Flashing LED Taillight - Opinions sought
#229701 01/08/2008 1:45 AM
It's been a long time coming but I believe I've finally worked out a circuit to add flashing brake lights to my LED Taillight project. It works by flashing the brake light between 1 and 10 times then turning the brake light on until you release the brakes. The number of flashes is user settable at this stage, but when finished will probably be hard wired in to about 4 or 5 flashes. It also incorporates a 'decay' so that the number of flashes is reduced when applying the brakes frequently eg: in heavy traffic.
If you're familiar with my project you'll know I currently have six high power LED's for the normal tail light/running light, and a further 12 high power LED's surrounding them for the brake light, as shown below.
Tail light/Running Light mode
Brakes + Tail light/Running light
Have your say in the poll below. Any other comments, thoughts, suggestions etc are welcome.
All or nothing? Or a bit of both?
single choice
All LED's should be on all the time; Dim for tail light, bright for brakes (23%, 8 Votes)
Six LED's for the tail light, another twelve for the brakes (60%, 21 Votes)
Huh? What's an LED? Just gimme a beer. (17%, 6 Votes)
Total Votes: 35
Voting on this poll ends: 01/13/2008 1:00 AM
Re: Flashing LED Taillight - Opinions sought
Sandmann #229702 01/08/2008 7:08 AM
I use the TailBlazer tail light bulb on my bike. Same type of concept as whet you are doing with the flasing LEDs. I think the flashing LEDs will be even much better than the TailBlazer bulb. Very cool idea! The more you can attract cagers attention, the better.
Soren #229703 01/08/2008 9:35 AM
I up for anything that increases awareness behind us so I think (short of an aircraft landing light) the more annoying the better.
oldroadie #229704 01/08/2008 4:19 PM
i am with him
Frank #229705 01/08/2008 6:24 PM
So far it looks like I'll be sticking with the system I already have. Makes things a lot simpler since dimming these LED's is a tricky business - they like to turn off rather than going dim. Good-o then...
Sandmann #229706 01/08/2008 6:29 PM
Having followed one of your LED taillights.... you can't miss them. I was looking at maybe making it myself, but I'm not sure at the mo, I still like the [sshhhh] H-D [/sshhh] ones...
I'd leave them as they are. Or just try and add more!
GinaS #229707 01/08/2008 6:33 PM
They look good thats a well neat idea.. I just love LED`s
I used one of these http://www.comagination.com/bflasher.htm for the flashing of the brakelight. I have to disconnect it each time for an MOT but thats just 3 push connectors..
TrOjAn
GinaS #229708 01/08/2008 7:07 PM
That's the general idea - the more visible the better. I like some of the HD ones too - I gotta give that company one thing, they know all about making a bike look good. I rather like the Honda VTX ones too. What I need to do is get hold of one of the many chopped up bits of rear fender that must be floating around from all the bobbers, and start trying on other tail-lights for fit. The "blob" that Triumph gave us works well but isn't the most attractive thing on the bike. If we can find a more common bike's taillight that works on our bikes it'd open up the range of LED inserts, chrome do-dads etc available to us.
Electronically adding more is easy - I could wire up 200 of the things if you really wanted. The hard part is fitting them into the taillight. If I had the faclity to make proper PCB's I could make the electronics smaller than the current crop of "perf-board" inserts but it's not worth spending the bucks on it for something I only do very occasionally. Besides, it's a messy job, what with photo-resist chemicals, etching acid, fixers and spraypack clear coats, etc. I'd need to go out and by a drill press too, and some incredibly tiny drill bits. Getting them done professionally is out of the question since they only do them in runs of 100+.
Oh well...
TrOjAn #229709 01/08/2008 7:12 PM
Yep, I looked at that - mine's basically the same thing except the flashes are user settable to a point. Also mine won't come in a seperate box - it'll be a single board with the LED's mounted on it too that you insert into your taillight in place of the bulb socket, so no mucking about trying to find somewhere to mount yet another black box.
Interesting point about the MOT... in Australia we only have to do the inspection when we first register the bike rather than every year. I might see about putting in a "disable switch" to switch it back to standard operation. Maybe a push-button arrangement, so you can drill a small hole in the side of the lens, put in a rubber plug for waterproofing, and simply poke something in to turn the flashing on or off.
Sandmann #229710 01/08/2008 8:00 PM
My father has a set of LED "Dounuts" that fit over the rear turn signals that are dual intensity for running and brake, then the turn off as the turn signal lights up, very effective, specialy when he gets his clear lens with the oragne buld on. Your LED Taillight would go great with that set up. Plus I think the 6 - running and all break would be more noticable, more eye catching when you apply the breaks.
Dormaar
Dormaar #229711 01/08/2008 10:38 PM
I've seen those extra running lights - they'd be a great addition and could be easily made to flash along with the standard light, or to act normally. You'd probably want them NOT to flash, else having the brake lights flashing AND the turn signals flashing behind the one lens could get confusing.
Unfortunately having running/brake lights inside the turn signal housings is illegal in Australia, as the law specifically states that indicator housings must house only the indicator lights, so I won't be adding them to my bike. (That's why you never seen brake lights doubling as turn signals in Australia, the way American cars do. All Aussie cars have seperate turn signals, like British ones.)
Hmm there's another idea, I'll add an "output" in case people want to connect extra flashing brake lights, as well as a "flash disable" switch. Any other suggestions/additions you folks would like to see?
Sandmann #229712 01/09/2008 8:28 AM
How about having the tail lights around the outside, and the brake lights making a "T" in the middle ?
Cheers
Steve
morethanenuff #229713 01/09/2008 8:54 AM
Funky idea, but that'd give more (therefore brighter) tail light than brake light... sposed to be the other way round. Could possibly to the T taillight, and a surrounding circle of brake light though...
Sandmann #229714 01/09/2008 9:26 AM
The possibilities of that one could be endless, like an "A" for taillight and then put a circle around it for brake.
Dormaar #229715 01/09/2008 10:27 AM
I have the same setup your dad does (from Electrical Connections in Knoxville, TN) and I'm thinking this would be a nice addition.
oldroadie #229716 01/09/2008 11:22 AM
Chy has them installed on his bike and riding behind him you really see a difference. At one point I had the parts for the setup but sold them to a member here since I decided to go another route.
Matt I do like your ideas and can't wait to see what you do with it.
wojo #229717 01/21/2008 4:44 PM
Don't forget, this is a direct plug-n-play solution for the America tail/brake light housing (don't worry that it's listed for a KLR650).
Todd Richmond Grapevine, TX USA '78 R80 /7 '06 FJR1300A
bmwhd #229718 01/21/2008 5:53 PM
...except that you need to find a solution for the license plate light eg: illuminated frame etc. Plus you can't say "I made it myself".
