Re: FREAK SURVEY ?
Dinqua #15066 04/06/2006 9:52 AM
They do not fit right, at least every single one I have seen needs some mods/bending/grinding/swearing to get it to fit and hold the covers on correctly.
Pat, I have to disagree. I had to bend and swear, but I didn't have to grind. Well..wait, that isn't technically correct. I used a flat file to touch up the plastic tab on the right side faux cover so it would go more easily into the rubber grommet hole. So, I guess you are right. The instruction sheets should include a short list of requirements; strong hands, a grinder, and the vocabulary of a sailor.
Cody
Re: FREAK SURVEY ?
BonnyBeemer #15067 04/06/2006 11:07 PM
Dinqua,
Here's how I cut my left side cover. You can't see anything under the cheese grater & the exposed part still looks stock. None of the mounting areas are affected
I did have to twist the Freak a bit & I thought $300 was a bit steep, but I couldn't have built it myself until after I saw what I was installing... I wouldn't take it out though, that's for sure.
Re: FREAK SURVEY ?
FRYGUY #15068 04/07/2006 4:58 PM
Gents,
You guys have some great ideas for getting air through the FREAK. I'll get right on that. As for the kit, I had no problems installing and haven't even had the clank problems yet. Brent, I think you made a ****** good little product...Joe
Re: FREAK SURVEY ?
Jack_D #15069 04/08/2006 11:15 AM
I have the FREAK. I also have BUBS dresser dog/megaphone pipes and have rejeted. There is a huge difference in performance, with a little degradation in gas mileage. Well worth the price IMHO. I have not had the K&N filter problems falling off as some here have. I just took the plastic toolbox out and left that space open.
I have the same setup. Except I have Bub Slash Cuts. Same results no toolbox. I gotta hang on!
Re: FREAK SURVEY ?
kennymc #15070 04/10/2006 4:17 PM
I installed mine over a year ago, got the T pipes, and then took it in and had it dyno'd. I didn't dyno before installation, but you can tell the difference, no doubt about it. I like the "kit" concept, because I am not that mechanically inclined, it came with easy to use directions, I'd do it again (thanks, Brent!)
Faye 04 America
Re: FREAK SURVEY ?
Faye #15071 04/10/2006 4:47 PM
what were your #'s faye? and what jetting you have
