 Tips for riding in the rain
Posts: 2,647 |
I got stuck in some rain on the way home from work yesterday (thanks awesome weather forecasters  ) and it made me think of posting this. When it comes to riding in rain, I really feel uneasy when any kind of turning is involved. I get this paranoid feeling that the wheels are just going to slip out from under me at any given moment, and I get a tendency to tense up a bit, like I don't want to lean the bike very much. I also am a hawk for painted lines and manhole covers when turning, which I guess is good but it's all I see, I end up looking down at the road instead of where I'm going. I really have no reason to be so paranoid other than a lack of experience in the wet. usually if it's going to rain I leave the bike home. I mean sometimes you gotta do whatcha gotta do, but I avoid it when possible. So, short story long, I was wondering if anyone had any wet weather riding tips for not only me, but maybe some others who are wondering as well.
 Re: Tips for riding in the rain
Posts: 6,060 Likes: 6
Posts: 6,060 Likes: 6 |
Sure, I've got a tip. Be doubly vigilant watching the cage drivers. Rain either brings out the nut cases, or amplifies their poor judgement. I've noticed through the years, the worst behavior happens in the first ten minutes of a rain, only compounding the slickest time of a rain.
Posts: 2,580 |
Always remember that the first rain after a dry spell brings the oils out of the road which makes things extra slippy But, the more wet weather riding you do, the more confident you'll become. Not necessarily like it more though
Bryn makes a good point. If possible it's an idea to let 'er rain for a half hour or so before heading out. That way the oils lifting from the road have a chance to wash away. As you yourself pointed out Scott, avoid manhole covers, and painted surfaces... come to a stop BEFORE the painted line across the road at an intersection for example. Use caution on railway tracks, bridge grates, wood (as in old bridges) and here's a good one... WET LEAVES!!
It's surprising how much traction there actually is on a wet road. The easiest way to test traction is to feel for it with your rear brake. Assuming you know how much deceleration you get on dry pavement before the rear tire breaks loose, you have a gauge of what's available if you repeat the test when the road is wet. If you do this at moderate speeds on a flat, straight road it won't become a thrill ride.
Other thoughts... still use the front brake but use it gingerly. The obvious... run with good tire with decent tread. Dress properly for the occasion... being cold and wet slows reactions and causes the rider to stiffen up. Maximize the ability to see but turning your head from one side to the other to help blow the rain away from visors or goggles.
I also try NOT to ride in depressions made on high traffic roads by the weight of vehicles rolling along. Yeah... getting in there can cause hydroplaning which is no fun at all!!
Posts: 144 |
Reminds me of the time I ran into a rainstorm, wisely pulled over and gave it 15-20 minutes to wash the oils etc. off and had a really pleasant ride... until I over took the leading edge of the rainstorm and found some really fresh oil patches. Nice lesson learned. I do like riding in the rain, just with a bunch of extra caution. And you are so right, a big difference riding in a warm rain than a very cold one.
Posts: 5,616 |
I feel the same way. I try not to go out if its raining if it can be avoided. I also stiffen up (pucker up as well) and I used to have a tendency to focus on the hazards.
Step one...know that you have the issues....you got that covered. Step two...relax a bit. Your there and theres no getting out of it so relax just a bit. My personal biggest fear was the tires slipping out as well BUT those tires have more grip than most of us use even in the dry. Keep your eyes open for the hazards...manhole covers, painted lines, cobblestones, deep water, etc....just like you have been doing. Step three...remember...you WILL go where your looking, even in the rain so know your hazards and look through your turns. This is the one that used to get me. Step four...slow down. Not so slow that you become a hazard but slow down. Im sure you got this one covered already as well.
I rode in the rain yesterday cause I had no option. No issues, kept my cool, kept my speed acceptable, kept my eyes open, kept my head turned when making turns and all was well. I actually had a good time.
NEW: 19 Goldwing Tour DCT
Posts: 2,626 |
Here's two tips for you. 1. Ride one gear lower than normal. It increases the compression braking, so you don't have to squeeze quite so hard on the regular brakes. 2. Reach down on the left side of your carbs and adjust the idle speed slower. This lets the throttle slides close a little bit more and adds even more compression braking. In a Florida Monsoon, I'll set the idle at about 900rpm. You have to keep one hand on the throttle at stoplights, though, or it'll stall.
The Hayabusa Killa
Procom CDI
Posts: 12,164 Likes: 1
Posts: 12,164 Likes: 1 |
Interesting ideas. Never thought of those, but they make sense.
Posts: 3,467 Likes: 3
Posts: 3,467 Likes: 3 |
Though I usually avoid rain, practice does make perfect. Occasionally, I'll suit up and ride when I've got no particular place to be. After the first dozen or so miles, it's relaxing.
No traffic though.
Ride only as fast as the conditions allow. This is not to say to ride below the speed limit nor above it, but usually riding under the limit is the safest bet. Ride at the limit or over, only when conditions allow. Animals sometimes like to play in the rain. Lookout for 'em scurrying about on the road. Seal any electronics in freezer grade ziplock baggies. Wallet too. Try not to be next to cages or behind them. If so open up a three second space. Don't break traction. Constant throttle though turns with no throttle chop or roll on. Being in the correct gear is essential. When vertical again, moderate throttle to speed so you don't break the back tire free. Puddles suck. Painted lines suck. You will break the rear tire on paint if you get hot on the roll over. Tuck in at speed so the rain won't sandblast you. Reach down every so often and pull the rainsuit legs back down over the top of your boots. again. Ignore the trickle of water running off the back of your helmet, down the inside of the back of your jacket. Take longer at rest stops as fatigue has a quicker onset. Pray that the complete change of clothes you have already placed in ziplock bags doesn't spring a leak! Stay at a hotel that has a hair dryer so you can dry out your stanky digs. Promise yourself you will not tear up your rainsuit as you step out of it half soaked!
Posts: 2,647 |
Good advice guys.
Just rode today for about 5 hours in rain... sometimes very heavy rain. What were the TOP concerns I had to address during this ride? Being able to see and level of comfort.
Posts: 246 |
I ride in the rain a good deal. I agree with BrianT that being a gear lower helps. I've never tried adjusting idle speed before, I'll be sure to test it out soon. I try to keep my tires a few psi deflated from the recommended psi. Being able to see is pretty crucial. I usually carry some fog-x anti fog wipes with me.
Posts: 988 |
I won't start out in the rain or if there is a good chance of rain either. But if I get stuck in it I get stuck in it. The biggest thing to remember is ride at a speed that you feel comfortable with and be careful the first 10-15 minutes of rain. A rainsuit makes for a lot more comfortable or pleasent ride. It sucks to have to ride for hours being soak and wet to the bone. I got stuck riding about 250 miles a couple years ago coming home from the Nor East Rally. I purchased some Frogg Toggs just for that trip. It actually wasn't a bad trip being prepared for the rain. MAKE SURE YOUR TIRES ARE NOT BALD!! You are just asking for trouble with bald tires. A lot of good points were brought up here. Just be careful out there and keep the rubber side down.
Posts: 7,630 Likes: 7
Posts: 7,630 Likes: 7 |
I don't set out in the rain but I don't let moderate chances of rain make me stay off the bike either. I've been wet before and I'll be wet again. I figure that my skin is water tight and I'll get to change clothes when I get where I'm going. That said, try to avoid the painted arrows and crosswalk lines, they can be slippery, ditto steel strips on bridges and steel bridges themselves, give yourself more room to stop and accelerate more slowly, assume you are even MORE invisible, I stay on the highest/driest part of the road, and if you're going on a long trip pack some good rain gear.
Posts: 15 |
Just read this thread and am jealous that so many people have the option of not riding in the rain. There are occasional days here when it's sunny and doesn't rain but it's the exception. I am thinking of moving to southern france just so I can ride in the sun!!
Posts: 2,580 |
You said it brother
Posts: 208 |
I got stuck in a thundstorm only 1/2 mile from home. I slowed down and stayed in the right lane and I was really nervous. Then the wind started. It started to blast me from the right side and was over 60 mph. One time only two blocks from home it blew me into the left lane. Both tires lost traction and the entire bike scooted over 10 feet to the left because of the wind gust. At that point I pulled over to the right and parked the bike and waited until the wind died down to a more reasonable level and drove home very carefully.
That was an experience I do not want to repeat.
07 Speedmstr, Long Tors, bags, sissy bar and rack, windshield, engine bars, 2 ww lights, 2 fast eddy stickers and a .45 ACP.
Posts: 2,580 |
Yeah, strong cross-winds are a lot worse than rain, I wouldn't like to drive the van in conditions like Dan described. Never mind ride a bike
Well, this is a bit OT but a friend once suffered a terrible accident due to wind. Yeah, he was blown right off an overpass and landed in a heap 30' below. Ouch!!!! He still rides but has to climb on the bike as it sits on it's stand, using the pegs as ladder rungs to get up and on.
That was wind alone. Wind and rain? Now that's even more trouble!!!
Posts: 23,241 Likes: 64
Posts: 23,241 Likes: 64 |
Manhole covers, rail road tracks, leaves, and lines painted on the road are all very slippery when wet. Also right after it starts to rain oils and such are still there making the road surface slippery. To lessen that risk keep your tires where the car tires run, there is less oil there.
Posts: 2,419 |
Spilled diesel is treacherous in the wet. Trucks with full fuel tanks often spill diesel out their tank overflow on corners. Their diesel usually spills on the outside wheel track of the corner so it pays to ride the inside wheel track on corners in the wet.
Posts: 582 |
I got stuck riding in a torrent of rain on the way to Lake George. rain suit 1/2 helmet & no bandana to cover my face. ended up riding one handed to block the needles from my face. it sucked.
just remenber to be smooth when the weather gets nasty, trust your tires. ever watch bikes racing in the rain? Smooth.
Posts: 348 |
Investing in good rain gear sounds kind of simple but it does magic. I got used to riding in the rain quite a bit when I lived in the UK. Being able to stay dry while you are getting dumped on always gives me a sense of security that things are not out of control. Make a deliberate effort to keep your bike straight up and down more than what you usually do. This will force you to slow down in the turns and not lean your angle too much. The more of a lean...the less tire contact on the surface. Those are the two biggest things for me...keeping dry and having the most tire surface coverage that I can at all times. You will be surprised how these bikes handle in the rain when that is done; I have traveled through some real whoppers of a storm. Of course in the UK, you can start out with a beautiful and sunny day and two hours later be in a monsoon that showed up out of nowhere. I just got used to it.
I keep a leather face mask the covers my nose and cheeks and goes down onto my upper chest and a pair of brown jersey gloves in my jacket pockets.I also keep a dew rag in my jacket pocket with those 3 simple items I am always ready for rain, I get wet but it doesn't hurt at 70mph.
I wear a dickey of sorts... a leather garment that fits the description of Ian's face mask. It zips up around my chin and face thus covering most of the exposed areas of my face.
But I'm still on the look out for a good finger wiper blade to clear my goggles when I need it. There are gloves with a wiper blade built into the thumb (But I thought it should be attached to the index finger). I once was shown a pair of gloves with the wiper built into the throttle hand glove! Huh? Since then I've hear of a wiper that attaches to the finger of a glove with a Velcro fastener. That sounds like a good idea and I'll either make or find one for those wet and rainy rides.
Posts: 3,971 |
Rain tales In the center of my small town there is a right angle corner with two heavily painted crosswalks across it. Some time ago I rounded said curve in a downpour at just a wee bit above traction speed, and the bike slide out from under me on the wet paint. As I was only going around 5 or 10 MPH, no injury came to me, and I recall laughing about it at the time. There was a funeral home there with 50 or so people outside to witness the spectacle. (My "incidents" ALWAYS happen with at least one or two witnesses to pass the sordid tales along) One gent got fairly frantic and wanted to call the police. Lucky for me I had a full face helmet on, and was able to stave off any embarrassment due to my anonymity. Hearing the word "police" gave me an extra few drops of adrenaline, and I picked the old girl up in no time, and rode away just as a police car was rounding the bend in the other direction. I rode home and stashed the bike in the woods just to be sure. Here in CT single vehicle accidents usually earn the operator a ticket for "Speed too fast for conditions." It's our little way of adding insult to injury, while putting a few bucks into the system. Never did mention the get off to my wife. Shh!  Why worry her for no good reason? Old fart with a bruised ego and a bent brake lever - 1 Police - 0
Posts: 1,540 |
Biggest tip I was told about riding in the rain, is too take it easy. Don't push yourself or the bike. Don't stab hard on the brakes or gun the gas. Just be smooth. Oh and we had a wicked ride back from Dinqua's rally one year, heavy rain, hail, miserable. Uncle Charlie decided he'd sleep for a another couple hours. He had the same ride, just sunny. So sometimes it worth pulling over and waiting.
Posts: 3,971 |
Sleep? Beercoma would be a better word
Posts: 609 |
Rain tales
Great story, well told, Martin.
Posts: 507 |
Been there. That does suck. 1. Slow down 2. Road paint is slick. 3. Maintain extra distance from cagers 4. Rain Gear 5. More frequent stops/breaks
Posts: 582 |
Always carry raingear on trips. Frogg toggs fold to near nothing & keep me 80% dry.
Not wanting to start a tire thread but just saying... as for riding in the rain, tires can really make a difference. My Trophy came to me with Metzler Sportec M3s front and rear and they stay glued to the road in rain. I rode my bike home from the far away dealership in torrential downpours... the kind that makes the backdrop a solid wall of blue-gray wetness. The kind of rain that floods the road and causes huge wet-outs with oncoming traffic. The kind of rain that made me the ONLY bike on the road. I was in this stuff for 5 hours. The whole time I cruised at 70 MPH through mountain passes and the bike stayed planted to the road the whole time.
So yeah, tires make a HUGE difference. Mind you, sticky tires don't last too long... but the rider tends to outlive the tires over and over again. If rain is a considerable part of your riding experience, consider a sticky tire such as the Metzler Sportec M3. One critic said this of the M3s...
"The M-3's compound is called "DuraSil", and contains a lot more silica than the compound of its predecessor. The silica works to enhance wet weather performance in the Sportec M3."
Posts: 1,193 |
http://ascycles.com/detail.aspx?ID=1628
Love these.
"Let your soul shine,
It's better than sunshine,
It's better than moonshine,
****** sure better than rain."
-ABB
Love these.
There we go. Thank you Paula!!
Posts: 10 |
since moving to the south and into (almost) year-round warm weather and selling the van, i ride my bike about 99% of the time. our only car is wifey's and she keeps it.
when school is wide open, i ride about 30 miles round trip to my afternoon class and have to ride in the rain occasionally. my tips are just to keep an eye on the weather.
if there is a chance of precip, i carry my rain gear. staying dry makes a rainy day comfortable, which helps keep a good mindset. you don't have to feel rushed to get in out of the rain. i increase following distance, slow down overall and i STAY OFF painted lines as much as possible. when i make turns on the lines, i plan them so i can stay upright.
of course, this is a routine drive and i have these spots memorized. i doubt i would take off into 'unchartered' territory in the rain.
...and on the eighth day, God said "Let's ride!"
... i doubt i would take off into 'unchartered' territory in the rain.
A good rule of thumb is to pretend you don't have any brakes (increases reaction time) and a really slow throttle. (A good wack on the throttle and you'll know why a slow throttle is good). Stay away from puddles as how deep are they really? Stay in the fast lane as the outside lanes hold water. And yes those painted lines, rr tracks, and steel surfaces are as slick as a gnats rear end. Beware of cages splashing you too. Other than that 'unchartered' territory is easy peasy.
Posts: 2 |
A mixture of road grit and water turns out to be the fastest method to erode rubber brake pads. Pads that last a full season in the dry will run metal to metal on the rims in a month of wet-weather training rides. Also, most rims require a full revolution before the brake pads squeegee the water from the braking surface and begin stopping. Plan ahead and brake early.
Posts: 8,393 Likes: 1
Posts: 8,393 Likes: 1 |
onces I was on my way home from Littlerock Arkansas. The weather was great until I got about half way through Texas. I ran in to a rain storm on 59 in the middle of nowhere. It rained so hard and so sudden it was freaky. I couldnt see more that a few feet in front of me. finally I found an old car wash and pulled in until it stoped. thats the worst rain story I don't carry rain gear so when it rains I try to pull over, its not always possible. some times you have to tough it out. You got it all right slow down watch for hazards such as paint, puddles, and pot holes. more than all that watch the idiots in cars they are tuned out, turned off, and dont care. I cant count the number of near misses because of some jack a$$(usually a woman in a car) with a cell phone, or chatting up some one in the other seat.
Edgar Allan Poe
Posts: 38 |
It's good to know I'm not the only one who is nervous or doesn't like to ride in the rain! My first time was during a rain/hail/lightning...will never forget it or repeat it!
When some friends and I rode to Laconia , NH a few years ago it was raining when we left and only got worse the farther we rode. It rained so hard I couldn't see the tail light of the guy in front of me. The farther we rode the colder it got too. None of us had rain gear, except 1. Wendy stayed on the back of my bike and my friends wife on his even though there was a van they could have gotten into. The 2 new rides commented on how tough Tom and I were but it wasn't that, it was that we wanted to get there! Once we hit the northern end of Vermont we finally gave up and spent the night in a motel. We were freezing and wet to the bone. My room had an oven and we took turns turns "cooking" our clothes to dry them. I have a shot of my boots that looks like a guy is laying in the oven. I still have them with the liner of the tongues burned. It made for a great time even with the rain. We hooked up with a stranger on an HD dresser about 1/4 of the way into the trip and he rode with us and even shared a room with one of the guys in our group.
Good story Ian! So what's your tip in all of this... remember not to leave yer clothes in the oven too long?
That could be drawn from the story. One of our group got in the vans blind spot coming out of a parking lot and was run over by the trailer so you should always be aware of your surroundings. We had 2 novice riders and he was one. No injury except his pride. I had a close call on some paint at a toll booth but didn't go down just had the back tire kick out a little. You can wear a trash bag under your leather to keep you dryer than if you didn't have one. You still get soaked in the kind of rain we rode in though. It sucks to see through little round sun glasses in the rain. A 71 Triumph Bonneville doesn't want to start after being trailered across several states in the driving rain. Same Bonnie will stop dead when the center stand catches on the trailer ramp when the ramp is in a ditch.(That one was pretty funny) A hair dryer will dry the points out enough to ride into town after trailering a 71 Bonnie across several states in the driving rain. Never put a hot gas grill on a plastic folding table. Don't set up your tent at the bottom of a steep hill in a low spot when it's raining. (My friends were floating on their air mattress in the AM. A pretty funny sight.)The list goes on from that trip. It is one of our best memories and was great fun. Bunch of bikers having a blast laughing and having a great time despite the weather. My friend I have mentioned that is in prison now was on the trip and he says he thinks of it often and asks for more pictures on it often and I always seem to dig a couple up. Probably should have edited this with a list and numbers but got too far before I thought of it. Almost forgot, never stick your finger in an electric fly swatter!  We had just gotten done explaining to this Guy Steve why that wasn't a good idea when my other friend Richie walked up behind us and all I saw was a blue flash. Well you guessed it, he walked up and did just that!  He wasn't right for a couple hrs.
Posts: 1,738 |
Try to stay upright and don't bother with the umbrella ella ella...
Funny thing is Keith , I don't think the trip would have been as good without all the crap we had thrown at us. That and we had the right bunch of people. No complainers we just laughed harder the worse it got.I wouldn't change a thing.
As if complaining woulda done any good, eh Ian? To laugh in the face of adversity is to be one step ahead of the consequences!! Again... good story!
Posts: 2,626 |
Beware of seal-coated parking lots. I rode through a Miami canal-flooder 26mi to school, no problem. I kid you not, ten feet from my parking spot I turned a corner, dragged a leeetle front brake... DOINK! At 3mph, no less  It seems I have a harder time picking the bike up when it falls on the right side than the left... Maybe it was just my back acting up. A burly Good Samaritan interrupted his smoke break to help. Live & Learn or Crash & Burn.
The Hayabusa Killa
Procom CDI
Posts: 10,735 Likes: 7
Posts: 10,735 Likes: 7 |
no wonder you had problems, I don't think anyone could navigate a seal coated parking lot!
Good one Dave!
Posts: 2,626 |
You think this is a tough crowd? In my high school, after the football team sacked the quarterback, They went after his family....
The Hayabusa Killa
Procom CDI
Edgar Allan Poe
Posts: 538 |
DANG IF I saw that I would have to clean my pants
