oil change b4 winter storage
#603375 11/30/2024 7:36 PM
jon1214 Offline OP
I was wondering if I should change the oil on the America b4 winter storage.
currently has 6,000 miles on the oil, I usually change the oil every 8,000 miles.
Re: oil change b4 winter storage
jon1214 #603376 11/30/2024 11:02 PM
Better to change in spring, condensation and contaminates will get in the oil over winter even if you don't run it.
The_Dog33 #603378 12/02/2024 12:01 AM
jon1214 #603395 12/10/2024 8:18 PM
jon1214 Offline OP
I don't take the battery out but it's on a trickle charger for the winter.
May be by mid-March I'll be riding again. Hope so.
Have a wonderful remainder of 2024 and good luck in the new year.
jon1214 #603396 12/10/2024 9:38 PM
You too Jon!
jon1214 #603407 12/28/2024 6:12 PM
Similar question came up on the Rocket forum... about changing oil for winter and should we worry about it??? Here was my extended answer... I agree with Dog too...
Short answer.... I really don't care.
If it is due because of mileage, I replace it. Otherwise it stays in the bike. I've never had an oil related issue storing the bike for the winter hibernation. I do use a premium motorcycle specific oil brand though. I have had the oil tested at the manufacturer's recommended oil change interval and it was still good to use... The riding climate in my home town is conducive to extending the oil change intervals. I typically run the oil in my bike to the recommended limit. Remember, a Rocket is no dirt bike so the oil remains generally free from outside contamination. You have to determine if the humidity is bad enough to warrant shorter oil drain intervals.
In the mine equipment field in one of the deepest base metal mines in the world I worked in for 37 years, we did extensive oil analysis testing. We found that with quality oil, we could extend oil life considerably by improving oil filtration using centrifical type filters (for engines to remove soot) and kidney loop filtration. Everthing on a loader or haul truck was extensively filtered improving component life dramatically. But this equipment didn't stop for any extended interval...
jon1214 #603427 01/20/2025 6:59 PM
jon1214 Offline OP
I use Castrol 10-50W, change the oil every 8,000. miles.
Use Mobil M-108A extended life oil filter.
BA.com reunion rally
by chy - 04/14/2026 9:11 PM
