Closest SAE socket size
#383896 04/03/2010 2:57 PM
nologic Offline OP
Hi guys. I'm going to change my front sprocket and was wondering if there is a SAE socket size that can be used in place of the 38MM?
Re: Closest SAE socket size
nologic #383897 04/03/2010 3:23 PM
Can't help you out, but if you're going to convert SAE to metric, might as well have the right size. I believe the socket is 36mm for the front sprocket...
jass #383898 04/03/2010 3:40 PM
nologic Offline OP
Yup, you are right. 36 mm. I just thought that if an SAE fits (as some sizes do) I could save a buck. Thanks.
nologic #383899 04/03/2010 4:07 PM
36mm is just a hair shy of 1.5 inches.
mrt202 #383900 04/04/2010 2:10 AM
36mm is precisely 1.417319 inches. 1.5" would be a bit sloppy I'm thinking. That would be about 1 13/31" which is a bit smaller than 1 3/8." Hmmmm is there an SAE that would work?
nologic #383901 04/04/2010 8:43 AM
I have that socket if you want to ride over to Ixonia to change out the spocket.
nologic #383902 04/04/2010 9:43 AM
Sears has them for around $10. Autozone or Pep Boys should also carry that size for a few bucks less. Although in SAE of that size, it wouldn't do any harm at all and fit nicely.
mag10 #383903 04/04/2010 11:54 AM
nologic Offline OP
Thanks for the offer but I'll just go buy one. That way I'll have it if I need to change it again. I was a mechanic for many years but wound up off the floor before the big metric push hit. I have a ton of tools but nothing that big in metric. Thanks guys!
nologic #383904 04/04/2010 9:11 PM
Many of the big auto parts chains stock 1/2" drive 36mm sockets intended for servicing car hubs. It's a good tool to have on-hand.
Keith #383905 04/05/2010 8:29 AM
Sloppy, yes but will work in a pinch. After checking some more i found that 1-3/8 is too small, but 1-7/16 will work perfectly.
mrt202 #383906 04/05/2010 3:35 PM
nologic Offline OP
That one I have. Thanks man!!!!
