hi does anyone know if you are supposed to get a 5volt, reading from the plug going to the ignitor, its the number four wire on my diagram , which says +5v external sensor supply, with ignition on i am getting nothing, also no live at the clutch cut out switch fitted a new pick up coil but still not sparking
lowered 2 in stretched front ,widened front forks, aubergine black pearl paint 40 ford rear light standard exhaust all baffels removed, pods, 155 main, 45 pilot, thruxton needle, 16 tooth sprocket procom ignitor set to no 5
