Intermittent Miss?
Posts: 4 |
I have a, '03 BA, bike starts fine, misses intermittently on idle, also from start of accelerating. Runs fine at speed. Thoughts?
If you can read this, thank a teacher - and since it's in English, thank a soldier.
Re: Intermittent Miss?
Posts: 10,711 Likes: 4
Posts: 10,711 Likes: 4 |
possibly not jetted correctly, what do you know about this bike?
Posts: 4 |
Everything, purchased it new in '03, been running fine, just recently started missing/hesitating on take off. Plugs look fine, fuel is new, air filter about 6 months old.
I would suspect maybe something in a jet, drop the carb bowls and see if there is any crud in there. clean the jets out and try again
Posts: 1,474 Likes: 5
Posts: 1,474 Likes: 5 |
Did you check your squirrel condoms? Rubber intake manifold?
Posts: 4,931 Likes: 1
Posts: 4,931 Likes: 1 |
Hidden filter still in place? Restricted tank vent, batch of bad fuel? Seafoam is a good start and beneficial to your fuel system whether it fixes the specific problem or not.
Posts: 23,171 Likes: 55
Posts: 23,171 Likes: 55 |
Spray carb clean around the intake rubbers and vacuum caps and listen for any change in idle.
