Re: Alternate foot peg location
unclecharlie #104975 10/26/2006 6:52 PM
Sorry, I can't figure out how they attach in detail. can someone help?
Bill #104976 10/26/2006 7:17 PM
I misunderstood what Bill was asking, and changed my post.
vdanger didn't though........... and took care of it.
KANSASBOB #104977 10/26/2006 8:40 PM
Unfortunately, my digital camera just went on the fritz so I can't post better pictures just yet. I'll try to get some in a day or two.
However, I will try to describe it. You see in the photos the two chrome bolts that hold on the passenger footpeg bracket? If you remove those bolts the passenger footpeg bracket comes off and you are left with two threaded bosses that are welded to the frame of the motorcycle.
I took a 1/4" thick steel bar (about 2" wide) and drilled two holes with the same spacing as the threaded bosses along the centerline of the bar (on the 2" wide side). Then, if you line these holes up with the threaded bosses, the bar will be angling downward and towards the front of the bike. The Passenger footpeg bracket is then bolted back into place (with longer bolts) OVER this flat steel bar.
Welded to the bottom end of the flat steel bar is a piece of square steel tube that extends forward along the bike right above the muffler. Attached to the front end of this square steel tube are a standard set of Triumph folding passenger pegs.
Hope this makes it a little easier to visualize.
Vance
- Before you criticize a man, you should walk a mile in his shoes. That way, when you do criticize him, you will be far away and have his shoes -
vdanger #104978 10/26/2006 9:52 PM
I got the visual, but how did you attach the pegs? Just a couple tabs?
bennybmn #104979 10/26/2006 11:20 PM
I welded a piece of 1/4" plate to the front of the square tube. It sticks out about two inches beyond the end of the tube. Drilled a hole in the flat plate for the mounting screw of the Triumph footpegs.
Vance
vdanger #104980 10/27/2006 10:23 AM
Oh ok, much simpler than I was thinking. I forgot the whole peg bracket comes off
