machining new triple clamp
#603048 01/24/2024 11:58 AM
mag10 Offline OP
With the strange 'too warm to hunt' weather here in December between the holidays. I finally got going on the long put off top triple clamp for the speedmaster that would fit isolators like the thunderbird uses. No longer having balancing shafts in the motor makes handlebar isolators seem like maybe a worthwhile thing to have.
I started out with a 12x5x1.25 inch bar of 6061 aluminum (that I bought 3 years ago). After whitling away most of it, I was about 85% finished when the cold weather returned and stopped work for a while.
I have to order a 1/8 inch slitting saw to cut the clamps and a little more light weighting left to do. Then wait for it to warm up again.
I have a set of new t-bird isolator rubbers and will use a t-bird riser spacer to adapt my HD duece risers to the isolators. It needs to be loosely assembled and then I can calculate the optimum length for the inside steel isolator tube based on the motor turning at 4000 rpm.
Not sure of the finish that the clamp will have. Could polish, or could tumble and hard anodize to look like the OEM, could anodize a bright color, even chrome!
Re: machining new triple clamp
mag10 #603049 01/24/2024 7:43 PM
chy Offline
Sounds like you know what you are doing. Hoping it works out for you.
mag10 #603125 06/10/2024 7:16 AM
mag10 Offline OP
I finally got the top triple done and assembled. It looks like it belongs on there. As I had the deuce risers on the bike and wanted to keep them, I had to get a new pair of risers that still have the bosses on the lower ends and make caps to fit the isolators. The new riser is an inch up and some back and is a little tight on the brake line and the clutch cable. Working with Fast Eddy to source some new ones.
I have taken pictures as the project progresses and will post them when all done.
mag10 #603126 06/10/2024 8:35 AM
Wow, I thought Fast Eddy retired. I would have suggested him in the caliper thread if I knew he was still plugging away.
The_Dog33 #603131 06/11/2024 7:39 AM
mag10 Offline OP
so far as I know Eddy is still going. His web site is up and he answers the phone.
mag10 #603220 08/23/2024 7:19 AM
mag10 Offline OP
I finally got this bike back together and, on the road, (thanks eddy). Did some fine tuning on the spacer lengths. I ended up 2.5mm shorter than my original design indicated. Actual compression of the isolators is somewhat variable.
I think that the new triple has taken a good part of the buzz out of the handlebar. The rise and pull back is a little more, which is good for my riding position (and back).
It was a lot of work for a feature that many bikes come with from the factory. But this is a hobby, so....
mag10 #603755 01/07/2026 8:38 AM
mag10 Offline OP
I never did report back on how this mod turned out. After riding here and there over the summer and tweaking the isolator compression, I got it to where it is pretty smooth.
I realize do that it will never be as good as it would be with the balancing shafts still in the motor, that was a tradeoff that I would think hard about making again.
In early October took the bike on a 300-mile day trip, motor ran great, no buzz or numb hands. Could have gone a couple hundred more.
Totally worthwhile project. I should have done it sooner.
mag10 #603756 01/07/2026 1:02 PM
II don't remember, was there a reason to eliminate the counter balance shafts?
The_Dog33 #603757 01/12/2026 4:34 AM
I believe mag 10 bored and stroked his little 790 out to an 1100cc monster. Just ain't enough room in the case for the counter balancer.
Two_Wheel_n #603760 01/13/2026 12:13 PM
mag10 Offline OP
per Bill Gately at Bonneville Performance, the counterbalance shafts are a power looser and are not needed with a balanced crankshaft.
He was pretty clear that even with the balanced crank it would not be as smooth as the stock motor with the balancing system in place.
I do not recall a discussion on whether the balancing shafts would still fit or not. But I did not try either.
mag10 #603761 01/14/2026 4:39 AM
Thanks for the clarification, I had a Norton that was balanced with Malory slugs , it still jumped around when it was running.
