? on changing front sprocket on speedmaster
Posts: 2 |
I want to put a bigger sprocket on the front to drop rpm's on the top end. Anyone found a good combo yet? How many teeth and will stock chain work?
'04 Speedmaster, Bub slash cuts w/baffels knocked out, 13.5 in. apes, low profile seat, rear lowering kit from boogieman. No front fender, and I bobbed the rear fender.
Re: ? on changing front sprocket on speedmaster
Posts: 10,711 Likes: 4
Posts: 10,711 Likes: 4 |
18 or 19 tooth, you can get from fasteddysports.com or newspeedmaster.com
Posts: 234 |
19t, stock chain works fine, 30min to 1hr mod. Really easy. No longer looking for sixth gear and still OK off the line.
Adventure before Dementia...
Posts: 3,057 Likes: 8
Posts: 3,057 Likes: 8 |
What year is your Speedmaster. The early models had 16 tooth front sprocket. The later models went to an 18 tooth (I think).
Posts: 2,240 |
I've had the 16t (stock sprocket), the 18t, and currently the 17t. Chain will work, no problem with any of them.
You adapt to what you have. I liked the 16t for the first 8-10k miles (I can't remember), then the 18t made it a whole new motorcycle, and then I put the TRIUMPH America chain and sprocket kit (with the 17t front sprocket)on, and I'm just as happy with it. I even think seriously about going back to the 16t next chain/sprocket change....I liked it when I had it, and the bike runs so good over 5k rpm I think it would be fun to be able to run the higher rev range on the highway more than I can now.
You can't go wrong.
Posts: 2 |
Mine is an'04 SM. As you know it turns about 4000 rpm at 60mph. How much will my rpms drop going from a 16 tooth to a 19 tooth?
I have a 17 tooth on mine, and I am sitting at 4000 rpm's at 70 mph.
Posts: 96 |
4000 rpm x 16t = 64000 divided by 19t = 3368 rpm @ 60mph.
Posts: 247 |
You'll drop aprox. 200 rpm's per tooth in high gear I run a 19't and think it would pull an even higher gear with no problem. I'm up to 51 MPG!
Posts: 2,726 |
I have an 18T sprocket and do close to 75 at 4000 rpm.
Bob
+1 that's just peachy for cruising the slab...
