OK, about to wire up my Kury Silver Bullits , the paper says these will add a 4 amp draw (I will probly go to LED eventually) so my question is this - if I go straight from a buss real close to the battery, and switch it at my console will I need a relay? The housings are self grounding so I'll switch the pos. wire.
I'll probly have a 10 A fuse, and the wire size, maybe 16 ?
Or is there enough power in the headlight bucket to pull from it? I did go to an LED headlight so I can cheat a bit.
Thanks for the expert advice in advance.
