 Popping on deceleration
Posts: 2,150 |
I noticed that Pat with his new mikunis explained how he had some popping on deceleration. Now I only recently adjusted my air pilot screws from 2 3/4's to 2 1/2 and have noticed whilst I have fixed the slight hesitation when taking off from idle and she now has better acceleration, there is just a little bit of popping when decelerating. Can anyone tell me if this is a problem and if so, what should I do about it? thanks guys
 Re: Popping on deceleration
Posts: 438 |
It's not really a problem if it's minor and doesn't bother you too much. It can mean that you are running a little lean as well, so check your plugs. Sometimes you have to trade a little popping for max performance.
Not you fat Jesus!
Posts: 1,836 Likes: 5
Posts: 1,836 Likes: 5 |
And if it continues to bother you - Just don't slow down
Posts: 1,337 |
You can try going up to a 45 pilots. Also check for any exhaust leaks.
Posts: 2,150 |
thanks for that. No it doesn't bother me at all really, I just wanted to know what it meant. Funny though, when the mixter screw was a 2 3/4's it smelt a little bit fuelly when idling she wasn't quite running right. I adjusted to 2 1/2 like I said and now may bit a bit lean. Now having spoken to you, I think she might be about right. Regards the plugs, I had looked at them a couple of weeks back and they were definitely on the dirty side so it all adds up to be fine I reckon. I'll check the plugs in a couple of weeks and wouldn't be surprised if they were much lighter.
Posts: 12,164 Likes: 1
Posts: 12,164 Likes: 1 |
With the pipes I have, that popping can kinda get loud. I like it when I am in a tunnel, especially if there is someone next to me on their cell phone.
Posts: 2,297 |
I have the same Soren. It is cool sometimes. I am going to re-pack my very open baffles to see what effect, if any, that has on the popping.
Posts: 6,308 Likes: 4
Posts: 6,308 Likes: 4 |
Ryan and Staffo, I got rid of 90% of the popping today. Doh! My right hand carb manifold's squirrel condom was pretty loose and was leaking I guess. I just jump-hosed the manifolds with 3/32" tubing and bingo!
Ryan, I know you have BGs nice SS manifolds so not sure what to do with yours - maybe turn the one air screw out a pubimeter? - I remember they are only at about 1/8 turn already and are very touchy.
Pat
Posts: 131 |
Just want to make sure I got this straight. Popping on decel is usually a sign of being too lean?
Put in TBS needles yesterday. Got the extra punch in the midrange as advertised. I also got more popping on decel, which confuses my little brain since I just made things richer. AI is out.
My set up: 06 TBA: Thunderbikes, 42, 132, AI out, TBS, top snork out.
Thanks.
Posts: 2,297 |
Extremely touchy!
Posts: 2,297 |
Thanks.
Did you shim the TBS needles?
Posts: 131 |
Thanks.
No, just dropped em in.
Posts: 151 |
Have you removed AI system? Air injection produces lot of popping also with rich carburetion.
Posts: 131 |
yes, AI is out.
Posts: 1,138 |
John,
Anytime you mess with the carbs, you should re-balance the carbs. There are two on Brents site and there is a link in the tech vault on how to make your own.
I went with Brents cheap on and it works great. You will not believe the difference balanced carbs make not saying it will get rid of the popping on decel.
I actual think it is cool I gave up trying to get rid of it you can but you end up with the flat spot on the low or mid range. I have my screws three turns out and he runs like a raped ape.
John 06 America Mulberry\Silver
"Seemed Like A Good Idea At The Time"
Posts: 1,337 |
You made it richer in the midrange. The needle does not affect your idle. The needle enters the fuel circuit at about 1/4 throttle and is out of the circuit at 3/4 throttle. Try going to a 45 pilot. Also check the vaccuum plugs, i.e. squirrel condoms, and look for exhaust leaks.
this is a good source for carbs and how they work...http://www.motorcyclecarbs.com/carbs101.pdf
Posts: 131 |
Thanks guitarted. That helps.
So, to make sure I have it straight: With 132 mains and 42 pilots, I could be lean in the pilot circuit, good in the midrange and a bit rich at full throttle?
Thanks.
Posts: 3,606 Likes: 2
Posts: 3,606 Likes: 2 |
ok here we go again...a PROPERLY tuned motor with high performance pipes WILL POP in DECEL....
From the mikuni site....
Note: It is normal for many high performance exhaust systems to moderately backfire or pop when the throttle is closed from mid-to-high rpm. In fact, one should expect a well-tuned high performance engine to "pop" and "crackle" when the throttle is closed at high rpm. One thing that should be pointed out is that while the throttle may be closed, leaning up the mixture, and it may take several revolutions of the engine to build up a burnable mixture in the pipe, the engine will still be running at a high enough RPM for the ignition advance curve to be advancing the ignition. So, if you have an ignition system that fires a waste spark, it's going to fire that spark during the valve overlap period on one of your four cylinders, and that's enough to make the exhaust backfire.
The popping is a result of the air/fuel mixture becoming very lean when the throttle is closed and the engine is rotating well above idle speed. It is also necessary that the exhaust system have rather open mufflers.
Why This (normally) Happens:
1) When the throttle valve is in the idle position, fuel does not flow out of the main system (needle, needle jet, main jet). Fuel is only delivered to the engine by the pilot (idle) system. 2) The combined effect of the closed throttle and elevated engine rpm is to create a fairly strong vacuum in the intake manifold. This vacuum, in turn, causes a high air flow rate through the small gap formed by the throttle valve and carburetor throat. 3) Under these conditions the pilot (idle) system cannot deliver enough fuel to create a normal, combustible air/fuel ratio. The mixture becomes too lean to burn reliably in the combustion chamber. It gets sent into the exhaust system unburned and collects there. 4) When the odd firing of the lean mixture does occur, it is sent, still burning, into the exhaust system where it sometimes ignites the raw mixture that has collected ---- the exhaust then pops or backfires.
your engine, rather because it is an indication of lean and running so can burn your exhaust valves everyone thinks it to be a bad thing.
Tuning your bike richer means an excess of fuel and very little to no oxygen. Thus the unburned fuel passes through the pipe without ever igniting. So you can think of the popping as a sort of environmental control on your bike, combusting excess fuel that would have otherwise not gotten burned.
THE VOICE OF REASON
per: Stewart
AF&AM/Shriner/Scoutmaster
130/45 TBS 2shim SS Uni 18/42
Posts: 1,337 |
Thanks.
No. I was trying to make the point that you didn't affect the idle circuit when you changed the needle.
Hey Rob, thanks for posting that. I did no know, now I do. Very Cool!
Posts: 2,150 |
now just remember I'm new at this thing also but maybe cos as the popping is happening with no throttle open as you are decelerating, you are only lean due to you air idle screw needing adjustment out. From what I've read, the tbs (which I have also) are effective midrange therefore having no impact on deceleration. Just how I see it and am happy if someone tells me I'm talking crap.
Posts: 2,297 |
Rob, very good stuff. Pop goes the blue Trump through Central Florida!
No Problem....just remember if you DO get rid of it all( the poppin)...(and you can)your running RICH on the low end...
THE VOICE OF REASON
per: Stewart
Posts: 2,150 |
Rob, I reckon you are right on that one. Mine only pops (so to speak) in only a minor way and my bike has never ridden so well. I think it's spot on, so it's nice to know what these little symptoms mean so we can get optimum performance and economy.
Posts: 2,297 |
I know what you mean. My bike pops quite a bit no matter the RPM, but I have tons of torque and power across the throttle. Perhaps, a richer needle could eliminate some of the popping at the lower end, but I am not sure of making that change. With the carbs and 904 kit, it takes me a good 3 minutes or so to warm up the motor.
Posts: 9,223 |
Mine is popping also so I've given up trying to remove it. Now I just enjoy! 3 minutes! I guess we know who's getting up earlier than everyone else in GA, eh?
Posts: 23,200 Likes: 56
Posts: 23,200 Likes: 56 |
My SM doesn't pop much at all. Its all in the idle mixture screws and pilot jets. It does pop a little every once in awhile but under normal easy conditions it doesn't.Freak...155 main 48 pilot ...AI removed....gutted stock pipes...dyno at 13ppm pretty much perfect air fuel mixture. took some playing to get it there.
Posts: 9,223 |
Every big bore I've seen burbles a bit no matter what you do with jets or needles. It's no big deal.
Big 10-4 on that statement Phil.
Pat
As it should, if it's properly tuned...if you did manage to get rid of it all (according to Mikuni) you would have a overly rich pilot circuit...
THE VOICE OF REASON
per: Stewart
Posts: 2,525 |
I ended up turning out my mixture screws out to 3 1/2 turns out. 90% gone
Erwin 05 America
Posts: 2,297 |
Yep, our rather open pipes are a big factor. POW-POW!
like I said mine does just a little but 90% or better gone. it does rumble a little on deceleration. But not that popping sound. According to my dyno runs it is dialed in as close to perfect as you are gonna get. small dip in mid range but that is pretty much normal with open pipes. air fuel is at 13 pretty much across the board.
Posts: 9,223 |
Try dropping in needles from a ThunderBird Sport (TBS). You will probably lose that dip.
I was wondering about the needle changes. Do I need to shim them or anything? Or change jets again? Use different spring or diaphram?
Posts: 9,223 |
Nah, I would just do the needles first. No shim. The profile is not a whole lot different that the stocker but just different enough where a lot of people have reported losing that lag, including me.
Cool. Thanx for the info I'll give it a shot and let ya know what it does for us.
TBS needles DEFINATELY helped my mid range flat spot (dip) just pull the old (stock) one out and drop in the TBS...you may need to adjust the air mix...but only slightly
THE VOICE OF REASON
per: Stewart
1 other question what year Tbird?
never asked...just told the Stealer I needed TBS needles they ordered them ($14.00) droped them in...done
THE VOICE OF REASON
per: Stewart
