chain tension
#25198 10/16/2005 11:29 AM
Frank Offline OP
what is the proper slack for the chain? i know it is 20-30mm but anyone have an idea what that would be in say inches? lol i am super busy and dont have time to look now so i figure i ask and have an answer when i can get back. sorry for asking such a simple question just not to much tme right now. thanks guys
Re: chain tension
Frank #25199 10/16/2005 11:40 AM
One inch give or take.
Re: chain tension
piper1 #25200 10/16/2005 2:25 PM
Frank Offline OP
thank you sir . oh and another thing. i adjusted it and used the lines on the adjusters to make sure its even. thing is i remember reading those marks are off. anyone have anyother techniques of makeing sure the wheel is nice and straight?
Re: chain tension
Frank #25201 10/16/2005 3:00 PM
Sears carries a number of measuring calipers that could greatly assist with measuring your chain adjuster. They range in price from around $7 for the pocket job or over a $100 for a pro digital model with metric dial ones that fall somewhere in between. Have a look at Sears.com and search under "calipers"
Of course there is also the laserline method between the front and rear wheel axels OR a string plumb if you don't have the laser.
Definition of Insanity: "Doing things the same way over and over and expecting different results."
Re: chain tension
jaymo54 #25202 10/16/2005 3:05 PM
Use the Wheel Alignment method below for reference.
Re: chain tension
jaymo54 #25203 10/16/2005 3:08 PM
...and here's yet another wheel alignment method.
Are you bored silly yet?
Re: chain tension
jaymo54 #25204 10/16/2005 3:14 PM
Here's a cool alignment device for the Harley boys. Anyone feel like jury rigging one of these babies for the TBA/Speedmaster. Interesting read anyway.
ENOUGH! Anyone else?
Re: chain tension
jaymo54 #25205 10/16/2005 11:24 PM
Forgot the Hardley Link... wheel alignment device
Re: chain tension
jaymo54 #25206 10/17/2005 6:31 AM
Frank, Piper is right. 25mm equals 1 inch.
Re: chain tension
Frank #25207 10/17/2005 12:23 PM
What I have found is that with the chain properly adjusted (on my bike anyway) it will just barely touch the bottom of the swing arm pad. This is right at 25mm. I prefer to run my chain a tad on the loose side as I am AHEM... a bit on the large side. A little loose is FAR better than a little tight.
Also, depending on what kind of chain lube you use, always check and adjust the chain BEFORE you squirt on your favorite slick stuff. Using PJ1 myself, after I adjust the chain I lube it and once the lube has set up, I have only about 7mm of slack on the chain. However after riding for about a mile, say to the local Stop-N-Rob, the chain is back to normal.
2002 Bonneville America 1995 Speed Triple STC 1996 Speed Triple 1999 Daytona 1200 SE (2) 1998 Sprint Executive
Re: chain tension
Frank #25208 10/18/2005 2:32 PM
Turn both bolts 1 side (1/6 turn) at a time to keep the original alignment.
Re: chain tension
Frank #25209 10/19/2005 9:46 AM
Count the threads on each adjuster with a toothpick. Or use a calibrated measuring device. Greybeard's suggestion works, if and only if, the adjusters are even to begin with. Make sure the adjusters are seated against the adjuster brackets too.
Re: chain tension
moe #25210 10/19/2005 9:51 AM
Frank Offline OP
i have a micrometer but it is tough to fit in a position to measure both sides. i have put about 100 miles since i adjusted it and seems fine. so i am just going to lave it.
