Slouching
#547939 06/02/2014 6:45 AM
When riding, I find I have a tendency to slouch.
What do you guys (or gals) do? When I do, I mentally tell myself to get my back straight, but it only lasts for a few minutes, then I find myself slouching again.
On longer rides, it makes my back ache, and my shoulder blades tense.
Any suggestions? (I was contemplating the switch to a T100 for a different riding position)
Re: Slouching
perceval #547940 06/02/2014 8:31 AM
Driver's backrest!
Re: Slouching
piper1 #547941 06/02/2014 1:20 PM
i raised my bars and brought them further back, put speedmaster riser and america bars. helped allot.
Re: Slouching
perceval #547942 06/02/2014 2:39 PM
I found wearing a kidney belt helps a lot.
Re: Slouching
dollarbill #547943 06/02/2014 2:54 PM
Fast Eddy sells a good quality backrest that mounts to the top of the rear shocks.
Re: Slouching
Ryk #547944 06/02/2014 9:49 PM
I have 4 1/2" rise and 1 1/2" pull back HD risers with BA bars on my SM but still tend to slouch.
Re: Slouching
piper1 #547945 06/03/2014 12:33 AM
Driver's backrest!
+1
Re: Slouching
Keith #547946 06/03/2014 9:54 AM
if riding solo I wear a back align to keep me from slouching. Riding 2 up, slouching is not a problem.
Re: Slouching
mag10 #547947 06/03/2014 11:25 AM
I'm always 2-up.
I still slouch.... and get pain in my shoulder blades after a while. Maybe because I'm 5'7"...
I could have a look at FastEddy's backrest (sorry but it doesn't look the part, even though I'm sure it does the job).
I need a floating disk from him anyway, I may add the backrest, especially since it looks like a very easy on/off item for the bike.
I'm not sure about the back rest though. Maybe...
But I still have this nagging idea about a T100....
Need to demo one with the wife behind first....
Re: Slouching
perceval #547948 06/03/2014 1:12 PM
You need to bring your bars back, otherwise you almost need to slouch to ride. The K. belt, backrest, and the bars further back all goes to correct the problem. As long as I can push my back into a backrest and reach the bars comfortably, my L-2&3 ruptured discs just feel (like sh!t) normal, without that, I'm in total misery and I just want to go home and eat Narco pain meds. I do agree the standard bike position with your feet under you, may help you without all the mods. I'm sure you will get it sorted, pain is a very strong incentive.
Re: Slouching
edmspeedmaster #547949 06/03/2014 1:38 PM
I want to add that i also in addition to the above,I raised the rear part of the corbin saddle by adding rubber disks under the rear pads that sit on the fender, which forced my lean a little more forward, i also bought a set of the front peg re-location brackets from a member in here which brings the pegs back 2" and down 1" these three items make me sit much more upright with my feet closer to being under me as apposed to in front of me, i am 5ft 8" with a 30" [ant leg legnth and this set up is perfect. Took a few years to get there though.
Re: Slouching
perceval #547950 06/03/2014 4:21 PM
I have lumbar spine issues as well. Buy a backrest and you will not take it off-problem solved!!!!!!
Before back rest 100k was max before pain stop. Now 6-7 hundred k not an issue!!!
Cheers
Kent
Re: Slouching
kent1969 #547951 06/03/2014 4:47 PM
http://www.backaline.com/index.html
I used a generic brand of the above before I went with a Corbin backrest and it really made a difference. If I were to take a long trip, I'd order one myself - even with the Corbin.
Re: Slouching
edmspeedmaster #547952 06/03/2014 5:35 PM
I've done the same, it also helped me a lot, especially on long runs.
Re: Slouching
Bedouin #547953 06/03/2014 8:27 PM
I put pullbacks on my America, but my shoulders and neck still ache, sometimes.
Re: Slouching
arstaren #547954 06/03/2014 9:31 PM
I was hesitant adding risers and such. Doesn't it alter steering? The long America bars already feel so far from the front wheel...
Re: Slouching
perceval #547955 06/04/2014 12:15 AM
I put taller risers on my bike, Jeff and never looked back. I'm about the same height as you and it made a huge difference to my comfort.
Re: Slouching
Keith #547956 06/04/2014 8:54 AM
www.Spacerjim.com is a quick way to go up an inch without any cable issues.
Re: Slouching
perceval #547957 06/04/2014 1:24 PM
you will not be bothered by any steering effects, this is how mine ended up, more than a few people in here have set it up this way, i am using america cables and they are fine.
Re: Slouching
Ryk #547958 06/05/2014 8:27 AM
I'm starting to have neck and shoulder pain since joining the ranks of AARP. What's a good source for risers that also pull back for an 06 America that wont require cable change?
Re: Slouching
Bruce #547959 06/05/2014 5:36 PM
Are you talking about a stock seat?
Re: Slouching
AngusPT #547960 06/05/2014 5:38 PM
I could only ride for about 45 minutes on the stock seat, back and coccyx pain.
Re: Slouching
AngusPT #547961 06/06/2014 2:09 AM
I get neck and shoulder pain too, it's from the WIFE
Re: Slouching
mcfcinusa #547962 06/06/2014 7:01 AM
I wish my wife was still alive, she was a pain in the ass sometimes but that I could tolerate. All my pain is up in the shoulder and neck area, arm is tingling constantly also.
Re: Slouching
Bruce #547963 06/07/2014 9:15 AM
We keep the best memories, and forget the bad.
Ok, I'm thinking risers like on the speedmaster, but will that affect the cables? Already my throttle cable is acting up when I steer all the way to the left, revs up the engine.
Re: Slouching
perceval #547964 06/07/2014 1:47 PM
It might affect your cables, but you can reroute them to the right of the yoke for a bit more play.
Re: Slouching
Keith #547965 06/08/2014 2:36 PM
Its interesting how different people are affected by the same seats. I have back problems from slipping a disc many years ago and now have several fussed disc's. Things are mostly all good as I've learn't several small things to do for myself when I feel I might have over done it.
Having said that I find that if I do have a sore back, nothing (and I mean nothing) helps my back like a ride on my Bike the longer the better. My set up is stock on the Speedmaster and find the lean forward to the bars super comfortable, My back stays nice and straight all day. I'm 5'10". I would'nt change my set up at all. As I say just find it interesting.
Re: Slouching
Cloudy #547966 06/08/2014 2:44 PM
Didn't anybody's grade school teacher give them a slap upside the head for slouching in their chairs?
Re: Slouching
Two_Wheel_n #547967 06/12/2014 1:58 AM
I find I slouch as well, but that may just be poor posture. Last year I started getting a little pain between the shoulder blades. I've never had lower back issues due to the speedmaster forward lean. I feel it has helped me keep my back straight as well. I am trying bringing the bars up and back and inch. On one longer ride I noticed the same pain. I may go back to the stock (or relatively close due to custom bars) position. I do have a bikers friend type hard round bag for overnight trips that doubles as a back rest. I'm 5' 11'' but only have a 31'' inseam. I think my long body and short legs work well with a little forward lean.
Re: Slouching
Hermit #547968 06/14/2014 1:17 AM
+1 for the corbin.I bought the seat alone.But the seat alone fixed my tailbone problem it didn't completely fix the slouching/lower back pain.I succumbed and bought the back rest and it's so good.Now no tail bone or back pain. Although I have the America.It's different with the Speedmaster
Re: Slouching
findlay13 #547969 07/07/2014 9:26 PM
Riding with solo seat, floor boards and Rivco risers on the Speedmaster sometimes upper back gets tired from the problem of slouching. The extra spacer under the rear mount sounds like a good suggestion prior to springing for an expensive albeit superior seat. The backrest might be the next step.
Re: Slouching
perceval #547970 07/10/2014 7:34 AM
Well , according to what I see with the local V-twin crowds... to crouch is to be "cool" but when I travel for reasons other than "show and tell" I'll wear my riding pants (leather Triumph) that have a high waist, would assume a kidney belt would do the same....On my Bonnie-A I have mid mount pegs too , that might be a consideration to assist your riding position.
Yes, messed up that reply placement I did...
