Bobbing rear fender
#432535 03/09/2011 6:08 PM
game_on Offline OP
This will probably sound like a stupid question...but my new tailight just came in and I can't wait to start slicing the rear fender. The only problem is I have never done this before. I know I can cut following the line I mark but I am not sure what to cut with. My plan was to use a pneumatic cut off wheel. Is this the best way to go? Or is there something better to use?
Re: Bobbing rear fender
game_on #432536 03/09/2011 7:22 PM
I used a dremel type tool. It is ozito, about 1/4 the price and all dremel attachments fit. Mark off the area and go slow with a fast cutter speed.
Lots of passes going deeper each time, don't cut all the way through at the start.
ozspeed #432537 03/10/2011 11:21 AM
I all ways wanted a cutoff wheel after watching OCC...so I got one and hacked away...oh put down some tape all over where you are cutting and mark the tape and cut thru the tape...
SDKimo #432538 03/10/2011 11:24 AM
I think I used a mini cutoff wheel and fine-tuned the edge with a sandpaper wheel on a bench grinder. But I didn't go with a straight cut and it took a while to get both sides to match.
FriarJohn #432539 03/10/2011 12:51 PM
For an even layout on both sides, you have leave the fender on for this method, use a string from for instance a hard common point on both sides of the bike such as the center of the top rear shock mount, you can triangulate an exact common point from there using a tape measure and level. I hard scribed exactly the finish cuts, but cut 1/16th long, you can finish up with a mill file right to the scribed line in a few minutes, no heat generation to foul the paint that way, touch up paint the cut line and your done. BTW, get the bike sitting sitting level and plumb on a stand or some wood or whatever ya got first.
Ryk #432540 03/13/2011 5:18 PM
game_on Offline OP
Thanks for all the input, nothing like learning and doing on the fly.
ozspeed #432541 03/13/2011 6:23 PM
I live in the sun downunder
Hey Stephen, have you got a link as to where you got the rear tail light?
I was going to get one from the USA, but if I could get one in OZ it would make it a lot easier.
FrankW #432542 03/13/2011 6:56 PM
FrankW #432543 03/13/2011 7:16 PM
BJ's in Brisbane sell them as do Trojan in Sydney do also, they are copies not the originals, I have an original 1 I run on my bike, they sell for around $65 here with the lens there are lots on ebay Frank
midnight7503 #432544 03/13/2011 8:03 PM
Thanks Stephen, I will have a look.
Bellacorse in the USA don't do International shipping.
FrankW #432545 03/13/2011 8:41 PM
Some units don't come with the black rubber foot that goes between your fender and the casting, make sure they include that as to protect you paint.
Ryk #432546 03/13/2011 9:42 PM
Good point, I will watch out for that.
FrankW #432547 03/14/2011 7:43 AM
I got mine on ebay..it is a copy but works well.
I paid about $70 to my door in W.A.
I got the clear lense covers from ebay uk...6 days from UK to W.A.
Zen would ride a Triumph
ozspeed #432548 03/25/2011 2:08 AM
Frank the ones that newbonneville sell i believe have Triumph connectors so they are just plug and play no wire splicing needed
What goes round comes round
