss my speed trip
Re: Airbox snorkel
melvin #166493 05/30/2007 7:12 PM
At that point I'm pretty sure there would be no air getting in at all. But I could be wrong...
Re: Airbox snorkel
FriarJohn #166494 05/30/2007 7:19 PM
Might run pretty rich if you plug that up.
Re: Airbox snorkel
oldroadie #166495 05/30/2007 9:15 PM
But the noise would be gone!
Re: Airbox snorkel
nologic #166496 05/30/2007 10:03 PM
I guess there wouldn't be any noise without the engine running.
Re: Airbox snorkel
melvin #166497 05/30/2007 11:00 PM
...really miss my speed trip ...
Man, I hear ya. A lot less happens when you twist the throttle on these... I've had mostly sport bikes up to now. Of the "cruisers" I have owned before were a VMAX, V45 Magna, V65 Sabre and Magna. Those don't really count, though LOL. This is my first real cruiser and I miss the 135+ hp in hand. I miss power wheelies, too.
However, I don't miss
    the numb hands
    sore wrists
    tendinitis in my elbows
    a crick in my neck
    3k miles from a set of tires
    6k on a set of brakes/sprockets/chains
    whining wife while trying to sit on that acorn size/shape excuse of a seat
    every biker boy in town wanting to street race and willing to kill me over it
    idiots wheeling beside me-while sharing a lane
    tickets in a no-tolerance state
    rednecks and dirtbags shouting, "hey maing, pop a wheelie!"
    the local, "it's a black thing" thug biker group
    stupid insurance rate because the plastic fairings are worth more than the bike
    no originality- they look the same no matter how much you modify them...
Enjoy your new wheels, brother. It is a different ride with different joys and different reasons for doing it.
Re: Airbox snorkel
The_Dog33 #166498 05/30/2007 11:55 PM
Agree as well. I had stock pipes and pulled the snorkle. Stuck it back in soon as I could get back in the garage. Too lean.
Re: Airbox snorkel
rwright #166499 06/01/2007 5:15 PM
well i plugged up the hole put on a filter on the end of the snorkel tube and it has slowed down the popping
still picks up quicker
though to get to top speed i do take a nap on the way to 180 kph
Re: Airbox snorkel
melvin #166500 06/02/2007 12:04 AM
am I alone or does that make little or no sense? If I read that right Melvin is running at full choke all the time. If I am wrong enlighten me.
Re: Airbox snorkel
The_Dog33 #166501 06/02/2007 3:03 AM
no it's not running at full choke
wot i did was plug the tube left by the snorkel and the popping has been reduced
the hose is now conected to a K&N filter
the bike picks up quicker than before and has less popping or backfire from the motor as i throttle down
i'll post a pic of the bike with the new pipes and filter fitted ok
Re: Airbox snorkel
melvin #166502 06/03/2007 7:18 AM
got some pics posted in the pics section
shows the short pipes and the snorkel re-conected to the filter
Re: Airbox snorkel
melvin #166503 06/03/2007 8:01 AM
Maybe I'm a dumbazz but Melvin's photo labeled snorkle_contected looks a lot more like a crankcase breather than the snorkle that came off my airbox.
Re: Airbox snorkel
oldroadie #166504 06/03/2007 8:42 AM
is'nt that the snorkel conected to the crankcase breather?
if not then what is the snorkel enlighten me please
Re: Airbox snorkel
melvin #166505 06/03/2007 9:24 AM
the snorkel it the rubber intake tube that sits on top and goes down into the air filter
Erwin
05 America
Re: Airbox snorkel
Erwin #166506 06/03/2007 9:31 AM
Look under your seat. It's the ribbed rubber tube that feeds the air box. It's very restrictive and pops out easily. Just give it a tug and then grab the throttle
Re: Airbox snorkel
oldroadie #166507 06/03/2007 9:36 AM
but does it need rejetting once removed
Re: Airbox snorkel
melvin #166508 06/03/2007 11:03 AM
I didnt.
Re: Airbox snorkel
melvin #166509 06/03/2007 11:09 AM
You might need to turn out your airmixture screws a bit.
Erwin
05 America
Re: Airbox snorkel
Soren #166510 06/03/2007 11:09 AM
well i've taken it of i will report my findings when i get back from my house in spain to my apartment in gibraltar
about 20 kilometers
hopefully i will find it more powerfull
by the way what sproket size doe the america have 16 or 17 as others say 18 gives you more mid to top end usability
Re: Airbox snorkel
melvin #166511 06/03/2007 12:15 PM
ok just got back 180 no pobs removal of snorkel works
