Throttle Position Sensor?
#504973 11/05/2012 9:57 AM
Our friend Gary (SMWasp04), tells me his bike was in the shop recently for a bad TPS....said the shop (Polaris West)(Triumph dealer, Katy, Tx) wanted $2K for new carbs?
Then found an aftermarket part installed for $400....
I can't find the former posts on the TPS, but I remember some had disconnected theirs...I even did the same for a while, I think.
Can anyone help with a link to those old posts?
Keith
Houston
Ridin'Texas
'04 Speedmaster
2020 T120 Black
Re: Throttle Position Sensor?
Blackwind #504974 11/05/2012 10:07 AM
Keith #504975 11/05/2012 12:35 PM
Thanks, Keith and Keith. I wish I had known to try this disconnect before I had it towed to the shop. They said the faulty TPS was sending a bad signal to the computer and that was why the timing was off and the backfiring through the left carb.
Yeah, $2043 for a pair of carbs from England. You have to replace the whole carb to fix the TPS, they act as a unit and are tuned to each other according to the Triumph guys. Do I hear scam?
-- Gary
smwasp04 #504976 11/05/2012 12:51 PM
all you need to know about TPS is here
TPS
Grzegorz #504977 11/05/2012 1:01 PM
buy some aftermarket carbs or set used ones
