 Sticky throttle (sometimes)
Posts: 485 |
I have an intermittent problem with a sticky throttle. It doesn't do it all the time, but I can tell as soon as I start the bike that it's going to be a problem on a given day. The bike runs fine, but it just feels like something is binding in the throttle, or is catching when I twist it. When it is acting up, I can let go of the throttle and it won't spring closed (kind of like cruise control). The bike's still rideable, but I'm kind of "jerky" with it because of the force it takes to twist it. It usually works itself out eventually, but not during the ride. It seems to stay around for a few days usually. Then one morning, I'll start it up and the throttle will be working fine again. Any ideas or things I can check?
Thanks. Will
 Re: Sticky throttle (sometimes)
Posts: 5,537 |
Loosen the two allen-bolts on the handlebar housing beside the throttle. I moved mine for new mirrors and discovered you can slide the housing right or left. You can actually move it up against the throttle to hold it in place. Did you make any adjustments lately, that could be the cause. Just loosen those two bolts and wiggle the housing slightly to the left.
Posts: 555 |
Did make any changes your handlebars (like adding risers? ) Also, the throttle thumb screws adjusters on the housing could they be too tight?
Posts: 485 |
I haven't made any adjustments or changes in that area. I'll take a look at the housing this evening and see if it just needs to be adjusted. FWIW, it's working great today. Thanks for suggestions. Will
Posts: 485 |
Thanks ssjones; you nailed it. I loosened one of those allen bolts and put a gap about the width of a dime between the throttle grip and the housing. Seems to work perfect now. Just in time for a ride to the parkway tomorrow. Thanks for the help.
Will
Posts: 5,537 |
Will
Well now you know how to have a nice, cheap, cruise-control if needed. I can snug mine up so it holds the throttle for about 30 seconds. Just the right amount of time to scratch an itch with my right hand or just give my hand a shake on long trips. Enjoy your ride!
Posts: 287 |
My throttle got sticky one day after washing my bike...i just loosen'd the trottle and moved it in a gazzillionth of an inch...problem solved...
Posts: 163 |
my throttle was that from the factory, and I mentioned it to them when i got it and they say some bikes are just like that when they get them. Bring it to your dealership and they'll take care of it under warranty
